Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
airvair601(at)yahoo.com Guest
Posted: Wed May 27, 2009 7:29 am Post subject: panel access modicaton location |
Normal 0 false false false MicrosoftInternetExplorer4 <![endif]--> <![endif]--> /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} <![endif]-->
We are trying to find dimensions for the placement of the
instrument panel access modifications pictured in the link below.
ZAC has blessed this modification. We would like the entire access port to be within the canopy bubble. We have a forward
tilting canopy on a HDS.
We would like to make the access port and the
panel cover before unrolling and fitting the bubble.
Can anyone help us with dimensions to place this access cover within the bubble?
Thanks phill
http://www.ch601.org/resources/zodiac%20updates/behind_the_panel_access.htm
carlossa52(at)gmail.com Guest
Posted: Wed May 27, 2009 7:43 am Post subject: panel access modicaton location |
Phil, I plan on doing that myself, and would appreciate if you could share any/all info on it.
Cheers
Carlos
CH601-HD, plans
2009/5/27 601corvair <airvair601(at)yahoo.com (airvair601(at)yahoo.com)>
Thanks phill
Posted: Wed May 27, 2009 8:32 am Post subject: panel access modicaton location |
Phill,
It's not too far a jump to making the forward top skin a removable
component. It's easier to get at everything and less expensive than
investing in a lot of
nut plates too. If you need more information on doing this, just ask and
I will do what I can to help you get it done and source the correct
hardware.
See links,
http://www.macsmachine.com/images/canopy/full/electricaccess.gif
http://www.macsmachine.com/images/canopy/full/canopysealtoskin.gif
http://www.macsmachine.com/images/canopy/full/uclips.gif
This approach is great help in checking the inside motor mount to
longeron hardware at annual inspection and finding wiring problems.
It takes 15 minutes to remove and maybe 20 to put it back on without
doing any damage to anything. It's been off 6 or more times in the last
3 years for radio transponder and fuel fitting checks and it's still
very sound at 135 hours flight time.
601corvair wrote:
the bubble?
Thanks phill
Gig Giacona
Joined: 10 Jan 2006 Posts: 1409 Location: El Dorado Arkansas USA
Posted: Wed May 27, 2009 8:40 am Post subject: Re: panel access modicaton location |
My advise, go ahead and fit the canopy and the front skin. Even if you are going to put an access panel in you are going to want the front skin off while you are doing the wiring. Also, if you wait you will see exactly where you need the access.
Just FYI I'm making the entire front skin removable.
[quote="airvair601(at)yahoo.com"]We are trying to find dimensions for the placement of the
Thanks phill
601XL Under Construction
dredmoody(at)cox.net Guest
Posted: Fri May 29, 2009 3:04 pm Post subject: panel access modicaton location |
Likewise, my entire forward top skin is removable and I highly recommend that mod to the drawings. It takes a lot of nutplates and some dimpling and some thought but is well worth it in terms of knowing that you will be able to access the area in front of the panel any time you want to in the future.
Ed
Larry Webber
Joined: 05 Jun 2008 Posts: 51 Location: West Kingston Rhode Island
Posted: Fri May 29, 2009 4:44 pm Post subject: panel access modicaton location |
Hi all likewise the forward top skin is removable i split it down the center fore and aft
used a cap rib and instead of rivets i used 4-40 rivnuts and finishing washers
just removed it in less than 5 mins to install msd switch and firewall thru coil wire
Larry
Subject: Re: Zenith-List: panel access modicaton location
Date: Fri C 29 May 2009 17:58:20 -0500
Likewise C my entire forward top skin is removable and I highly recommend that mod to the drawings. It takes a lot of nutplates and some dimpling and some thought but is well worth it in terms of knowing that you will be able to access the area in front of the panel any time you want to in the future.
Ed
| Quote: | http://www.matronics.com/Navigator?Zenith-List
ronics.com
ww.matronics.com/contribution
| Hotmail® goes with you. Get it on your BlackBerry or iPhone. [quote][b]
_________________ how do you eat an elephant ? one bite at a time |
