jfmasell(at)optonline.net Guest
Posted: Mon Mar 27, 2006 9:07 am Post subject: Welding my tanks |
I am looking for someone who can weld my tanks. I am using 3031 tank grade
aluminum and have formed all pieces as well as purchased all fittings I need
someone who can take on the welding for my 801. I have fabrication for 4
tanks. Any recommendations?
John Maselli
516-524-0420
_____
I've stopped 1,014 spam messages. You can too!
One month FREE spam protection at www.cloudmark.com
<http://www.cloudmark.com/spamnet?v1&rc=>
<http://www.cloudmark.com/spamnet?v1&rc=> Cloudmark SpamNet - Join the
fight against spam!
frank.hinde(at)hp.com Guest
Posted: Mon Mar 27, 2006 9:27 am Post subject: Welding my tanks |
Yes...Don't weld if you can help it...ZAC's tanks get somewhat distorted
and a better way if you can is to use riveted lap joints and an evil goo
called Proseal (available from Vans aircraft). All Vans tanks are made
very successfully this way. The nick name for Proseal is "The Black
Death"...But it sure does seal!
Welding is OK but I am not the first one to suffer a leaking tank dues
to a cracked weld (I assume from work hardening the little bent flanges
plus heat).
Then you can do it all yourself
Frank
601 HDS 394 hours
Posted: Mon Mar 27, 2006 9:49 am Post subject: Welding my tanks |
That's great I actually made the flanges larger to accommodate welding
because I had trouble with my welds in practice I drilled for all the rivets
but then someone told me that I was going to get leaky tanks. If I can rivet
my self then I can do the job myself. But how do I rivet the fittings this
may be a bit more difficult I suppose I could make gaskets and flange rings
to rivet the fittings? But again thanks George I need encouragement to get
this portion done. It has stopped me in my tracks!
John Maselli
A Computer Consulting
516-524-0420
_____
Cloudmark SpamNet - Join the fight against spam!
Posted: Mon Mar 27, 2006 10:35 am Post subject: Welding my tanks |
Thanks Frank will tell Vans and the flange washer idea sounds good I already
bought the aluminum fittings from aircraft spruce. I order the quart of
proseal (They have new stuff on vans replaces proseal calls flamemaster) I
will get a few smaller 6oz jars to do the fittings first. I believe this
will work!
John Maselli
516-524-0420
_____
rdewees(at)mindspring.com Guest
Posted: Mon Mar 27, 2006 11:31 am Post subject: Welding my tanks |
Hi John,
If you go with a sealant, I would suggest that it's as compatible with
as many fuels as possible. Several old sealers weren't compatable with
auto fuel and/or autofuel with alcohol in it. Don't know what motor you
are using but if you even think that the next owner could use autofuel,
look at the best sealer for it and 100LL.
Just a suggestion-- I use 99% auto fuel in my Jab 3300 and it works great.
Ron
John Maselli wrote:
John Maselli
516-524-0420
steveadams
Posted: Tue Mar 28, 2006 5:37 am Post subject: Re: Welding my tanks |
I guess I will be the dissenting opinion in this discussion. While Vans does use the rivet/proseal method, it is not without it's shortcomings. It seems to be the most dreaded part of the build for many builders, and leaky tanks are a significant problem with this method as well. RV's are designed for this type of tank and they can be removed for servicing if needed. Browse the RV lists and you will see a lot of discussion about the tanks and problems encountered. While I have seen some discussion on this board concerning leaks in welded tanks, the leaks have been discovered for the most part with testing prior to installation. I have not noticed a problem with welds cracking after the airplane has been flying. The zodiac design is for the tank to be within the wing, rather than an intregal part of the wing. Getting to the tank after closing the wing involves opening up the wing skin. Yes it is difficult to properly weld a tank, and requires a skilled and experienced welder to do right. Yes the tanks are a bit deformed looking sometimes. But if done correctly and adequately tested for leaks prior to installation, I believe it is a superior tank for the Zodiac design. Just my opinion.
Posted: Tue Mar 28, 2006 7:26 am Post subject: Welding my tanks |
Mine failed after about 250 hours and had to be removed for
re-welding...Not the end of the world but welded tanks do fail.
Proseal is not THAT hard to work with having built two RV tanks....Its a
bit like fixing a sewer leak....Thinking about it is the worse part...
Frank
HDS 394 hours
leaky tanks are a problem with this method as well. RV's are designed
a tank, and requires a skilled and experienced welder to do right.!
http://forums.matronics.com/viewtopic.php?p=24758#24758
shilocom(at)mcmsys.com Guest
Posted: Tue Mar 28, 2006 8:36 am Post subject: Welding my tanks |
I would tend to agree with the conclusion below. When at the Zenair
workshop I watched the young lady they had welding their tanks and saw the
quality of her output and was Impressed. So many times in discussions like
this we take Part A and apply it to aircraft B and expect it to work and it
doesn't. I think that's really what the conclusion below is all about also.
Now IF I had to weld the tanks, and for that matter, design the tanks the
clear choice would be PRO SEAL, but that's not the case here. My welding
and design abilities are not in the same league as Zenith. Bob U.
steveadams
Posted: Tue Mar 28, 2006 11:10 am Post subject: Re: Welding my tanks |
| frank.hinde(at)hp.com wrote: | Mine failed after about 250 hours and had to be removed for
Frank
HDS 394 hours
True, they do occasionally fail. However, look how often the prosealed tanks get a weeping rivet or two. Not a problem if the rivet is staring you in the face. There are ways to drill out the offending rivet and seal the leak without even having to pull the tank. In a Zodiac that is not an option, you either live with the leak (not a good option) or open up the skin and fix the tank (also not such a good option). I'm not saying that the RV is not a good design, just that you really can't build a Zodiac the same as an RV any more than you can build an RV just like a Zodiac. CH didn't include welded tanks in his design because it is easier or cheaper for them to manufacture, so in my mind there must be a good reason.
mgraves(at)usmo.com Guest
Posted: Wed Mar 29, 2006 5:01 am Post subject: Welding my tanks |
If the 3031 is .040-.050 thick, almost any good welding shop with a TIG
welder will be able to do it. Members of your local EAA can direct you
where, if one of them can't do it. If you still can't find a local
welder. Bruce Frank, advertises in the back of the EAA rags, to weld
and customize fuel tanks. From what I hear He does good work although
I have no idea what he charges. There will be shipping to and from CA I
believe..
The problem is getting the Zenith tanks welded is two things. 6061 is
harder to weld, and the .025 thickness. It takes a lot of practice and
skill to weld sheet that thin on and alloy that is not commonly
welded......Most welders won't attempt it. Not that they can't, its not
worth the pain in the ass to fiddle with for such a small job.
A local EAA chapter member welded up my 701 tanks, upon his recomendation
I went with the 3031 Alum also and .040 thick. I helped him clean and
fit the seams with vice grips as he welded, and each tank took aprox 2-3
hours of time to complete and pressure test. He did a nice job and they
turned out great.
Depending on welders rates in your area, this should give you some idea of
what each tank will cost to get it welded.
If you decide to go ahead and weld instead of rivet. Save the 3031 scrap
pieces, and takes some along to the weld shop. The welder may need some
patch fill pieces for the corners. If you cut a fraction too big a notch,
there will be a gap when the lips are folded over and mated to the side pieces.
Monty Graves
John Maselli
516-524-0420
