Yak-52 Battery Switch Sanity Check
shinden33
PostPosted: Sat May 30, 2009 4:44 am    Post subject: Yak-52 Battery Switch Sanity Check Reply with quote
All,
Sanity Check needed. Yak-52 battery switch terminals (on the back, not switch position):
Top- external
Mid - Off/ground?
Bot- battery
Is this correct?
Scott
N8252
The Defiant Company
www.thedefiantcompany.com
dsavarese0812(at)bellsout
PostPosted: Sat May 30, 2009 5:14 am    Post subject: Yak-52 Battery Switch Sanity Check Reply with quote
Scott,
Looking at the back of the battery switch, the top section where the buss bar is located, is the BATTERY side when you have the battery switch in the UP position on the front. Put your volt meter on the buss bar, flip the battery switch to the UP position and you should read the battery voltage.
Dennis
shinden33
PostPosted: Sat May 30, 2009 5:21 am    Post subject: Re: Yak-52 Battery Switch Sanity Check Reply with quote
Thanks!
The Defiant Company
