IVO in-flight adjustable, is it a good option?
Float Flyr
PostPosted: Wed May 27, 2009 1:01 pm    Post subject: IVO in-flight adjustable, is it a good option? Reply with quote
Good experiences using the IFA - UL on a 582 B box really helped shorten
the take off run on floats.
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
akflyer
PostPosted: Wed May 27, 2009 7:12 pm    Post subject: Re: IVO in-flight adjustable, is it a good option? Reply with quote
hmm would have to say that if it help the take of run, then yep its a good option...( I know I like mine, especially on floats). Were you posting a question or opinion?
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
582 (87 hrs and counting on the rebuild)
IVO IFA
Full Lotus 1450
hander outer of humorless darwin awards
Mark.Summers(at)lwbref.co
PostPosted: Fri May 29, 2009 1:22 pm    Post subject: IVO in-flight adjustable, is it a good option? Reply with quote
I bought a C box with the slip clutch recently, just realized the gear
ratio is 3.47 would this ratio be an issue for a 582 with 66 inch three
blade IVO ground adjustable prop. Thanks Mark
Float Flyr
PostPosted: Fri May 29, 2009 4:11 pm    Post subject: IVO in-flight adjustable, is it a good option? Reply with quote
I think with that reduction you will want a bigger prop. With slow turning
props bigger is generally better. You can use one of the blade tip speed
calculators to make sure the tips won't go supersonic on you at max rpm..
Noel
Noel Loveys
Kitfox III-A
Aerocet 1100 Floats
akflyer
PostPosted: Sun May 31, 2009 5:30 am    Post subject: Re: IVO in-flight adjustable, is it a good option? Reply with quote
your performance will suffer greatly with the 3.47. I have been running 2.62:1 with IVO IFA 72" I went to the 3:1 at the suggestion of a guy who stated the performance was much better.. I have tried 3 different props and found that I lost performance all the way around. Longer TO run, 5 mph less cruise, and about 300 FPM less on climb. Oh as an added bonus, the fuel burn went up a touch over 1 gph to cruise at the same speed. I am switching back to the 2.62:1 next time home.
snakeman
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
propellerdesign(at)tele2.
PostPosted: Sun May 31, 2009 7:11 am    Post subject: IVO in-flight adjustable, is it a good option? Reply with quote
66" will be good for 2,62:1
71" ---------------- 3,00:1
77" ---------------- 3,47:1
This with a Warp 3 blade or other normal 2 blade,
Problem with the high ratio is that angle become very large and a big part
of prop will be stalled at take off/climb
Jan
thesupe(at)hotmail.com
PostPosted: Sun May 31, 2009 1:39 pm    Post subject: IVO in-flight adjustable, is it a good option? Reply with quote
I've got a set of 2.62 gears in very good condition that I might sell for the right price.  Shoot my a private email if you are interested.  Take care C  Jim Chuk
Subject: Re: IVO in-flight adjustable C is it a good option?
Date: Sun C 31 May 2009 06:30:14 -0700
--> Kitfox-List message posted by: "akflyer" <akflyer_2000(at)yahoo.com>
> I bought a C box with the slip clutch recently C just realized the gear
your performance will suffer greatly with the 3.47. I have been running 2.62:1 with IVO IFA 72" I went to the 3:1 at the suggestion of a guy who stated the performance was much better.. I have tried 3 different props and found that I lost performance all the way around. Longer TO run C 5 mph less cruise C and about 300 FPM less on climb. Oh as an added bonus C the fuel burn went up a touch over 1 gph to cruise at the same speed. I am switching back to the 2.62:1 next time home.
snakeman
DO NOT ARCHIVE
Soldotna AK
Avid &quot;C&quot; / Mk IV
582 IVO IFA
Full Lotus 1260
http://forums.matronics.com/viewtopic.php?p=246128#246128
&gt=======================
Windows Live™: Keep your life in sync. Check it out.
PostPosted: Mon Jun 01, 2009 3:24 am    Post subject: IVO in-flight adjustable, is it a good option? Reply with quote
Thanks to all for the C box gear ratio information, appears I need to
re-gear or get a bigger prop. Is a 77" prop a viable option for a K-F 2?
Would I need to consider a 2 blade v/s 3 if I increase the prop size?
The main reason I bought the C box was to get the slip clutch addition,
I assume a larger prop would not be a problem with the slip clutch.
Thanks Mark
