gfmjr_20(at)hotmail.com Guest
Posted: Sun May 17, 2009 6:24 am Post subject: EGT Temps |
Can someone tell me what the expected max and min temperatures for EGT on the 912uls. Trying to set up my Dynon---
George May
601XL 912s
Insert movie times and more without leaving Hotmail®. See how. [quote][b]
Ollie Washburn
Joined: 10 Jan 2006 Posts: 56 Location: Central Florida
Posted: Sun May 17, 2009 8:13 am Post subject: EGT Temps |
CHT----275
170-230
OIL T--265 max
190-230
OIL P--
30-73
FUEL P--
2.2--5.8
H2O--275 max/Evans
EHT--1615 max
1560 Cr max
RPM--5800
48K-5500
IDLE MIN
1600
Ollie
On Sun, May 17, 2009 at 10:23 AM, george may <gfmjr_20(at)hotmail.com> wrote:
George May
601XL 912s
_________________ Ollie RV6-A & Rans S7S
Central FL |
Posted: Sun May 17, 2009 1:11 pm Post subject: EGT Temps |
Thanks Ollie----that's what I needed
| Quote: | Date: Sun C 17 May 2009 11:57:29 -0400
Subject: Re: EGT Temps
--> RotaxEngines-List message posted by: Ollie Washburn <ollies7s(at)gmail.com>
CHT----275
170-230
OIL T--265 max
190-230
OIL P--
30-73
FUEL P--
2.2--5.8
H2O--275 max/Evans
EHT--1615 max
1560 Cr max
RPM--5800
48K-5500
IDLE MIN
1600
Ollie
On Sun C May 17 C 2009 at 10:23 AM C george may <gfmjr_20(at)hotmail.com> wrote:
> Thanks
> George May
> 601XL 912s
> ________________________________
Hotmail® has a new way to see what's up with your friends. Check it out.
kitfoxsport(at)verizon.ne Guest
Posted: Sun May 17, 2009 9:21 pm Post subject: EGT Temps |
EGT for 912
Rotax Installation Manual under exhaust systems section 11.2
EGT:
Normal 1470 f
Max 1560 f
Take off 1616 f
George
Sport Model - 914 / painting complete 5/1/09
Sent: Sunday, May 17, 2009 2:10:05 PM
Subject: RE: RotaxEngines-List: EGT Temps
.hmmessage P { margin:0px;padding:0px;} body.hmmessage { font-size:10pt;font-family:Verdana;} Thanks Ollie----that's what I needed
| Quote: | Date: Sun, 17 May 2009 11:57:29 -0400
CHT----275
170-230
OIL T--265 max
190-230
OIL P--
30-73
FUEL P--
2.2--5.8
H2O--275 max/Evans
EHT--1615 max
1560 Cr max
RPM--5800
48K-5500
IDLE MIN
1600
Ollie
> Thanks
> George May
> 601XL 912s
rampil
Posted: Thu May 28, 2009 7:51 am Post subject: Re: EGT Temps |
The book values do not always pan out. I have 4 EGTs in the
prescribed spots and seldom see even 1500F on the back cylinders
and 1200F in the front. My system is digital and calibrated (Blue Mountain).
BTW: Rotax does not recommend EGT monitoring on the 912/912s
because there is no way in a stock engine to alter the mixture, and
seeing the usual values just makes owner anxious and leads to excess
calls to the distributors who can only reassure.
Posted: Thu May 28, 2009 1:49 pm Post subject: EGT Temps |
Hi Ira"because there is no way in a stock engine to alter the mixture"Turn off fuel supply and it will lean mixture, that will let you see if you are rich of peak.Ron Parigoris [quote][b]
rampil
Posted: Fri May 29, 2009 6:43 am Post subject: Re: EGT Temps |
Hi Ron,
I was just pointing out that most Rotax drivers are probably better off
without EGTs than they would be with. I say that as a quant who has
4 EGTs, 6 CHTs (two duplicates to compare plug rings with Rotax probes)
and coolant and carb temps.
Ira
