ChangDriver
Posted: Thu May 14, 2009 6:06 am Post subject: Contactor and Crowbar Ratings |
Bob:
I looked at the contactors made by Eaton that are 337 approved for Cessna Aircraft. Eaton P/N PW6041H215. rated for 28 volts continuous which is good for my 24 volt experimental aircraft. My question is about the crowbar circuit for overvoltage protection of the ground relay. The ones I see B&C and aeroelectric carry are rated at 12 VDC and 24 VDC. Shouldn't they be 15 VDC and 28 VDC to allow for battery charging thru the ground power port? If so, can the ones you sell be modified for this?
Craig
Posted: Thu May 14, 2009 6:35 am Post subject: Contactor and Crowbar Ratings |
At 09:06 AM 5/14/2009, you wrote:
<capav8r(at)gmail.com>
Bob:
When you can find these, get a grip on your
wallet. While these are the cream of the crop
for DC contactors, they're quite pricey.
| Quote: | . . . rated for 28 volts continuous which is good for my 24 volt
No, generally speaking 12/14 and 24/28 are
interchangeable with respect to functionality.
The low-cost 12/24v RBM/Stancore/W-R and Cole-Hersee
battery contactors offered by B&C and others
are quite suited to our task.
( -Thomas Paine 1776- )
ChangDriver
Posted: Thu May 14, 2009 5:53 pm Post subject: Re: Contactor and Crowbar Ratings |
Bob:
Spoke with Bill at B&C. Their 24 volt crowbar trips at 32 VDC. That is OK.
However, I am having difficulty finding a contactor for a 24 VDC application. The Stancor ones have a coil voltage of 24 VDC or 36 VDC. However, 28 VDC exceeds the coil voltage of the 24 VDC unit so it can't work. Also, their 36 VDC contactors will not work because of the coil voltage being too high to activate it. Bottom line is I need a contactor with a coil voltage rating of 28 VDC. Other than the Eaton unit (which you are correct is costly) I am running out of luck. Any ideas?
Craig
Posted: Thu May 14, 2009 7:21 pm Post subject: Contactor and Crowbar Ratings |
At 08:53 PM 5/14/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com>
Bob:
Spoke with Bill at B&C. Their 24 volt crowbar trips at 32 VDC. That is OK. |
Yes . . . the nominal trip range for 14v ov protection
is 16.2 to 16.5 volts. 28v aircraft it's 32.4 to 33 volts.
| Quote: | | However, I am having difficulty finding a contactor for a 24 VDC application. The Stancor ones have a coil voltage of 24 VDC or 36 VDC. However, 28 VDC exceeds the coil voltage of the 24 VDC unit so it can't work. Also, their 36 VDC contactors will not work because of the coil voltage being too high to activate it. Bottom line is I need a contactor with a coil voltage rating of 28 VDC. Other than the Eaton unit (which you are correct is costly) I am running out of luck. Any ideas? |
I can tell you that the 70 series, continuous duty contactors
have been used in 14 and 28 volt aircraft with good
service histories. Yes, they run warm. But in airplanes,
the ambient temperatures for most operating conditions
are lower that max rated for 12v operation which tends
to offset the effects of the extra heating.
The 70-903 contactor has a resistance of 60 ohms
operating at room temperature. If you're worried
about it, you could put a 6 ohm, 1W resistor in
series with the coil to "cool" it off by about
10% of applied voltage . . . but I think you're
okay without it. These contactors have been around
since about WWII. While they're not "Space Rated"
contactors, they've proven to be of good value
in a failure tolerant airplane.
Even the $high$ contactors have bad days
http://tinyurl.com/qmk6gm
If you're loosing sleep over it, consider the
these EV200 series contactors. They feature
automatic coil current reduction after pull-in
to reduce continuous power to keep the contactor
energized. However, they're about 6X the price
of the 70 series device and do generate some
noise that has been a problem for a few builders.
See:
http://tinyurl.com/qazl8t
Bob McC
Posted: Thu May 14, 2009 7:35 pm Post subject: Contactor and Crowbar Ratings |
As Bob N stated in his earlier reply 24 and 28 volt components are
interchangeable. (They are the same thing from a practical/functional point
of view) just as 12 and 14 volt components are. Items such as contactors,
relays, motors, light bulbs etc are just not that voltage sensitive that
they are affected by the normal swing of system voltages. Your 24 volt
(nominal) system may experience actual measured voltages from a low of say
20 (maybe less) to a high of 28, 29 (maybe more) but all of the nominally
rated 24 volt components will function just fine. It's like your house
current at home. It may be 110,112, 115,120,125, 130 Volts or thereabouts if
you actually measure it, but you don't use different toasters, washing
machines, light switches etc for these different values. Standard 120 volt
rated devices are close enough. Similarly 24 volt devices are fine for any
voltage likely to be present in a 24 /28 volt aircraft.
Another Bob
Bob McC
[quote] --
_________________ Bob McC
Falco #908
(just starting) |
ChangDriver
Posted: Fri May 15, 2009 6:18 am Post subject: Re: Contactor and Crowbar Ratings |
Thanks for the reply. When looking at the Stancor 70-903 data sheet it states the Max Safe Operating Range is 110% of nominal rated voltage. That gives me 26.4 volts. In a 24 volt system, the bus voltage often runs near 28 volts for the alternator to charge the battery. That is over the rating.
Additionally, in the Stancor documentation for sizing a contactor, they specifically state a warning about using contactors rated at battery voltage when there is charging taking place. For 12 VDC systems, they make a 15 VDC contactor but have no such beast for a 24 vdc system.
Also, Bob, take a look at the URLs in your last post. Some malware or something has changed the url to some odd url.
Craig
ChangDriver
Posted: Fri May 15, 2009 8:35 am Post subject: Re: Contactor and Crowbar Ratings |
OK, after much research, the Gigavac GX11CA it is. I spoke with one of their engineers and it is designed for 28 VDC continuous use. In addition, it is hermetically sealed as an added plus and it has built in spike suppression so it needs no external diodes. There are also models that have an extra contact for switching on an indicator light if wanted. Price is $113 each. So, more that Stancor, less than Kilovac and much less than CH.
Thanks for all your help and direction!
Craig
Posted: Fri May 15, 2009 10:38 am Post subject: Contactor and Crowbar Ratings |
Actually 28.5 volts nominal . . .
vdc system.
I've read the warning and I've observed the performance
of these contactors in service since they went into the
C-140 back in '46 or so. B&C and I have sold hundreds of
these critters for the purpose of providing battery
contactor, external power and cross-feed service for
many moons . . . and found that they continue to offer
satisfactory service in these applications. But if this
idea stresses your sensibilities too much, there ARE
several alternatives . . .
One COULD also craft a after-pull-in power reduction
module to emulate the performance of devices like
the EV200. A 555 timer and a few jelly-beans would
probably make it work.
Looked over my postings as they arrived here
and didn't see anything out of the ordinary.
Which URL you saw was hosed?
ChangDriver
Posted: Sun May 17, 2009 1:42 pm Post subject: Re: Contactor and Crowbar Ratings |
Bob:
These urls
See:
Posted: Sun May 17, 2009 6:03 pm Post subject: Contactor and Crowbar Ratings |
At 04:42 PM 5/17/2009, you wrote:
Bob:
These urls
. . . and this 6041 series contactor . . .
in spite of its pedigree had a very
bad day in a King Air about 20 years
ago.
See:
. . . and this is an exemplar 21st century
design for a contactor along with a place to
purchase the critter.
These are "Tiny URL" contractions of the
desired address. See:
http://tinyurl.com
Bob McC
Posted: Sun May 17, 2009 6:36 pm Post subject: Contactor and Crowbar Ratings |
Craig;
Both those URL's work fine for me.
Bob McC
[quote] --
Falco #908
(just starting) |
jquinn3(at)gmail.com Guest
Posted: Tue May 19, 2009 12:38 am Post subject: Contactor and Crowbar Ratings |
Bob,Why would the Tyco EV200 create noise in some applications and how could this problem be mitigated?
On Sun, May 17, 2009 at 16:42, Craig Winkelmann <capav8r(at)gmail.com (capav8r(at)gmail.com)> wrote:
[quote]--> AeroElectric-List message posted by: "Craig Winkelmann" <capav8r(at)gmail.com (capav8r(at)gmail.com)>
Bob:
These urls
See:
http://forums.matronics.com/viewtopic.php?p=244422#244422
-List" target="_blank">http://www.matronics.com/Navigator?AeroElectric-List
le, List Admin.
Posted: Tue May 19, 2009 4:41 am Post subject: Contactor and Crowbar Ratings |
At 03:33 AM 5/19/2009, you wrote:
| Quote: | Bob,
"Noise" by definition is the artifact of rapidly
changing current flow that propagates from some
antagonist to some victim. This is described in
more detail in the book. Sometimes the 'noise'
is an intentional byproduct of a useful radiation.
For example, you radiate strong signals from your
comm and transponder antennas to achieve
a useful purpose. In some cases, the stronger the
radiation, the better. However, this radio frequency
energy can become a nuisance too. Its sorta like
being pleased that your wheat fields are benefiting
from a good rain shower but the holes in your roof
are a source of concern.
The EV200 (and similar devices) use an transistor
that's turned on with varying duty cycle to reduce
current in the contactor coil after pull-in is
achieved. The speed of the switching device, the
amount of current it carries, the area of its
"antennas", the frequency of operation and the
artifacts of current modulation flowing out on
the wires are all ingredients that go into
a recipe for problems.
The stuff that gets outside the product needs
to be evaluated for potential nuisance if not
hazard. This is part of what DO-160/Mil-STD-704
is about. In the case of the EV200, the occasional
OBAM aircraft builder has heard the duty cycle
switching of the EV200's control electronics as
a "buzz" in their audio system.
I've not been able to put my hands on one of these
problems to deduce the magnitude of potential noise
or track down the specific propagation path. However,
it's a pretty fair bet that poor grounding techniques
are the probable cause.
I wouldn't shy away from an EV200 installation
based on a reported noise issue. I've never found
a noise problem I couldn't fix. I've found problems
that the customer decided not to fix because it
involved $millions$ of design changes to an
airframe. But in our airplanes, the risk of noise
is low, the cost of the solution is not great.
In response to our List discussion late last week
on the ratings for the lowly el-cheeso contactors,
I've begun a design for a contactor power management
module. This device will be assembled much like the
over voltage modules . . . quasi-potted in double
walled heat shrink. It's easy to add this device
to an el-cheeso contactor and achieve improved
electrical performance that emulates the EV200.
At the same time, it separates control electronics
from the contactor. If the contactor ever requires
replacing, then you don't need to buy new electronics.
Similarly, if the electronics craps, you don't toss
out a perfectly good contactor. See:
http://www.aeroelectric.com/Catalog/AEC/9024/9024-700-1P1.pdf
I have an upcoming opportunity to get into the EMC
lab with a customer's product for DO-160 conducted
emissions testing. I'm planning to piggy-back a
couple of my projects into the same testing session.
If my software guru can get me some exemplar chips
for the 9024, I can do an EMC look-see to confirm
my confidence in its OBAM aircraft friendly demeanor.
This module will drastically reduce the temperature
rise on the RBM/W-R/Stancore contactors. This not only
reduces energy required to keep the critter closed,
it honors the manufacturer's ratings limits for
use in systems with bus voltages high enough to
charge batteries.
