Jack heads for yaks the same as changs?
skidmk
PostPosted: Fri May 29, 2009 11:57 am    Post subject: Jack heads for yaks the same as changs? Reply with quote
does anyone know if "yak" jacks work for the chang?
Mike "Skidmk" Bourget
Ottawa, Ontario
viperdoc(at)mindspring.co
PostPosted: Fri May 29, 2009 6:15 pm    Post subject: Jack heads for yaks the same as changs? Reply with quote
I believe the answer is no. Ask Doug Sapp about the way a CJ is jacked up.
There are no jack points on the firewall of the CJ. A cradle is placed under
the bottom cylinders for the nose jack point. There is an L shaped elbow
that goes under the wing jack points if my memory serves me right. The YAK
jack placed at the CJ's wing jack point interferes with the swinging of the
gear.
I believe Dennis went through this dance with the last CJ he had in the
hanger.
Doc
