		flyboy3847(at)onecommail. Guest
				 Posted: Tue May 26, 2009 5:42 am    Post subject: Zenith601-List Digest: 1 Msgs - 05/19/09 |
				I just completed my 601 HD and when it was time to attach the canopy to the
 frame I called the manufacturer to see what they thought was the best way.
 They were firm in their belief that you should use an AN3 bolt through the
 canopy and all the way through the frame.  The canopy should be drilled to
 accept a 3/16" grommet and a nylock nut on the other end.  That way the
 force can be controlled and the canopy will stay on and not crack.
 Leroy Wheeler
  |  | - The Matronics Zenith601-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		jaybannist(at)cs.com Guest
				 Posted: Tue May 26, 2009 7:08 am    Post subject: Zenith601-List Digest: 1 Msgs - 05/19/09 |
				Leroy,
  What manufacturer did you call ?
  Zenith provides # 6 screws (NAS548P6-10), which are to be installed in holes drilled with a #40 drill bit .  That hole is roughly half the size of a hole for an AN3 bolt.  The hole for the # 6 screw is only through one side of the tube frame.  Drilling a 3/16" hole through both sides of the tube takes away 4 times as much material as for a # 6 screw.  A # 40 hole reduces the cross sectional area of the tube by 4.37%.  Two 3/16" holes reduce it by x 17.25%.  It seems to me that is a significant reduction in strength of the tube frame. That is why I am asking.
  Jay Bannister
           	  | Quote: | 	 		  --> Zenith601-List message posted by: "Leroy Wheeler" <flyboy3847(at)onecommail.com (flyboy3847(at)onecommail.com)>
 Leroy Wheeler
       Email message sent from CompuServe - visit us today at http://www.cs.com
				 Posted: Tue May 26, 2009 7:55 am    Post subject: Zenith601-List Digest: 1 Msgs - 05/19/09 |
				I think it was Aero Plastics.  We bought it direct from Zenith.  It was whomever they use.
 Leroy
 From: owner-zenith601-list-server(at)matronics.com [mailto:owner-zenith601-list-server(at)matronics.com] On Behalf Of jaybannist(at)cs.com
  Sent: Tuesday, May 26, 2009 10:56 AM
  Subject: Re: RE: Zenith601-List Digest: 1 Msgs - 05/19/09
 Leroy,
  Jay Bannister
  Leroy Wheeler
        size=2 width="100%" align=center>
    	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?Zenith601-List  | 	  0123456789
      date.
  Checked by AVG - www.avg.com
  05/14/09 17:54:00
		Gig Giacona
				 Posted: Tue May 26, 2009 10:17 am    Post subject: Re: Canopy Installation |
				I would strongly suggest you look at the Zenith construction manual.
 Here's a link. http://www.zenithair.com/zodiac/xl/data/6-c-4.pdf
 While Aero Plastics may know about the canopy they built they aren't experts on installing it as directed by Zenith.
601XL Under Construction
				 Posted: Wed May 27, 2009 6:14 am    Post subject: Zenith601-List Digest: 1 Msgs - 05/19/09 |
				I'll let you know how it works out.
