Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
vincent
Posted: Sun May 17, 2009 1:27 pm Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
Someone had an idea where to install a garmin GPS 296 in a yak 52 cockpit ?
Posted: Sun May 17, 2009 3:09 pm Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
I mounted my 295 initially (now changed to 396) to the ventilation tube
between my legs. I used a RAM-B-108 base with strap clamp (P/N 11-02003) to
attach the ball base to the side of the tube. I then used the RAM-B-138-GAZ
(P/N 11-01766) to mount the ball clamp parallel to the tube with Garmin
sitting in front of the flat plate on the vent tube. I bought the mounts
from Aircraft Spruce.
Hope this helps.
Doc
LawnDart
Posted: Fri May 22, 2009 5:22 am Post subject: Re: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
I use RAM mounts. They have one that will mount to the glare shield and hold the 296. It is very sturdy and does not vibrate in flight.
Mount: RAM-B-177-GA7U
http://tinyurl.com/pyojro
I mounted mine in the center. Does cover up the artificial horizon when mounted.
yakplt(at)yahoo.com Guest
Posted: Sat May 30, 2009 2:52 pm Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
Bought N66PW.
Mark
To: yak-list(at)matronics.com
Sent: Monday, May 18, 2009 7:05:44 PM
Subject: RE: Install a GARMIN GPS 296 in a YAK 52 cockpit ?
--> Yak-List message posted by: "Roger Kemp M.D." <viperdoc(at)mindspring.com (viperdoc(at)mindspring.com)>
Hope this helps.
Doc
Posted: Sat May 30, 2009 4:15 pm Post subject: Install a GARMIN GPS 296 in a YAK 52 cockpit ? |
You did! Cool. Let me know when you are going to tooling through central Al if you are going to go back to NC across the lower US.
Doc
From: owner-yak-list-server(at)matronics.com [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of Yak Pilot
Sent: Saturday, May 30, 2009 5:52 PM
Subject: Re: Install a GARMIN GPS 296 in a YAK 52 cockpit ?
Bought N66PW.
Mark
Hope this helps.
Doc
