				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| ploucandco
				|  Posted: Sun May 24, 2009 8:21 am    Post subject: Monowheel Brake |   |
				| Hi all,
 I would like to hear your experience with the monowheel brake system. I purchased my Europa XS monowheel from the builder about 1 year ago (N205CN has its 1st flight on May 2006) and had all the issues that I could imagine with the brake system till now.
 After bleeding the master cylinder at least 5 times (leaks with air coming in), I decided to completely replace the whole system beginning of this year: master, slave and tube.
 Europa first sent me a leaking master cylinder that was replaced for free.
 So during the 20 hours that I flew after this replacement, I already got 2 times the tube to come out from the slave cylinder connection. Today I got the tube to come out of the master cylinder.
 I became a master in flushing the whole system and reconnecting everything as well as bleeding from the slave cylinder in less than 15 minutes. That's not the issue.
 But, this system is not acceptable from a safety point of view. Today, I got no brake at the end of the runway (400m concrete). Good that I stopped the engine and that there is 50 meters grass after the runway...
 2 months ago, I was doing the mag check at 3000RPM when I lost the brake! I luckily touched nothing but finished my course 2 meters from the hangar door.
 Am I the only one who is facing such issues with the monowheel brake?
 Potentially, do someone of you have a solution that enhance the safety of this system?
 Thanks for your input, Jacques.
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| ken carp
				|  Posted: Sun May 24, 2009 9:10 am    Post subject: Monowheel Brake |   |
				| Been flying with my brake system seven years and 525 hours without any problems.  sounds like your connections on the end of the tube are flawed is some way.
ken carpenter   N9XS  mono 914
 ken carpenter
		| Back to top |  |
		| rparigor(at)suffolk.lib.n Guest
				|  Posted: Sun May 24, 2009 10:38 am    Post subject: Monowheel Brake |   |
				| Hi Jacques
 I have a XS monowheel, but am not yet flying.
 I however did work on plumbing my brake system.
 I suspect that you may be using american sized brake tube instead of metric. It is so very close in size to metric, but I was not able to make a good seal, I inspected contact area (crushed seal) after tightening down and it was very marginal at best. American tubing is smaller in diameter compared to supplied metric.
 Another problem is that american pipe threads are oh so close to metric in diameter and pitch, but again not the same, so you can't just screw in place american fittings IMHO and use american diameter hose.
 I was unable to find metric brake hose in the states, I ordered the longer piece needed from Europa.
 Ron Paigoris
 Visit -  www.EuropaOwners.org
		| Back to top |  |
		| mikenjulie.parkin(at)btin Guest
				|  Posted: Sun May 24, 2009 10:59 am    Post subject: Monowheel Brake |   |
				| Jaques,
 I did away with the standard system and installed a calliper break master
 cylinder on the stick.  The calliper  was made in France by MDO, it is very
 powerful and brilliant to use.  One finger is all that is needed on the
 lever, it also has a built in parking break.  The only shortcoming of the
 system is that the brake is only available to the left-hand seat.  Not a
 problem for me, as apart from 2 notable exceptions (Ivan Shaw and Andy
 Draper) no one flies my baby apart from me.
 Do not archive.
		| Back to top |  |
		| ploucandco
				|  Posted: Sun May 24, 2009 11:46 am    Post subject: Re: Monowheel Brake |   |
				| Hi Ron, I am just using the tube that I got from Europa...
 Mike, do you have a phone number, a website or something like that?
 Other suggestions?
 Thanks, Jacques.
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Sun May 24, 2009 12:15 pm    Post subject: Monowheel Brake |   |
				| Hi Jacques,
 Like Ken, I have had very little trouble with my mono brake.  I noticed that you said it took 15 minutes to bleed your system and I was wondering if you had the brake bleeding kit that Europa sell.  It is a funnel that fits into the the hole in the master cylinder and I find that bleeding my brake system with this to be very fast and easy.
 Paul
		| Back to top |  |
				|  Posted: Sun May 24, 2009 3:22 pm    Post subject: Monowheel Brake |   |
				| Hi Jaques"Hi Ron, I am just using the tube that I got from Europa... "Measure diameter, it sure does sound like you have american size.If you need I will measure mine, but I think the metric was like 6 or 8 thosands larger in diameter than the american size. A standard piece of paper is ~ .0025".Ron Parigoris   [quote][b]
		| Back to top |  |
				|  Posted: Sun May 24, 2009 9:42 pm    Post subject: Monowheel Brake |   |
				| I lost the man's details when my old computer died.  I think he came from
Biarritz.  Perhaps one of our French readers could track him down.
 Mike.
		| Back to top |  |
		| justin(at)systemwise.co.u Guest
				|  Posted: Mon May 25, 2009 12:40 am    Post subject: Monowheel Brake |   |
				| Hi,
 I too have put my master cylinder on the control stick. I found that Mountain bike brake specialist “Hope” made a lever with integral master cylinder ideal for the job here in the UK. Mountain bikes are very light these days and this was a beautifully engineered part.
 I did look at the French one mentioned by Jacques but it was twice the weight of the Hope offering. The Hope offering has no parking brake and I find it a real nuisance not to have one.  In hindsight I would probably go for the French one which has an hydraulic shut off valve for the park brake.
 What I would say is that having a brake that can be operated by one finger on the stick is a huge advantage. The safest place to do the braking on my monowheel is just after touch down when there is still bags of elevator authority. At this point it is better to concentrate on flying the aeroplane than reaching out to operate a brake leaver on the far side of the tunnel. Along with Jacques I find the braking a lot more controllable too. The braking action more controllable too
 Just my pennyworth.
 Justin
 Justin Kennedy
 G-ZTED Europa Classic Monowheel
 912S Airmaster CP with Warp Drive blades.
		| Back to top |  |
		| h&jeuropa
				|  Posted: Mon May 25, 2009 2:05 am    Post subject: Re: Monowheel Brake |   |
				| Jacques,
 From my racing days I was suspect of using plastic tubing in a brake system and others were reporting leaks with the Europa supplied parts.  So, we replaced the hose with stainless steel braided hose and the matching fittings during the initial build.  Got all the parts from McMaster.  I can probably find the part numbers if you need them.
 Jim & Heather
 N241BW
		| Back to top |  |
		| fklein(at)orcasonline.com Guest
				|  Posted: Mon May 25, 2009 6:20 am    Post subject: Monowheel Brake |   |
				| Justin & Mike,
 I (for one) would be most interested in seeing a photo of your installations if you have one handy which you could post.
 Thanks...Fred
 On May 24, 2009, at 11:58 AM, Mike Parkin wrote:
 [quote] This message has been scanned for viruses and dangerous content by MailScanner, and is believed to be clean.   [quote][b]
		| Back to top |  |
		| ploucandco
				|  Posted: Mon May 25, 2009 6:46 am    Post subject: Re: Monowheel Brake |   |
				| Hi Jim,
 I am really interested in part numbers for these fittings. Well, what is unclear is how do you manage the fact that the brake calliper (slave) is moving with the wheel when retracting it. I would be surprised if the stainless steel braided hose is flexible enough. What kind of solution do you have there? A high pressure flexible hose for some part ?
 Thanks, Jacques.
		| Back to top |  |
		| ploucandco
				|  Posted: Mon May 25, 2009 7:02 am    Post subject: Re: Monowheel Brake |   |
				| Hi Jim,
 Is http://www.mcmaster.com/#braided-hose/=210iuu the kind of tube that you are using? Thne it is clear that it is flexible.
 Thanks, Jacques.
		| Back to top |  |
		| h&jeuropa
				|  Posted: Tue May 26, 2009 3:49 am    Post subject: Re: Monowheel Brake |   |
				| Jacques,
 Yes, it is similar.  I think I actually used the hose on page 248 P/N 52515K22.
 I used the same hose, larger diameter for the oil return from the bottom of the Rotax to the oil tank.
 I'll dig thru the old receipts today and get you the P/N.
 Jim
		| Back to top |  |
				|  Posted: Tue May 26, 2009 8:12 am    Post subject: Monowheel Brake |   |
				| Hi Jim
 When you used McMaster hose, I imagine you used the american fittings they sell.
 Did you do anything special when you screwed them into the metric pipe threads? Sealant? Retapped?
 Thx.
 Ron Parigoris
		| Back to top |  |
		| terrys(at)cisco.com Guest
				|  Posted: Tue May 26, 2009 9:10 am    Post subject: Monowheel Brake |   |
				| Hi Ron,
 We also used American fittings to allow the use of stainless braided
 brake lines from Summit Racing.  We used an American standards pipe
 thread tap to clean out the threads on the master and slave cylinders,
 making sure not to get shavings into the parts.  This has been very
 reliable for 8 years now.
 Terry Seaver
 A135 / N135TD
		| Back to top |  |
		| h&jeuropa
				|  Posted: Wed May 27, 2009 6:24 pm    Post subject: Re: Monowheel Brake |   |
				| Jacques & Ron,
 I have the receipt from McMaster.  I used 52515K21 hose, 52515K41 fittings for end of hose and 50695K181 elbows into the brake caliper and master cylinder.  Per Terry's note above, I cleaned the threads with a 1/8" NPT tap.  Did not use any sealant.  Has worked fine for 100 hrs, 2 years.
 Jim
		| Back to top |  |
		| ploucandco
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
