spark plug gapping (new questions)
skidmk
PostPosted: Mon May 25, 2009 8:40 am    Post subject: spark plug gapping (new questions) Reply with quote
HI all,,
changed my plugs at the annual this year (chinese to chinese) and we now have a vibration at high rpms.
In keeping with the previous discussion of vibration, I'd like to check the gaps.
I know the gap specs (from the book), but what massive electrode tool would I use to fix them if they are out?
I've looked at ATS and aircraft spruce for a gapper, but they are all 18mm?
thanks
Mike
Mike "Skidmk" Bourget
Ottawa, Ontario
dougsappllc(at)gmail.com
PostPosted: Mon May 25, 2009 9:46 am    Post subject: spark plug gapping (new questions) Reply with quote
Mike,In every can of Chinese DZ5 plugs there are 10 plugs, copper gasket/seals and a gapping tool, this is a go/no go "feeler gauge" type tool.  No need to buy any special tools.
Always Yakin,
Doug
On Mon, May 25, 2009 at 9:40 AM, skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
--> Yak-List message posted by: "skidmk" <skidmk(at)gmail.com (skidmk(at)gmail.com)>
HI all,,
thanks
Mike
Mike &quot;Skidmk&quot; Bourget
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=245274#245274
rget="_blank">http://www.matronics.com/Navigator?Yak-List
le, List Admin.
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
dsavarese0812(at)bellsout
I'm pretty sure if you buy 20 Chinese spark plugs from Doug, the sealed container with the plugs has a neat little gapping tool in it. Check with Doug to see if this gapping tool is available separately.
Dennis
skidmk
PostPosted: Mon May 25, 2009 10:38 am    Post subject: Re: spark plug gapping (new questions) Reply with quote
Hi guys,,
yes the go no go tool is there. I'm not terribly familiar with its use (used to gappers), and as such didn't want to risk bending/breaking an electrode/other.
I understand the gap tool slides down next to the electrode to test the gap,and it should be tight, but easily slide up and down. However if there are instances where the gap is too tight, can the tool be used to bend the plug back?
M
Ottawa, Ontario
PostPosted: Mon May 25, 2009 11:11 am    Post subject: spark plug gapping (new questions) Reply with quote
If it is too tight just tap it in and it will set the correct gap.
Doug
On Mon, May 25, 2009 at 11:38 AM, skidmk <skidmk(at)gmail.com (skidmk(at)gmail.com)> wrote:
Hi guys,,
M
Ottawa, Ontario
http://forums.matronics.com/viewtopic.php?p=245296#245296
le, List Admin.
Always Yakin,
Doug Sapp
Phone 509-826-4610
Fax 509-826-3644
skidmk
PostPosted: Mon May 25, 2009 4:01 pm    Post subject: Re: spark plug gapping (new questions) Reply with quote
yep did that, what if its too loose?
Ottawa, Ontario
wlannon(at)persona.ca
PostPosted: Mon May 25, 2009 7:37 pm    Post subject: spark plug gapping (new questions) Reply with quote
Doug & Mike:
NO!!!
That is not a gapping tool. It is simply a gauge. Do not attempt to change
the gap by applying any pressure to the center electrode. This can crack the
porcelain insulator.
Walt
skidmk
PostPosted: Tue May 26, 2009 6:36 am    Post subject: Re: spark plug gapping (new questions) Reply with quote
Walt is there a gapping tool you can recommend?
Mike
Ottawa, Ontario
Nanchang CJ6
PostPosted: Sun May 31, 2009 12:59 am    Post subject: Re: spark plug gapping (new questions) Reply with quote
Hi! We are specialized in Nanchang CJ6 aircraft parts.And we have some stocks about DZ-5 spark plugs.If you are interested in it,pls feel free to contact me!My msn is lcdzkj(at)live.cn.
Sarah:86-13468610692
View user's profile Send private message Send e-mail Visit poster's website Yahoo Messenger MSN Messenger
