ron.mcgann(at)baesystems. Guest
Posted: Wed May 27, 2009 5:46 pm Post subject: UMPCs for the cockpit |
For the technophiles out there, I am about to lay down some cold cash for a Viliv S5. It will be used as a backup GPS and flight planning system in the cockpit. Anyone have any experience with these devices?? (Note that they also come in a 32G SSD version)
http://jkontherun.com/2009/04/18/viliv-s5-review/
Ron
VH-XRM
[quote]"Warning:
The information contained in this email and any attached files is
confidential to BAE Systems Australia. If you are not the intended
recipient, any use, disclosure or copying of this email or any
attachments is expressly prohibited. If you have received this email
in error, please notify us immediately. VIRUS: Every care has been
taken to ensure this email and its attachments are virus free,
however, any loss or damage incurred in using this email is not the
sender's responsibility. It is your responsibility to ensure virus
checks are completed before installing any data sent in this email to
your computer."
glastar(at)gmx.net Guest
Posted: Wed May 27, 2009 10:49 pm Post subject: UMPCs for the cockpit |
Hi Ron,
power sounds al right however for a 4.8" screen 1024x600 is (out of my
view) to high of a resolution, the harddisk will longterm not last in a
cockpit environment you're better off with a SSD. What I'm missing
totally is how many nits the screen has as most of this gadgets are a
bit short in brightness. I'm currently working on my own hardware, intel
Atom 1.6Gig board with a 750nits Optrex 6.4" (640x480) screen where the
touchscreen will reduce that by around 100 nits.
Cheers to "Downunder"
Werner
McGANN, Ron wrote:
Ron
VH-XRM
"Warning:
your computer."
tc1234c(at)roadrunner.com Guest
Posted: Thu May 28, 2009 4:09 am Post subject: UMPCs for the cockpit |
I have a Samsung UMPC. The screen is just not bright enough to use in my 9A. It will be better in a 10, yet still not ideal.
T.C. Chang
http://3limafoxtrot.com/
RV-9A, Lycoming (ECI) O320-D2A, 160 hp, Carb, left Mag + right Lightspeed EI, Sensenich FP
GRT dual DU H1, TT DigiFlight II VSGV, 579 hrs Hobbs
Last flight: http://www.mail2600.com/cgi-bin/track.cgi?call=KD8IIR&last=1
RV10 emp, #40948
Lenny Iszak
Posted: Thu May 28, 2009 8:11 pm Post subject: Re: UMPCs for the cockpit |
I have a samsung Q1 ultra, and it's mostly visible, but not always.
I'm building a 1600 nit screen with a capacitve touch sensor. Most of the resitive sensors i looked at are rated for max 10000ft.
Has anyone ever had problems with resistive touch screens (most laptops tablets & pdas use it) working at high altitude?
Lenny
Posted: Thu May 28, 2009 11:39 pm Post subject: UMPCs for the cockpit |
Lenny,
any source/price for the 1600 nits screen?
Werner
Lenny Iszak wrote:
Lenny
http://forums.matronics.com/viewtopic.php?p 45833#245833
Lenny Iszak
Posted: Sat May 30, 2009 6:03 pm Post subject: Re: UMPCs for the cockpit |
Werner,
I bought the screens from Landmark Tech. LM190A-121X1-LO1 KIT $795 each. It comes with the controller, and inverter. They are 12 inch screens.
http://www.landmarktek.com/
I also found a chinese manufacturer that sells 10 inch screens for only a couple hundred bucks, 1500nits. The problem is that the resolution is only 800x600.
Lenny
Posted: Sat May 30, 2009 8:54 pm Post subject: UMPCs for the cockpit |
Hi Lenny,
thanks a lot, they sound very interesting, I see they sell opsware
screens too so they have the well known brands for high tech LCD's and
you better stay with a known quality company then buying "paperware"!
Werner
Lenny Iszak wrote:
Werner,
Lenny
http://forums.matronics.com/viewtopic.php?p 46081#246081
