Rivet length with .125 angle on 701
rvickski(at)yahoo.com
PostPosted: Wed May 20, 2009 11:54 am    Post subject: Rivet length with .125 angle on 701 Reply with quote
I upped the ad5-6 to ad5-7, the avex I left the same. Spar web .025, +Cap .125 =grip lenght .150. + .156 rivet dia x 1.5= .234+.150=.384 which is a touch short for a -6 rivet. When riveting I didn't pay so much attention to the height as long as the shop head was 1.5 times the rivet starting diameter. The cabin sides are .032 material and the -6 is way too short.
Aircraft Sheet Metal by Jeppesen and AC43-13B are both good reference and procedure books.
Roy Szarafinski
roysgarage.com
701 etc.
PostPosted: Wed May 20, 2009 1:22 pm    Post subject: Rivet length with .125 angle on 701 Reply with quote
I should have said .384 is a touch LONG for a -6 rivet. The .040 strut/web spar doubler makes the 7/16 long rivet near perfect length.
Roy
JohnDRead(at)aol.com
PostPosted: Wed May 20, 2009 3:11 pm    Post subject: Rivet length with .125 angle on 701 Reply with quote
Zenith construction standards will also give the added length required for a given rivet diameter. do not archive.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 5/20/2009 1:54:44 P.M. Mountain Daylight Time, rvickski(at)yahoo.com writes:
--> Zenith701801-List message posted by: Roy Szarafinski <rvickski(at)yahoo.com>
Roy Szarafinski
roysgarage.com
701 etc.
----- Original Message ----
To: zenith701801-list(at)matronics.com
Sent: Wednesday, May 20, 2009 3:08:00 PM
Subject: Re: From 2003 and Mark T
--> Zenith701801-List message posted by: "kmccune" <kmccune(at)somtel.net>
Out of curiosity, those who have used the .125" wall angle, did you used teh standard ================================================
Dell Inspiron 15 Laptop: Now in 6 vibrant colors! Shop Dell's full line of laptops.
kmccune
PostPosted: Thu May 21, 2009 3:38 am    Post subject: Re: Rivet length with .125 angle on 701 Reply with quote
Thanks for the help guys.
Kevin
R.W. Emerson (1803-1882)
Dorothy McCune
zodierocket(at)hsfx.ca
PostPosted: Tue May 26, 2009 5:45 am    Post subject: Rivet length with .125 angle on 701 Reply with quote
Mark Townsend
Can-Zac Aviation Ltd.
519-590-7601 www.canzac.ca
Canadian Dealer for Zenith Aircraft Kits, Zenair Designs.
Can-Zac_Aviation_Ltd._(president@can-zacaviation.com).vcf
 Filename:  Can-Zac_Aviation_Ltd._(president@can-zacaviation.com).vcf
 Filesize:  195 Bytes
 Downloaded:  396 Time(s)
kmccune
PostPosted: Tue May 26, 2009 2:17 pm    Post subject: Re: Rivet length with .125 angle on 701 Reply with quote
Mark,
Kevin
Dorothy McCune
