slip-skid indicator
bressler(at)wyoming.com
PostPosted: Mon May 18, 2009 8:07 pm    Post subject: slip-skid indicator Reply with quote
Does anyone know if a peel-and-stick slip-skid indicator is on the market? Saw one once but can't remember where.
Wes & Lurlene Bressler; 601XL with Jabiru 3300; 90% done - 10% to go
arno7452(at)bellsouth.net
PostPosted: Tue May 19, 2009 4:47 am    Post subject: slip-skid indicator Reply with quote
Tape a short piece of string on your cowl. Best indicator there is.
Ken
a.s.elliott(at)cox.net
PostPosted: Tue May 19, 2009 5:07 am    Post subject: slip-skid indicator Reply with quote
I got mine from WalMart Aviation Supply Co., in the recreational vehicle aisle. Came in a package of 2 for <$10. It is a bubble type inclinometer, which is more sensitive than the regular aircraft ball. I trimmed the superfluous edge material and mounted it with double-stick foam tape. Works very nicely. Since it uses a floating bubble and has the curve of the tube in the opposite direction from a ball indicator, it does work opposite from a normal indicator. That is you step *away* from the bubble, not on it. The fluid is dyed vaguely fluorescent and the bubble is very easy to see.
I uploaded a picture of my panel to:
http://members.cox.net/n601ge/pix/panel_27Apr09.jpg
FWIW,
Andy Elliott, Mesa, AZ
N601GE,601XL/TD,Corvair
Gig Giacona
PostPosted: Tue May 19, 2009 5:23 am    Post subject: Re: slip-skid indicator Reply with quote
How many hours did you fly sideways before you figured that out? Smile
W.R. "Gig" Giacona
601XL Under Construction
kmccune
PostPosted: Tue May 19, 2009 2:17 pm    Post subject: Re: slip-skid indicator Reply with quote
Good one! Laughing
Kevin
History is a great teacher if you take time to study it.
Steve Bennett
