captainron1(at)cox.net Guest
Posted: Fri May 29, 2009 1:20 pm Post subject: WRT M3X prop boom measurements. |
Folks I started the mating of the Suzuki motor to the Mounts. I need some measurements as to prop clearances and measured distance from the Boom the the center of the prop hub. I can't see where some of you reported where you had a 72 inch prop. I see where I can install a 70 inch prop on my mount but then clearance will be down to about an inch. These are preliminary measurements for my airframe.
Anyway I need to figure out what's what WRT that.
Ron (at) KFHU
Posted: Fri May 29, 2009 1:36 pm Post subject: WRT M3X prop boom measurements. |
Ron C
� I have a turbocharged Suzuki G1.0.�& a 68" inflight electric adjust IvoProp.� My measurements are:��from tip of prop to boom tube C I have close to 2 3/4" clearance.� Of course C you have a different redrive than I do C but it sounds like your prop position is very close to mine.
Mike Welch
MkIII
[quote] Folks I started the mating of the Suzuki motor to the Mounts. I need some measurements as to prop clearances and measured distance from the Boom the the center of the prop hub. I can't see where some of you reported where you had a 72 inch prop. I see where I can install a 70 inch prop on my mount but then clearance will be down to about an inch. These are preliminary measurements for my airframe.
Ron (at) KFHU
Hotmail� goes with you. Get it on your BlackBerry or iPhone.
Posted: Fri May 29, 2009 2:00 pm Post subject: WRT M3X prop boom measurements. |
Quote: | Anyway I need to figure out what's what WRT that.
Ron (at) KFHU
I've flown with 70,71, and 72" props on my mkIII. Clearances ranged from
the "book" 1.5" to as little as .75". Currently have 1.25" with my new 71"
blades.
The lower the line of thrust the more efficient the system will be.
_________________ John Hauck
Titus, Alabama |
Posted: Fri May 29, 2009 8:55 pm Post subject: WRT M3X prop boom measurements. |
Okay thanks, I guess and also based on what John H. said that the Suzuki motor crank is stationed lower on the mounts than the Rotax.
I would like at one point to have the SPG-2 turned down and have a 5 or 6 blade prop on it. this will place the center of thrust just about equal with the trailing edge of the wings. However for the moment and with the budget I got I'll keep it as is.
A friend of mine was looking at it today for the first time and she said "it has such a big motor on it"..... I guess the DOHC 1.3 is kinda large looking on the frame.
---- Mike Welch <mdnanwelch7(at)hotmail.com> wrote:
Ron,
I have a turbocharged Suzuki G1.0. & a 68" inflight electric adjust IvoProp. My measurements are: from tip of prop to boom tube, I have close to 2 3/4" clearance. Of course, you have a different redrive than I do, but it sounds like your prop position is very close to mine.
Mike Welch
MkIII
Quote: | Folks I started the mating of the Suzuki motor to the Mounts. I need some measurements as to prop clearances and measured distance from the Boom the the center of the prop hub. I can't see where some of you reported where you had a 72 inch prop. I see where I can install a 70 inch prop on my mount but then clearance will be down to about an inch. These are preliminary measurements for my airframe.
Ron (at) KFHU
Hotmail® goes with you.
http://windowslive.com/Tutorial/Hotmail/Mobile?ocid=TXT_TAGLM_WL_HM_Tutorial_Mobile1_052009
kugelair.com
Posted: Sat May 30, 2009 7:44 am Post subject: WRT M3X prop boom measurements. |
It could have been me last year ( or 2 or 3 years ago) that spoke of a high number multi blade propeller. However for me as evidenced by my own paint jobs, beauty or looking cool for looking cool is seldom a consideration.
A multi blade prop all else being equal is more efficient and effective. I truly don't want to delve into this subject again, but I think that real life experience and the math supports what I say. But again the last thing I want to start is another debate about this.
I just felt for whatever strange reason to say the above fully knowing that this may yet start another thread..... LoL.
Anyway budgetary consideration will probably keep me more or less in a more popular configuration engine prop wise ( for the time being....).
Ron (at) KFHU
Ron,
Turning the SPG-2 redrive upside down (lowering the prop center) and then using a 5-6 blade prop would be a really bad idea.
This subject has been discussed numerous times before on this list. The smaller the prop, the faster is has to spin. Plus, because the prop is small, you have to add more blades, because a large engine will overpower a small 2 blade prop. But, a faster spinning prop means more noise and is not as efficient.
IIRC, someone proposed putting on a multiblade prop (4-5 blades) a year or two ago. They thought it looked "cool". They were willing to give up some performance for "the look". Not a
good idea to just throw away some of an engine's thrust.
Just my opinion.....
Mike Welch
MkIII
Quote: | Date: Sat, 30 May 2009 00:54:30 -0400
Subject: RE: WRT M3X prop boom measurements.
Ron,
Mike Welch
MkIII
> Thanks
> Ron (at) KFHU
kugelair.com
Insert movie times and more without leaving Hotmail®.
http://windowslive.com/Tutorial/Hotmail/QuickAdd?ocid=TXT_TAGLM_WL_HM_Tutorial_QuickAdd1_052009
kugelair.com
JetPilot
Posted: Sat May 30, 2009 1:21 pm Post subject: Re: WRT M3X prop boom measurements. |
captainron1(at)cox.net wrote: |
How many blades do you mean by " Multi Blade ? " One huge factor is power for the amount of prop area and speed. For a turboprop going fast, I think the 6 blade prop works better, but they are trying to get 3000 horsepower into a limited diameter prop.
With all the LSA and experimental planes out there, no significant number of planes are using more than 3 or 4 blades. If it were as easy as adding more blades to get significantly more performance on our class of airplane, many would be doing it. Theory is nice, but nothing trumps real life performance, and by the lack of many bladed propellers on our class airplanes seems to indicate there is just noting to be gained by that. If were as easy as changing a prop, and there were some reports of a 6 blade propeller significantly improving performance of our class planes, people would be lined up waiting to buy these props.
Kolb MK-III Xtra, 912-S |
Posted: Sat May 30, 2009 1:43 pm Post subject: WRT M3X prop boom measurements. |
It goes without saying that adding blades, will not do a thing for HP. We got what we got in that motor. The question is, well let me back up. I am thinking of lowering the thrust line further. With the SPG-2 it can be mounted 12-3-6- and 9 o'clock.
If I turn it down the thrust line gets be be pretty low. But now I am down to a 55 inch prop. If I use a two blades I will be nowhere near optimal conversion of HP/thrust. As you said it needs enough wing airfoil or prop to take the hp and make the thrust that the motor is capable of producing
thus I gotta put more blades. Or another way I gotta create more blade area. I guess we can figure out how much effective airfoil area two 71 inch props has and then figure out how many blades I gotta put on that hub to get the same total area. And then You can throw another blade in there for rotating disc efficiency and be done with it. Like I said the last I commented about this some experimentation is certainly required. One of the prop makers has a hub that can use six blades I guess if its not too expensive I buy it and start with 3 blades like everyone else and then add 3 more blades ( down sizing the whole deal as needed), and see the difference.
I think that would be fun to explore.
Ron (at) KFHU
http://forums.matronics.com/viewtopic.php?p 46065#246065
kugelair.com
JetPilot
Posted: Sat May 30, 2009 4:22 pm Post subject: Re: WRT M3X prop boom measurements. |
For a slow flying plane like a Kolb, a larger diameter prop is far more efficient and provides more thrust. As you make the prop disc smaller, the velocity of the air that you need to move becomes faster... A Kolb can not take advantage of High Velocity thrust. Imagine putting a small jet engine on a Kolb, you would be using a huge amount of power and fuel just to cruise at 80 MPH. It is an extreme example, but its the same thing as putting a small prop that depended on high velocity air on a Kolb, you would need about 200 HP to get the same performance as we get with our large diameter props.
A helicopter rotor is just a large prop that is very large diameter and optimized for slow speeds ( Lifting ). An R-22 will have more thrust than weight with just 160 HP and fly... If you took that same 160 HP engine on a helicopter and put a small high speed prop on it instead of a rotor, you would be moving a smaller volume of air very fast, but it would all be wasted energy, and it would not even come close to lifting the helicopter off the ground. On the same token, the helicopter rotor would not fly very fast mounted on the front of a Cirrus or other high speed plane.
The idea of getting the thrust line much lower would be great, but it is not practical with this type of airplane. You would need so much extra power to compensate for the small diameter high speed optimized propeller that you would create more problems than you would solve. There has been a lot of experimentation with props and thrust lines on pushers, and what we have now as about as good as a compromise that you will get. Again, if it were as easy as adding prop blades, and lowering the thrust line closer to the CG of the airplane, it would make a much nicer flying airplane, and it would have been done long ago.
Posted: Sat May 30, 2009 5:44 pm Post subject: WRT M3X prop boom measurements. |
Ideally an Ultrastar should have the prop rotating around the boom
tube. Take a nice big bearing......
BB
diameter props.
on it instead of a rotor, it would not even come close to lifting
it on the ground. On the same token, the helicopter rotor would
speed plane.
http://forums.matronics.com/viewtopic.php?p 46074#246074
Dana
Posted: Sat May 30, 2009 7:03 pm Post subject: WRT M3X prop boom measurements. |
At 09:42 PM 5/30/2009, robert bean wrote:
Quote: | Ideally an Ultrastar should have the prop rotating around the boom
Y'know, I've thought of that. Suitable bearings _are_ available (I
checked). Replacing the redrive belt would be quite a procedure, though...
-Dana
We wonder why the dogs always drink out of our toilets, but look at it
from their point of view: why do humans keep peeing into their water bowls?
Posted: Sat May 30, 2009 7:27 pm Post subject: WRT M3X prop boom measurements. |
See this is the thing I don't understand about the idea that a larger prop is more efficient. If say ( and its better if we use numbers as then we have a hard baseline) 55 inch blade. The 55 inch blade lets for the heck of it say six blades has a total effective surface area which may be larger than three blades of say 72 inches.
Furthermore if the tips of the props remain under .8 mach ( which they will) and the prop is near its Ld / Max, where in the world a three blader will be better ( we are rich so money is not a limit ).
Its like the gears in a car, it will do 70 miles an hour as long as you get the rght amount of HP to the wheels, be the wheels 20 inch rims or be the wheels 13 inch rims with taller gearing at the same RPM (more blades roughly speaking 35% more blades) output at the crank. Not exactly aples to aples but close enough for us.
A helicopter rotor is just a large prop that is very large diameter and optimized for slow speeds ( Lifting ). An R-22 will have more thrust than weight with just 160 HP and fly... If you took that same 160 HP engine on a helicopter and put a small high speed prop on it instead of a rotor, it would not even come close to lifting it on the ground. On the same token, the helicopter rotor would not fly very fast mounted on the front of a Cirrus or other high speed plane.
kugelair.com
Dana
Posted: Sat May 30, 2009 8:05 pm Post subject: WRT M3X prop boom measurements. |
At 11:25 PM 5/30/2009, Ron wrote:
Quote: | See this is the thing I don't understand about the idea that a larger prop
larger than three blades of say 72 inches...
There are several aspects to this.
First, a prop creates thrust by increasing the speed of air passing through
it. It's more efficient to accelerate a lot of air a little bit than to
accelerate a little bit of air a lot. Thus a larger prop is better.
Second, there are tip losses, just like a wing. A higher aspect ratio wing
is more efficient (look at a sailplane).
Third, the closer together the blades are, the more each blade is operating
in the air disturbed by the previous blade. This causes inefficiency in
the same way that a biplane is less efficient than a monoplane.
The ONLY reason for more than two blades is if you don't have enough room
for a 2 blade prop that can absorb all the engine's power, or if it's
turning too fast so that you get tip losses due to sonic effects and you
can't increase the reduction ratio.
-Dana
Ethernet (n): something used to catch the etherbunny
robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Sat May 30, 2009 8:36 pm Post subject: Re: WRT M3X prop boom measurements. |
A very good parallel for understanding the prop diameter / efficiency thing is to look at a tug boat prop. A tug has a huge diameter slow turning propeller which is what it takes to produce alot of thrust, as opposed to a speedboat's small prop turning very fast to achieve high speeds. I think it's fairly obvious that you need diameter to move alot of water or air, and create thrust. Hence, if you are limited in diameter, you will be giving up some thrust.
I hope that helps, Rob
russ(at)rkiphoto.com Guest
Posted: Sun May 31, 2009 3:13 am Post subject: WRT M3X prop boom measurements. |
BB , I like your thinking! -- long as you didn't take off or land,
you'd be fine.
But I wonder about gyroscopic & P-forces??
BB
> Mike
Posted: Sun May 31, 2009 5:53 am Post subject: WRT M3X prop boom measurements. |
Link belt
though...
-Dana
at it from their point of view: why do humans keep peeing into
their water bowls?
Posted: Sun May 31, 2009 8:37 am Post subject: WRT M3X prop boom measurements. |
"First, a prop creates thrust by increasing the speed of air passing through
accelerate a little bit of air a lot. Thus a larger prop is better. "
============== above is a quote==============
that's actually incorrect, it may be correct if we were talking about a Rocket motor or say a Turbo Jet but not a conventional propeller. The propulsion that a prop creates is directly proportional to how much lift the prop airfoil creates. Now if you look at the mechanic of lift you will see that to top of the prop creates a low pressure area. the air movement that you notice as the prop blast is to a large extent a stream of onrushing air filling in the low pressure area that the blades created. It can be accomplished by a large blade or many small blades. In fact the many small blades are way better at creating a vacuum in front of the propeller than a fewer blades attempting the same thing. This is not an opinion this is a fact of aerodynamics ( all else being equal ).
I sense that people have some problems in letting go of some constants in their minds, one of them is notion that a large because its large creates more propulsive force than an equally sized volume disc with multiple blades. Anyway I really gave out more information then I want, since who knows I may want to have a Kolb Air Race and I want to compete against the folks who hold a different concept.
Posted: Sun May 31, 2009 8:47 am Post subject: WRT M3X prop boom measurements. |
I want a front row seat.
BB
On 31, May 2009, at 12:36 PM, Ron wrote:
passing through
than to
equal ).
different concept.
I don't know about that,,,,, .
I just did a quick Google search for boat props and most of them are at least 4 blades, and their cross section support 100% just what I'v been saying all along. Submarine props are very much multi blade props, they almost look like the Propjets from the 80's.
http://forums.matronics.com/viewtopic.php?p 46096#246096
kugelair.com
