kmccune
Joined: 22 Sep 2007 Posts: 577 Location: Wisconsin, USA
Posted: Wed May 27, 2009 7:01 pm Post subject: Bending 701 cabin sides |
Anything to watch out for when bending the 701 cabin sides ?
They took about 5 hour to make both and I don't want to have to make more. Though I will trace one out on the left over sheet....just in case.
Kevin
_________________ “Always do what you are afraid to do.”
R.W. Emerson (1803-1882)
Dorothy McCune |
dougsnash
Posted: Thu May 28, 2009 6:10 am Post subject: Bending 701 cabin sides |
Kevin, I don't remember anything overly trickey in beding the cabin sides. Just be really sure of where you are going to bend. I can understand why these parts are pre-built for kit builders. they are really time consuming to construct.
Doug MacDonald
CH-701 Scratch Builder
NW Ontario, Canada
--- On Wed, 5/27/09, kmccune <kmccune(at)somtel.net> wrote:
| Quote: | From: kmccune <kmccune(at)somtel.net>
Subject: Bending 701 cabin sides
Received: Wednesday, May 27, 2009, 10:01 PM
--> Zenith701801-List message
posted by: "kmccune" <kmccune(at)somtel.net>
Kevin
Mark Twain: Twenty years from now you will be more
disappointed by the things that you didn't do than by the
ones you did do. So throw off the bowlines. Sail away from
the safe harbor. Catch the trade winds in your sails.
Explore. Dream. Discover.
http://forums.matronics.com/viewtopic.php?p 45650#245650
FAQ,
- MATRONICS WEB FORUMS -
List Contribution Web Site -
-Matt
Dralle, List Admin.
__________________________________________________________________
Looking for the perfect gift? Give the gift of Flickr!
http://www.flickr.com/gift/
kmccune
Posted: Thu May 28, 2009 4:48 pm Post subject: Re: Bending 701 cabin sides |
Thanks for the response, but I reread what I wrote and I really didn't write it very well. Is there any fitments that I may want to consider. This coming from someone who made the stab before the fuselage, if you get my mounting point width drift.
Kevin
PS I will bend several scrap pieces at least, before committing my sides.
Dorothy McCune |
dougsnash
Posted: Thu May 28, 2009 6:38 pm Post subject: Bending 701 cabin sides |
Kevin, this is going back a couple of years for me so my memory might not be completely accurate. Anyway, the biggest issue I recall was that the vertical extruded Ls over top of the gear mount have special rivet spacing. Pay close attention to drill the rivet holes exactly where it says too. I seem to remember that the lower end of the L does not get rivets drilled in it.
Also, pay attention to the doubler that goes in the side, I seem to remember that I missed it on the first read through of my plans. I caught it before it affected me but it is worth noting.
One other thing is the lower door sill cover strip rivet spacing. It is easy to get the holes drilled where you cannot insert a rivet all of the way without hitting the underlying structure. Specifically on the back end of the surface that runs parallel with the cabin floor. The rivet will interfere with the L that goes back into the rear fuselage.
Hope these hints help. Best of luck with the build.
Doug MacDonald
CH-701 Scratch builder
NW Ontario, Canada
Oh, and ask again before you drill the cabin floor, there are some tricks I learned there too.
Subject: Re: Bending 701 cabin sides
Received: Thursday, May 28, 2009, 7:48 PM
pint width drift.
Kevin
kmccune
Posted: Fri May 29, 2009 1:46 pm Post subject: Re: Bending 701 cabin sides |
Thanks Doug, good stuff right there!
Kevin
Dorothy McCune |
