		bigglesusa
				 Posted: Tue May 19, 2009 8:31 am    Post subject: Window sealing YAK 18t |
				Can anybody please advise best method of sealing new windows in my YAK 18t?  I have tried the excellent Cessna sealing strip but it is too thick and prevents the fitting of the fixing plates.
 Thanks.
 BigglesUSA
  _________________ 'Le temps mange la vie' |
		Vic
  Joined: 12 Aug 2008 Posts: 116 Location: Southern Bavaria
				 Posted: Tue May 19, 2009 12:26 pm    Post subject: Re: Window sealing YAK 18t |
				Hello Biggles,
 we used clear silicone sealant on the windows .
                                                      Vic
		bigglesusa
				 Posted: Tue May 19, 2009 3:01 pm    Post subject: Re: Window sealing YAK 18t |
				Thanks Vic - ? just clear silicone, no tape or nothing ?  How about any preparation ?
 BigglesUSA
		dougsappllc(at)gmail.com Guest
				 Posted: Tue May 19, 2009 3:29 pm    Post subject: Window sealing YAK 18t |
				Yikes, silicone?  It has been my experience that your going to be pretty much screwed if you ever have to replace a section if it was installed with silicone.  The stuff just does too good of a job, it just wont let go!  You end up having to nearly destroy the frame to get the old piece out.
 Doug
 On Tue, May 19, 2009 at 4:01 PM, bigglesusa <thecookoos(at)gmail.com (thecookoos(at)gmail.com)> wrote:
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax 509-826-3644
		bigglesusa
				 Posted: Tue May 19, 2009 3:32 pm    Post subject: Re: Window sealing YAK 18t |
				What do you recommend Doug ?
 BigglesUSA
				 Posted: Tue May 19, 2009 4:21 pm    Post subject: Window sealing YAK 18t |
				I have never replaced the glass on a 18T, so don't cant speak to the problems or best methods for you.  For Nanchang canopies I use Cessna horizontal stabilizer leading edge tape from A/C Spruce.  It's a thick black tape seems to work well, never had a canopy leak.
 On Tue, May 19, 2009 at 4:32 PM, bigglesusa <thecookoos(at)gmail.com (thecookoos(at)gmail.com)> wrote:
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax 509-826-3644
				 Posted: Tue May 19, 2009 5:11 pm    Post subject: Window sealing YAK 18t |
				Excellent point Doug and I second your comments 100%.   I've seen the effects of someone using clear silicone sealant.  The front  window frame was almost destroyed while trying to remove the stuff from the  frame.
  Dennis
  [quote]   ---
		Vic
				 Posted: Tue May 19, 2009 5:14 pm    Post subject: Re: Window sealing YAK 18t |
				Hi Biggles,
 you may find places on the Yak where you´d like to have the tape a few millimeters thick, but mostly zero thickness would be fine. So you´d better find some metric sealing compound for the job on Russian aircraft like silicone. That way adjustments while fitting the windows are possible. With tapes you might fall into offensive language, but in some places tapes should do . When replacing windows one day, I guess you will need a cutter anyway to separate the window from the frame. Windshields on cars are glued as well, but I think this stuff is even tougher than clear silicone. I´d suggest you do a test elsewhere to find out what suits you best for this job.
   Vic
		N13472(at)aol.com Guest
				 Posted: Tue May 19, 2009 5:52 pm    Post subject: Window sealing YAK 18t |
				Another good tape to use is the 20 mil black pipe wrapping  tape. You can get it at Home Depot, Lowes, etc.
 Tom Elliott
 CJ-6A NX63727
 702-595-2680
  [quote]         From: owner-yak-list-server(at)matronics.com    [mailto:owner-yak-list-server(at)matronics.com] On Behalf Of doug    sapp
 Sent: Tuesday, May 19, 2009 5:20 PM
 To:    yak-list(at)matronics.com
 Subject: Re: Re: Window sealing YAK    18t
 Always Yakin,
 Doug Sapp
 Phone 509-826-4610
 Fax    509-826-3644
  	  | Quote: | 	 		  http://www.matronics.com/Navigator?Yak-List
 atronics.com
 //www.matronics.com/contribution
  | 	  [b]
