Pilot Proficiency vs RV10 'flyability'
Goto page 1, 2  Next
Deems Davis
PostPosted: Tue May 26, 2009 6:45 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Slightly Off Topic: Portable intercom and Flight Training
I've been watching this thread and biting my tongue a bit. It seems that
we are mixing 2 issues.
1. Pilot proficiency or lack there of. 2. How hard/easy to fly is the
RV10. I'm probably going to get thumped for what I'm about to say, but I
think that the RV10 is a relatively easy airplane to fly. Now I say that
based on my experience which is different from others. I'm not a hot
stick, and if you witnessed my landing Sat you would quickly agree.
Since the RV10 has a higher HP and a constant speed prop, it does have
some inherent complexity that trainer aircraft do not have. And learning
these skills will decidedly add to the learning curve for a new or lower
time pilot. But transitioning from a trainer to a complex high
performance aircraft doesn't (shouldn't) double the amount of training /
learning. Additionally I think there is something to be said for the
learning advantage that accrues from flying the same aircraft flight
after flight. The biggest variable in the learning to fly equation is
the capability and mindset of the individual. As individuals we all vary
widely and I encourage everyone to be honest and conservative in our
individual self assessments about our abilities and our respect for all
of the unexpected things that can happen in aviation. Commercial
aviation has proven statistically that re currency for even the most
experienced aviator pays high dividends in safety. I just don't want
people to be unnecessarily scared or worried about the RV10. As a point
of reference, I've recently flown a couple of local friends RV7's which
have flight characteristics which are IMO much more sensitive/critical
than the RV10. Yet there are many people that transition successfully
into RV6, 7's and 8's with relatively low time.
I maintain the RV10 is an easy airplane to fly. Flying it or any other
aircraft well, and flying them safely is a matter of pilot capability
and proficiency.
Deems Davis
N519PJ 28 hrs of 'expert' opinion
deej(at)deej.net
PostPosted: Tue May 26, 2009 7:08 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
after flight.
Hi Deems,
I agree with your thoughts. It took me about 10 hours of dual to
transition from a Cessna 150 to a Glasair 1 FT, and at the time I had
about 200 hours in only Cessna aircraft. At 10 hours I certainly didn't
feel like an expert, but I felt that I could fly the plane safely. I
don't have very much time in a -10, but the little I do have felt like
the -10 flies somewhat like a Glasair, only not as quick and sensitive
(ie, the -10 is little easier). The Glasair is closer to a -7.
As long as a pilot gets the proper dual training until they feel safe,
and not put a time limit on it, I think they'd do fine in a -10.
-Dj
dlm46007(at)cox.net
PostPosted: Tue May 26, 2009 7:37 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
I think you might have added "pilot judgment". Many of the problems that
have occurred within the RV10 community are judgment related. I won't rehash
the details of previous lapse of RV10 judgment but given enough flight time
and experience, the RV10 is a delight to fly. Each time I fly my Glastar I
think I am back in a car without power steering. Judgment is hard to teach.
The crash in AZ last Saturday night was a case in point. The aircraft was
single engine and operating IIRC in marginal conditions at midnight over
mountainous northern AZ. The moon was not visible. The odds of a favorable
outcome if anything goes wrong are small. A superior pilot once said that he
used his superior judgment in order to avoid having to demonstrate his
superior skill. As more 10s fly, take the time to acquire the necessary
skills to fly it "right". If you want an interesting exercise look each day
at the experimental NTSB summary of accidents as OSH approaches. For each
accident look to see whether that is a new flight test phase aircraft or
not. You will find many are or are aircraft of priors years where the pilot
may be trying to get proficient to fly to OSH. Evaluate the risks and fly
safe.
Tim Olson
PostPosted: Tue May 26, 2009 8:06 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Don't get me wrong, I'm not on an extreme as far as I'm concerned.
I think that the -10 is very easy to fly, if you stay ahead of it.
ANY airplane that you don't stay ahead of is hard to fly. So for
me I'm not saying that you need "double" the training or anything
like that. In an ideal world, flying would be cheap and everyone
could quickly go out and put on 250 hours of time. But it won't
work that way for most people. I just think that there are so many
things that those of us who have gained some experience end up
forgetting and taking for granted. Things that we don't remember
anymore, but at the time it was a real challenge, so a pilot
should get good instruction, get extra instruction for a slippery
and high performance plane, but also fly it conservatively for a
good amount of time too. Dj, you noted that you had 200 hours
in only Cessnas. That's HUGE. Certainly with that amount of time
you gained a lot of skill and experience. So no, transitioning
to the -10, for a current pilot, I wouldn't think would be tough
at all at that point. I think under 100 hours it would get tougher
and tougher as you get lower in time. A lot of it again has to
do with how compact that timeframe is too. 200 hours over 2 years
is a lot of flying. Someone who does that will have an easier
time than someone with 75 hours over 5 years of flying. And, of course,
there are those who will just be quicker or slower to adapt than
others. The RV-6/7/8 are all definitely a notch above ours for
how sensitive they would be to transition to. So no, I think the
-10 is really easy to fly, myself. For me I transitioned right from
a "Slowdowner" (with some 182RG and Sierra retract time) with no
problem, and I probably could have easily from any point after my
first 150 hours. I probably still took a bunch of benefit from all
those hours beyond that point that I had...but the benefits
were less. My main point was that the -10 probably wasn't the best
TRAINER plane for people. Once you gather time and experience, it's
definitely not one to fear.
Tim Olson - RV-10 N104CD
> after flight.
Hi Deems,
-Dj
Dick Sipp
PostPosted: Tue May 26, 2009 9:04 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Deems:
I think your opinion is spot on. This has been a great thread and deserves
to continue. There are many more folk's thoughts out there that would add a
lot to the conversation. Vic S.?
I had 750 hours in an RV4 and 13,000 in transport/military aircraft and
would not have considered flying the 10 without some dual before the first
flight.
(flew 3 hours with Jerry VanGrunsven). As you say the 10 is not a difficult
airplane at all to fly well, but with all the training resources
available now, why would one not want to become at least familiar with the
type before flying one on the first flight. The first flight in an airplane
you built is not the time to be doing self instructed transition training.
A few hours, at least, in a relaxed training environment will pay huge
benefits
in the early flights in our own new airplane. Throughout commercial
aviation, formal training in a new type is required regardless of previous
experience.
If the 10, like the other RVs, have a fault it is that they fly so well, are
so responsive, they quickly build the self confidence of their pilots,
perhaps too much so.
The sports models all beg to rolled, looped, flown in formation, etc - Total
Performance - right? My guess would be that most 10 pilots value the
productivity of their 4 place efficient cross country SUV. Most 10s are
well equipped for IFR, beg to cover a lot of ground through changing weather
patterns, and often carry one or more family or friends.
I find my mental attitude to be very differnent in this environment than it
was by myself in the 4. Satisfaction now comes from providing a comfortable
travel experience for the passengers while continually refining flight
procedures to get the most out of that expensive instrument panel. With 130
hours I am still learning how to get the most out of myself, the avionics,
and the airplane. The process of trying to continually improve will provide
satisfaction for a long time to come.
We all take pride in deciding to become part of the most successful
experimental aircraft line ever. As the fleet and flight hours set new
records every day we as a group become more and more visable. Our record
and reputation is good but can always be improved. The past few days have
been costly to the family and deserve renewed commitment to safety.
Can a wife or any other women fly the 10? Of course. If they can fly
F-15s, catch the third wire on carrier in an F-18, or qualify for the
Thunderbirds, the 10, after good training, will be a walk in the park.
Dick Sipp
N110DV
jesse(at)saintaviation.co
PostPosted: Wed May 27, 2009 3:50 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
This has come up more than in this e-mail. You mention the 13,000 in
transport/military aircraft. We just sold a Cessna 206 to an airline
pilot with 27,000+ hours, mostly in regional jets in the last 20
years. He had a lot of cessna time, but hasn't been in one in 20
years. It would have been a huge mistake to assume that he could just
hop in and fly it. He would have killed himself. His first landings
(or attempts, I should say), were horrible. He is used to something
FAR different. All this to say, that even if you are a high-time
pilot, getting some transition training (at least in a similar
aircraft, but preferrably in the -10 itself) is critical. It is
nothing to be afraid of, but rather to be respected.
Jesse Saint
Saint Aviation, Inc.
jesse(at)saintaviation.com
Cell: 352-427-0285
Fax: 815-377-3694
On May 27, 2009, at 1:02 AM, richard sipp wrote:
Deems:
deserves to continue. There are many more folk's thoughts out there
that would add a lot to the conversation. Vic S.?
and would not have considered flying the 10 without some dual before
the first flight.
difficult airplane at all to fly well, but with all the training
resources
with the type before flying one on the first flight. The first
flight in an airplane you built is not the time to be doing self
instructed transition training. A few hours, at least, in a relaxed
training environment will pay huge benefits
previous experience.
well, are so responsive, they quickly build the self confidence of
their pilots, perhaps too much so.
- Total Performance - right? My guess would be that most 10 pilots
value the productivity of their 4 place efficient cross country
SUV. Most 10s are well equipped for IFR, beg to cover a lot of
ground through changing weather patterns, and often carry one or
than it was by myself in the 4. Satisfaction now comes from
providing a comfortable travel experience for the passengers while
continually refining flight procedures to get the most out of that
expensive instrument panel. With 130 hours I am still learning how
to get the most out of myself, the avionics, and the airplane. The
process of trying to continually improve will provide satisfaction
new records every day we as a group become more and more visable.
Our record and reputation is good but can always be improved. The
past few days have been costly to the family and deserve renewed
fly F-15s, catch the third wire on carrier in an F-18, or qualify
for the Thunderbirds, the 10, after good training, will be a walk in
the park.
Dick Sipp
N110DV
partner14
PostPosted: Wed May 27, 2009 4:34 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Thanks to all of you for taking the time to express and explain your thoughts and feelings to all of us. Yes, our family is growing and we all need to work together to keep our reputation at the highest possible level. We have lost 7 individuals in the Sacramento area within my 2.5 years of build time.... a little concerning to me as a newcomer to aviation. (only 1 was an RV) BUT, each and every one involved experienced pilots, most of which were making serious, stupid mistakes. What would have me concerned is individuals being killed and the crash was NOT, at least to some extent, pilot error. Flying into bad weather, overloading the plane at the same time the density altitude was at it's max, engine out on takeoff, with fire, and trying to turn back to the airport, fuel pump and boost pump malfunctions at the same time, flying into the side of a mountain, and what may have been a heart attack..... with the exception of the last, these possibly were all avoidable. The worst being the 10,000 hour pilot overloading the plane and taking off with a high density altitude, from his home airport, and killing his 2 best friends. It seems that maybe the most vulnerable are the pilots that accumulate 150 to 250 hours, and then let their guard down. Maybe all this is similar to a motorcycle rider.� The new guy is overly cautious (unless he's under 20), and then once they get a little experience they push the envelope further and further, until their on the edge, and something out of the ordinary gets them. For us that could be weather, equipment failure, another aircraft, or terrain. ok, that's my 3 cents.
Thanks again guys...... and by the way, congrats to our new RV10 guys completing their first flights!!!!!
Don McDonald
#40636 Done, but sailing on the east coast.
--- On Tue, 5/26/09, richard sipp <rsipp(at)earthlink.net> wrote:
Subject: Re: Pilot Proficiency vs RV10 'flyability'
Date: Tuesday, May 26, 2009, 10:02 PM
--> RV10-List message posted by: "richard sipp" <rsipp(at)earthlink.net>
Deems:
I think your opinion is spot on.� This has been a great thread and deserves to continue. There are many more folk's thoughts out there that would add a lot to the conversation. Vic S.?
I had 750 hours in an RV4 and 13,000 in transport/military aircraft and would not have considered flying the 10 without some dual before the first flight.
(flew 3 hours with Jerry VanGrunsven). As you say the 10 is not a difficult airplane at all to fly well, but with all the training resources
available now, why would one not want to become at least familiar with the type before flying one on the first flight.� The first flight in an airplane you built is not the time to be doing self instructed transition training. A few hours, at least, in a relaxed training environment will pay huge benefits
in the early flights in our own new airplane. Throughout commercial aviation, formal training in a new type is required regardless of previous experience.
If the 10, like the other RVs, have a fault it is that they fly so well, are so responsive, they quickly build the self confidence of their pilots, perhaps too much so.
The sports models all beg to rolled, looped, flown in formation, etc - Total Performance - right? My guess would be that most 10 pilots value the productivity of their 4 place efficient cross country SUV. Most 10s are well equipped for IFR, beg to cover a lot of ground through changing weather patterns, and often carry one or more family or friends.
I find my mental attitude to be very differnent in this environment than it was by myself in the 4. Satisfaction now comes from providing a comfortable travel experience for the passengers while continually refining flight procedures to get the most out of that expensive instrument panel.� With 130 hours I am still learning how to get the most out of myself, the avionics, and the airplane. The process of trying to continually improve will provide satisfaction for a long time to come.
We all take pride in deciding to become part of the most successful experimental aircraft line ever. As the fleet and flight hours set new records every day we as a group become more and more visable. Our record and reputation is good but can always be improved. The past few days have been costly to the family and deserve renewed commitment to safety.
Can a wife or any other women fly the 10? Of course. If they can fly F-15s, catch the third wire on carrier in an F-18, or qualify for the Thunderbirds, the 10, after good training, will be a walk in the park.
Dget="_blank" href="http://www.matronics.com/Navigator?RV10-List">http:/llow" target="_blank" href="http://forums.matronics.com">http://forums.sp; - List Contribution Web Sbsp; > http://www.matronics.com/co=================
Don A. McDonald
40636
pitts_pilot(at)bellsouth.
PostPosted: Wed May 27, 2009 5:22 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Don makes some very good observations here, and I'd like to comment
(yeah, I couldn't resist) and put some perspective here.
level.
This is very important ..... especially when we're an emerging 'class'
and scrutinized by the insurance companies. Less than a professional
approach means we pay, and pay, and pay.
Very, very seldom is the blame for an accident ever placed on the
airplane. At least until the Lawyers get involved! I've had three
'failures' ..... two that resulted in off-field landings. All three can
be attributed to poor performance by people ..... and not pilot error.
All three were attributable to poor performance by maintenance personnel
.... in my case two were really my fault because I hold the repairmans
certificate for my Pitts, which is now 28 years old.
best friends.
The same scenario figured in my second loss of close friends.
all this is similar to a motorcycle rider. The new guy is overly
Well, I have to admit that exuberance and youth played a great part when
I was a baby pilot. My AA-1B (little Grumman trainer)was my first
aerobatic airplane ..... and if I hadn't built the Pitts probably would
have cut my flying time short and become a statistic.
There are a lot of sayings that come to mind ..... 'we don't have time
to make all the mistakes ourselves so learn from others' ...... and the
'old, bold, pilot' to name a couple. I have my own .... 'An old pilot
is one that survives all his (or her) stupid mistakes.' I've surely
made my share. I'm a little (well, a lot)older, a little wiser, and try
hard to mentor others as they follow the path to aviation bliss. I am a
survivor!
that's my 3 cents.
Inflation again!!!
I'll second that!!! It's been years since I first flew the Pitts, but
the excitement and every second of the flight is indelibly etched in my
mind.
Be safe out there!!!
Linn
Don McDonald
Tim Olson
PostPosted: Wed May 27, 2009 5:56 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Dick, that was a great post, and it's wonderful that you have
such a good attitude. I find that one of the most impressive
qualities of a pilot is when they have the humility to
admit that they have to approach things with a proper cautious
attitude despite their high hours. There are people who
go both ways. When we leased that Cherokee, I *insisted* on
a checkout before we took it, because in 450+ hours I
hadn't flown slow, yoke equipped, underpowered planes. They're
different...not hard, but different than what I was used to.
Then, there's my dad. He's not maintained anywhere near 25
hours a year for the past years since we sold the plane we
owned together. He also had only about 10 hours in a Cherokee
140, and maybe in the 20's in all piper models. But, he
walked into the place to pick it up thinking that he shouldn't
have to worry about a checkout at all. Probably has less
than 10 or 15 hours in 12 or more months. I was not
impressed with the attitude. Some people for some reason,
want to look at training as an obligation, and a sign that
they somehow aren't adequate. Some people look at it as
an opportunity, and love to just have the chance to get
in that seat and see if they can improve themselves. It's
a stark difference, and I'm guilty of viewing it both ways
in the past myself. But, I guess I did enough stupid things
along the way that I was able to convince myself I didn't
know everything. Wink
richard sipp wrote:
Deems:
first flight.
the type before flying one on the first flight. The first flight in an
instrument panel. With 130 hours I am still learning how to get the
to come.
safety.
Dick Sipp
N110DV
deej(at)deej.net
PostPosted: Wed May 27, 2009 7:30 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
On 05/27/2009 09:17 AM, linn wrote:
My AA-1B (little Grumman trainer)was my first aerobatic airplane .....
and if I hadn't built the Pitts probably would have cut my flying time
Hi Linn,
Given that I'm going to look at a 1969 AA-1A this weekend, I'm
curious. Can you elaborate on that a bit?
-Dj
Strasnuts
PostPosted: Wed May 27, 2009 8:31 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
I have about 4500 hours and in the last five years it has all been Citation single pilot time. I hopped in Scott Schmidt's great RV-10 and was suprised how behind I was in the airplane. I will be taking my time transitioning into the slower airplane. It is funny how I thought it would have been easier for me to fly the slower airplane. The flying part wasn't hard, it was the systems and the scan that was the most difficult, which makes the flying harder. I can see how you can get behind the "flying part" by trying to figure the systems out. Hopefully I will get more transition time by the time my RV-10 is done.(hint hint Scott).
RV-10 SB N801VR Flying
780 Hours
SuperSTOL 60 hours
dlm46007(at)cox.net
PostPosted: Wed May 27, 2009 9:02 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
The TR2 was known as the widow maker in the flight instruction world. Talk
to Andy Elliott ; he owned one for years. I will provide contact info
offlist if desired.
deej(at)deej.net
PostPosted: Wed May 27, 2009 10:35 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Would that be the same as having a student learn in an RV-10, or are
there inherent problems with the design of the Grumman Yankee AA-1? I
had not heard of this phrase being used in conjunction with the Yankee
until now.
-Dj
speckter(at)comcast.net
PostPosted: Wed May 27, 2009 11:20 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Do not discount how helpful it is to just sit in your AC and work with the avionics/EFIS’s. Many hours in this type of (hanger flying) helps with the scan and knobology. Close your eyes and reach for what you want and practice until you can do it successfully. Garmin has a wonderful simulator for their 900X that helps with the procedures. Do others have this simulator too? It is time well spent.
Gary Specketer
40274 Flying
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Seano
Sent: Wednesday, May 27, 2009 11:28 AM
PostPosted: Wed May 27, 2009 11:22 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
The reputation is that it has a nasty spin that is not recoverable. I had a
AA5 and loved it but was always wary of getting to slow.
Gary Specketer
40274 Flying
deej(at)deej.net
PostPosted: Wed May 27, 2009 11:39 am    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Interesting! I had someone else tell me that about Piper Tomahawks,
but said the Yankee was fine. The cautions about the Yankee have been
about not overloading it, and trying to take off on a hot day with
obstacles at a short runway. It tends to like the runway more than the
other airplanes of its class from the same time frame, but it is also 10
knots faster in cruise.
-Dj
dlm46007(at)cox.net
PostPosted: Wed May 27, 2009 12:36 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Perhaps Andy will reply to the list. IIRC the problem was high approach and
landing speeds and high sink rates when speeds got slower than 90 mph. My
only experience with Grumman has been AA-5. Both have castoring hose wheels
like the RVs. The AA-5 with 150HP and cruise prop was not a good climber.
deej(at)deej.net
PostPosted: Wed May 27, 2009 12:59 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Thanks, David. My impression so far has been that the AA1 Yankee
had similar characteristics to the Glasair 1 FT that I had, but having
not yet flown one, I'm still researching as much as possible. I've put
out a query on a Grumman mailing list to see what people there might
have to say (more appropriate than on this list).
I do appreciate the input!
-Dj
jim(at)CombsFive.Com
PostPosted: Wed May 27, 2009 2:01 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
A few more thoughts.First I don't think gender has anything to do with flying the -10. There are no physical requirements that would make men any better or worse than women at flying this airplane. I have found that I fly the airplane with my fingertips. No need to grip the stick and yank it around. I have flown with pilots who could not keep it level and I noticed they were gripping the stick. Just not needed. It's an airplane with lots of power but no surprises. Stalls are announced with plenty of feedback. Both of which make it a good honest airplane. That doesn't mean it should not be respected. What I have learned is the -10 reacts big time to ground affect. For that reason take-offs result is a departure from the runway followed by a short transition of acceleration in ground affect before climbing. Landings when done at the correct airspeed result in some pretty sweet touchdowns. It's not a Cessna (thank YOU!) and it should not be flown like one.I consider myself a low time pilot and did seek transition training. I had never flown an RV at all prior to my transition training. Nor had I flown behind a constant speed prop. But I did get to the point where I am enjoying the flying. I don't actually recall any bad experiences in my short 40 hours. I currently have 212 total time, 40 hours in type and 72 landings in type. While I still consider myself a low time pilot, I consider the -10 to be the best airplane I have ever flown. I do tend to make my patterns larger because of the speed. But nothing compares to the ride.Like riding a motorcyle, treat it with respect, live long and prosper!Thanks, Jim Combs40192 (N312F) - FlyingDo Not Archive [quote][b]
deej(at)deej.net
PostPosted: Wed May 27, 2009 5:00 pm    Post subject: Pilot Proficiency vs RV10 'flyability' Reply with quote
Don't know if anyone on this list cares, but thought I'd follow up with
input I got from the Grumman list:
"The AA-1 will recover, if you apply standard spin
recover technique immediately. It only becomes dangerous after 2-3
turns. This really shouldn't be an issue, as the plane doesn't really
have any bad stall characteristics and will only spin if pushed,
however, spins are prohibited. "
"The NASA tests involved a modified Yankee forced into very
aggravated spins of more than three turns. And yes, they had to use the
spin chute (a drag chute on the tail, not anything like the BRS on the
Cirrus) to recover from a lot of those spins. However, a stock Yankee
passed all the normal and utility category spin tests for an aircraft
with a "No Intentional Spins" limitations. In those spins, the aircraft
was only put into an incipient spin -- three seconds or one full turn,
whichever was longer. If you start into a spin, and use the book
recovery procedure, it will recover promptly. But you did get the right
idea -- don't let it spin. When doing stalls/slow flight, keep the ball
centered and the nose from yawing."
More than one mentioned that with my Glasair time, the AA-1 should be
an easy transition. In the spirit of the actual topic of this thread,
yes, if I buy it I will be going up with an experienced Grumman CFI
until I feel comfortable... Smile
-Dj
Goto page 1, 2  Next
Page 1 of 2
