Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
Juan Vega Jr
Posted: Mon Jun 01, 2009 5:43 pm Post subject: Putting Flutter Issue to Bed |
See Below. Lets Quit the BS, as the test result show the Flutter is the wrong tree to bark up. Lets look a the quality of the builds, even the AMD one or the lack Pilot control.
This reprot makes it clear Flutter aint happening! Now someone needs to take this to the press to make sure the bad press we recieved gets its proper rebuttal.
Juan Vega
ARTICLE from Zenith Europe-
The recent meetings between Zenair and German authorities (the DAeC and their DAR engineers as well as the BFU) were very productive with key steps taken towards re-establishing the good standing of the CH 601 XL aircraft throughout Europe. A very comprehensive presentation by the head of the GVT program that tested the aircraft made it very clear that the oft suggested flutter is an exceedingly unlikely “smoking gun” to explain past accidents. The engineer in charge instead applauded Chris Heintz for the overall scores obtained by the Zodiac throughout the tests, as they were among the best ever seen in his lab. The results of the very thorough linear flutter analysis left no doubts in anyone’s mind: “No tendency to flutter or divergence was found within the flight envelope of the CH 601 XL”. This included tests from minimum to maximum take-off weight; with fixed as well as free controls; with control cable tensions varying from well below 10 lbs. to over 40 lbs, and with standard as well as overweight control surfaces (i.e. possibly due to excessive paint in the “real world”); all from sea level to over 15,000 feet and to speeds well above 400 km/h.
In order to ensure accurate results, all tests were carried out on two different Zodiac aircraft. The significance of the flap stops called-for as part of the regular design was confirmed. The aircraft which did not at first have these installed showed less satisfactory results than Zenair’s own standard demo plane (with stops) which was one of the tested planes. Zenair will be issuing a Service Letter very shortly calling for owners/pilots to check their flap stops (and to install them prior to further flight operations if these have not been previously fitted). By the end of the tests, both aircraft (a classic CH 601 XL and the newer CH 650 E) presented the same consistent results: No tendency to flutter.
Also during this GVT testing process, it was noticed that the German-registered CH 601 XL on which the tests were conducted did not have part of the aileron-stop structure which was an integral part of the CH 601 XL at the time of German certification. Zenair has been asked by the DAeC to issue a Service Letter addressing this potential discrepancy for German-registered CH 601 XL; the DAeC will be issuing its own AD shortly to ensure the aircraft’s ongoing compliance with LTF-UL certification.
Many questions were answered by the flutter expert after his presentation to German authorities; his answers and ample GVT data successfully satisfied those present that flutter was a non-issue for the Zenair Zodiac design. “The complete ground vibration tests (GVT) just completed were conducted to natural frequencies well over 70 Hz. This clearly demonstrates that the standard Zodiac design is flutter-free within (and well beyond) the entire range of its flight envelope” said Chris Heintz, who also attended the meetings.
jmaynard
Joined: 27 Feb 2008 Posts: 389 Location: Fairmont, MN (FRM)
Posted: Mon Jun 01, 2009 6:22 pm Post subject: Putting Flutter Issue to Bed |
On Mon, Jun 01, 2009 at 09:40:39PM -0400, Juan Vega wrote:
| Quote: | See Below. Lets Quit the BS, as the test result show the Flutter is the
Just because flutter isn't the issue (I agree with that) doesn't mean that
there's not some other problem with the aircraft itself. We just don't know.
Of course, you're invulnerable, so you'll never have a problem.
Come on, Juan, pull your head out of the sand.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
psm(at)att.net Guest
Posted: Mon Jun 01, 2009 6:36 pm Post subject: Putting Flutter Issue to Bed |
Indeed, the NTSB identified another problem - one which I think might
explain all the accidents. It is the stick gradient problem that
makes it easier to pull additional G's as you pull additional G's.
The NTSB demanded both this be fixed and aileron mass balancing be
added. I hope the Zenair folks are going to release design changes
to resolve those issues. It really doesn't matter whether the
changes are justified by German engineers or not. The changes are
still needed to satisfy the NTSB demands.
Paul
XL grounded
At 07:21 PM 6/1/2009, you wrote:
| Quote: | Just because flutter isn't the issue (I agree with that) doesn't mean that
d.goddard(at)ns.sympatico Guest
Posted: Tue Jun 02, 2009 1:44 am Post subject: Putting Flutter Issue to Bed |
I don't know Paul. With the engineering report in hand the NTSB may withdraw
it's request for mass balancing, it's likely to go unfulfilled at this
point. The stick issue is an undesirable feature but training could/should
address it. My hope is that the aircraft just experienced a very bad patch
of incidents and that history will not repeat itself. A new stick
arrangement would be nice, many of the Zenith designs seem to require much
more force in roll than pitch.
Posted: Tue Jun 02, 2009 2:13 am Post subject: Putting Flutter Issue to Bed |
Hi Dave,
While you may be correct about the NTSB changing their position on
the design changes, I seriously doubt that will happen.
I don't think they made the demand for aileron balance based on
research about the Zodiac design. I think it was made based on the
experience in the industry that aileron balance makes safer
airplanes. According to a number of people I have contacted in this
regard, industry standard handling of this question has shown aileron
mass balancing is beneficial (i.e. saves lives) on all airplane
designs except for those that have fabric covered ailerons. Please
keep in mind that there have been a relatively high number of
structural failures on Zodiac XLs. That is why the NTSB was looking
at this particular design in the first place.
I don't know why you made the comment about the difference in forces
for aileron vs. elevator travel. That is not an issue for me or the
NTSB. The issue is the clear flaw that as you increase the G's being
pulled by the plane it becomes easier to add more G's. While
training about this flaw might prevent some deaths it seems more
appropriate to actually fix the design. I don't know exactly what
this will take, but my sense is that it is not difficult to fix. I
don't believe any pilot would apply too much force to the stick on
purpose. I think this is possible in a panic situation or possibly
as a weird mistake where the passenger accidently kicks the stick or
some such thing.
If the NTSB issues another letter saying they have decided to
withdraw their statement that these changes are needed then I will
consider dropping the same needs from my decision to ground my
plane. As it now stands, I need approved engineering changes from
Zenith or a related source for these issues before my plane gets
un-grounded. The longer it takes for Zenith to decide to create
those engineering changes the longer my plane will be grounded.
Paul
XL Grounded
At 02:41 AM 6/2/2009, you wrote:
| Quote: | I don't know Paul. With the engineering report in hand the NTSB may
withdraw it's request for mass balancing, it's likely to go
unfulfilled at this point. The stick issue is an undesirable
feature but training could/should address it. My hope is that the
aircraft just experienced a very bad patch of incidents and that
history will not repeat itself. A new stick arrangement would be
nice, many of the Zenith designs seem to require much more force in
roll than pitch.
Thruster87
Posted: Tue Jun 02, 2009 2:36 am Post subject: Re: Putting Flutter Issue to Bed |
| psm(at)att.net wrote: | Hi Dave,
regard, i[b]ndustry standard handling of this question has shown aileron
designs except for those that have fabric covered ailerons.[/b] Please
some such thing.
Paul
XL Grounded
I just balanced the ailerons and the elevators for a DC4 which are fabric and there are many other aircraft with mass balanced fabric covered ailerons. Cheers
| [/quote]
Posted: Tue Jun 02, 2009 2:50 am Post subject: Putting Flutter Issue to Bed |
The comment was actually in response to the stick gradient concern. It had
stuck in my mind from reading your email and my response was off target I
guess. I have thought that the stiff roll and very easy pitch was a sort of
odd arrangement, but maybe that's just something to get used to. I admire
your resolve in this matter, do you know if there are any certified light
aircraft designs with metal ailerons that do not use mass balance? I
understand that it is common practice, but surely CH is not the first to
break with tradition. My feeling is that while it is common, I would be
unlikely to want to add any structure that does not actually need to be
present.
Posted: Tue Jun 02, 2009 3:25 am Post subject: Putting Flutter Issue to Bed |
Hi Dave,
I don't have universal knowledge of what light aircraft designs
exist. I do know from personal experience that it is extremely
common, perhaps almost universal, that airplane designs call for
different control pressure and movement in different axes. While
this seems to be a criteria that some aviation magazine authors think
is important (i.e, "Control Harmony") I have not heard anyone suggest
there was a safety issue here.
In general, I agree with you completely that it is a bad idea to add
unnecessary features to a light plane design. If nothing else the
added weight and expense are things to avoid.
It is the question of how you define what is necessary and what is
not that makes this problem so perplexing. For me, the NTSB saying
the changes are necessary is enough. For others it is not.
I make no claim that I am right and other builders are wrong. This
is a very difficult problem to resolve, and those who believe there
is no need to fix anything have a lot of facts to support their
decision. Indeed this is not a democratic situation. We don't need
to agree or come to a consensus decision.
Building, and particularly flying, experimental airplanes is, and
will always be, a dangerous activity. Each builder and owner must
decide for himself just how much risk is acceptable. This applies
just as much for risks that are well known as for ones that are
subject to question.
My own decision was made based on my own criteria and my own
situation. I searched my soul and discussed the situation with my
wife (who also flies) and reached the conclusion I would ground my
plane, as suggested by the NTSB, until the two mentioned changes were
implemented. If I am demonstrating resolve, it is merely that there
have been no changes in the situation that would convince me I should
change my own decision.
Best regards,
Paul
XL grounded
At 03:49 AM 6/2/2009, you wrote:
| Quote: | The comment was actually in response to the stick gradient concern.
It had stuck in my mind from reading your email and my response was
off target I guess. I have thought that the stiff roll and very easy
pitch was a sort of odd arrangement, but maybe that's just something
to get used to. I admire your resolve in this matter, do you know if
there are any certified light aircraft designs with metal ailerons
that do not use mass balance? I understand that it is common
practice, but surely CH is not the first to break with tradition. My
feeling is that while it is common, I would be unlikely to want to
add any structure that does not actually need to be present.
tonyplane(at)bellsouth.ne Guest
Posted: Tue Jun 02, 2009 6:16 am Post subject: Putting Flutter Issue to Bed |
"Indeed, the NTSB identified another problem - one which I think might
| Quote: | explain all the accidents. It is the stick gradient problem that makes it
added."
Maybe I missed it (see attached extracts below from the NTSB Report) but I
do not see
where the NTSB demanded the light stick forces on the XL (also found on many
other aircraft) be "fixed", nor demanded balancing of the ailerons.
I personally believe that some if not all of the structural failures were
caused improper use of the stick, also know to be a wing removal device on
most aircraft.
Tony Graziano
XL; Jab; N493TG 495 really enjoyable hours.
Recommendations extracted from the NTSB Report
Require a comprehensive evaluation of the wing and aileron system on the
Zodiac CH-601XL, including ground vibration tests, to identify design and/or
operational changes that will reduce the potential for flutter; the
evaluation should give significant consideration to the benefits of
installing mass-balanced ailerons and should also address the adequacy of
cable tension values specified by Zenair.
Evaluate the stick-force gradient of the Zodiac CH-601XL at the maximum aft
center of gravity and notify pilots of the stick-force gradient that occurs
at the aft center of gravity, especially at the higher G forces.
Potential Role of Stick Forces (Extracted from the NTSB Report)
In an effort to identify potential factors that might have contributed to
the many in-flight breakups of CH-601XL airplanes, and mindful of the fact
that high loads can cause structural failure, the Safety Board examined the
control stick forces required to generate high maneuver loads19 on the
accident airplane model. Zenair provided the Safety Board with a flight test
report that had been used to validate the airplane design under ASTM
standards. The report included data on the stick forces required to generate
maneuver loads or Gs.20 The term "stick force per G" refers to the control
force gradient that is derived from flight test data. Data from the
Comparative Aircraft Flight Efficiency Foundation's21 airplane performance
reports show that the stick force per G on other airplanes is similar to
that of the Zodiac CH-601XL except that, on
the CH-601XL, the stick-force gradient lessens distinctly as loads increase
above 2.5 Gs.22 The lessening of the gradient continues as loads surpass 4
Gs. As a result, at high Gs, a moderate increase in stick force could result
in a larger than expected increase in maneuver loads. A sufficient
stick-force gradient is required for pilots to maneuver an airplane safely.
The Safety Board recognizes that experimental and light sport airplanes
typically exhibit lighter stick forces than airplanes certified under 14 CFR
Part 23 and that, if properly trained, pilots can safely maneuver airplanes
with relatively shallow gradients. However, even experienced pilots may find
control difficult if the gradient is not constant but instead lessens as Gs
increase. With a lessening stick-force gradient, it becomes easier to
inadvertently overcontrol the airplane and reach higher acceleration forces
than intended. Zenair has expressed concern that pilots may be
overcontrolling the airplane with large or aggressive stick movements. On
May 10, 2007, the designer wrote the owners and pilots of Zodiac airplanes
an advisory letter, which included the following: The Zodiac aircraft has a
large amount of elevator control. ... Pushing the stick rapidly full forward
at cruise speed-even briefly-can result in serious damage to the airframe.
Caution must be exercised to not inadvertently push the stick rapidly to its
limits (i.e. while stretching, reaching into the rear baggage compartment,
etc.). In July 2007, the designer issued the following update: Owners should
take note that the CH-601XL has relatively light pitch control forces and
that it is possible to exceed the positive (+6) and the negative (-3)
ultimate load factors if forcing the controls in a very rough or sudden
manner. Pilots usually become familiar with the maneuvering characteristics
of an airplane while operating routinely between the 1 G and 1.5 Gs common
during normal flight. Higher G forces are often disconcerting, and a
lessening of the stick-force gradient may go unnoticed. In addition, the
stick forces are least when operating at the maximum aft center of gravity.
Although the Zodiac designer has advised pilots of the light stick forces,
the Safety Board concludes that pilots may not be aware of the change in the
effect of stick forces that occurs while maneuvering at higher Gs.
Therefore, the Safety Board believes that the FAA should evaluate the
stick-force gradient of the CH-601XL at the maximum aft center of gravity
and notify pilots of the stick-force gradient that occurs at the aft center
of gravity, especially at the higher G forces. In addition, the Safety Board
believes that the FAA should work with ASTM International to develop
requirements to be included in the standards for light sport airplanes that
provide for stick-force characteristics that will minimize the possibility
of pilots inadvertently overcontrolling the airplane.
22 The Zodiac designer also provided flight test data for the CH-600/601
(non-XL) airplanes. The data show that the stick forces are generally
somewhat lighter than those experienced on the CH-601XL but that the
gradients are constant until the airplane reaches at least 4 Gs.
ggower_99(at)yahoo.com Guest
Posted: Tue Jun 02, 2009 6:54 am Post subject: Putting Flutter Issue to Bed |
Hello Paul,
Good explanation...
If I will ask my wife if I should be flying or not... I for sure will also be grounded.
Saludos
Gary Gower
Flying from Chapala, Mexico.
701 912S 240 hrs
building 601 XL Jab 3300
Macho Flyer, Wife grounded
Do not archive.
--- On Tue, 6/2/09, Paul Mulwitz <psm(at)att.net> wrote:
--> Zenith-List message posted by: Paul Mulwitz <psm(at)att.net (psm(at)att.net)>
Hi Dave,
My own decision was made based on my own criteria and my own situation. I searched my soul and discussed the situation with my wife (who also flies) and reached the conclusion I would ground my plane, as suggested by the NTSB, until the two mentioned changes were implemented. If I am demonstrating resolve, it is merely that there have been no changes in the situation that would convince me I should change my own decision.
Best regards,
Paul
XL grounded
Gig Giacona
Joined: 10 Jan 2006 Posts: 1409 Location: El Dorado Arkansas USA
Posted: Tue Jun 02, 2009 8:32 am Post subject: Re: Putting Flutter Issue to Bed |
| Quote: | Recommendations extracted from the NTSB Report
Recommendation met by GVT report.
Issue already addressed before it was recommended. We were advised to add an elevator stop quite some time ago. I added mine the weekend after it was recommended. Took about 20-30 minutes. Any additional issue can easily be handled with training. I'd like to see Zenith along with the FAA come out with a requirement much as was done with SFAR 74. This had a major impact with the insurance companies that were insuring Robinson helicopters. In something like a 601 specialized training would reduce accidents to as close to zero as could be hoped and would have the long term effect of making up for, statistically, the accidents we have already had. Not to mention it would be a plus for those CFI-LS out there that choose to use 601XLs.
601XL Under Construction
Juan Vega Jr
Posted: Tue Jun 02, 2009 12:10 pm Post subject: Putting Flutter Issue to Bed |
Paul,
you need to sell yuor plane, obviously you will not be happy until you are flying a Cessna.
Juan
jmaynard
Posted: Tue Jun 02, 2009 12:53 pm Post subject: Putting Flutter Issue to Bed |
On Tue, Jun 02, 2009 at 04:03:58PM -0400, Juan Vega wrote:
| Quote: | you need to sell yuor plane, obviously you will not be happy until you are
flying a Cessna.
Horse exhaust and hogwash. Just because a plane is an experimental (or SLSA)
does not mean that it cannot adhere to generally accepted standards of safe
aircraft design, or that it gets a free pass for failing to do so. Would you
argue that a pilot of an experimental aircraft need not be trained to the
same standards as a pilot of a 172? It's the identical case.
Posted: Tue Jun 02, 2009 12:55 pm Post subject: Putting Flutter Issue to Bed |
Gig,
Although I do not believe anyone would criticize specialized training in the
XL (or for that matter any airplane you have not flown before). I find that
the XL is pretty easy to fly and is forgiving. I had never really flown the
XL before I flew my XL's first flight.(had a short ride at the controls at
the Zenith factory, but was not permitted to stall or land it).
I do not believe that the XL has a reputation for stall/spin type accidents
common to many other airplanes; in fact, during my Phase I and sometimes
when I do "air-work", I have purposefully tried cross controlling in various
flight regimes ( SLOW descending turns etc) and never have had the airplane
roll off into a departure. I have had it in stall buffet conditions and have
tried to get it to depart left or right also without success. I believe I
could get the airplane to depart, but I would have to really be highly
uncoordinated, or really stomp the rudder full during the stall and hold it
until probable departure.(have not tried this and do not plan to - unless
someone other than me wants to do a complete spin evaluation : ).
I believe that what everyone should be aware of is that you can easily
induce large elevator deflections with out trying hard - not a problem,
except at high speeds.
I really like the stick forces in pitch and wish the aileron were was a
little more "sensitive", but the ailerons also require little stick movement
(with more force) to start rolling/turning. I have no problems trimming in
roll or pitch.
Tony Graziano
XL/Jab; N493TG; 496 hrs/1098 landings in my XL.
Gig Giacona
Posted: Tue Jun 02, 2009 1:00 pm Post subject: Re: Putting Flutter Issue to Bed |
| jmaynard wrote: | On Tue, Jun 02, 2009 at 04:03:58PM -0400, Juan Vega wrote:
flying a Cessna.
Jay
I don't think that is point Juan was trying to make. I think the point is that there is no reasonable act that Zenith could take that would make the person he replied to happy with they aircraft. The problem being this particular poster thinks that anything the NTSB says is golden and he is also under the misconception that the NTSB has the power to demand anything.
And just for the record the pilot of a 601XL doesn't have to be trained to the same level as the pilot of a 172.
jmaynard
Posted: Tue Jun 02, 2009 1:16 pm Post subject: Putting Flutter Issue to Bed |
On Tue, Jun 02, 2009 at 02:00:35PM -0700, Gig Giacona wrote:
| Quote: | I don't think that is point Juan was trying to make. I think the point is
anything.
I disagree. Zenith could come up with a balance weight kit for hte US, or
just make the one they developed for the UK avalable here, and find a fix
for the G force gradient issue, and I think Paul would be happy,
| Quote: | And just for the record the pilot of a 601XL doesn't have to be trained to
The differences have to do with the limited privileges of a sport pilot; the
standards for those elements that are in common are identical.
Perhaps I should have said "Skycatcher" rather than 172. After all, that's a
Cessna. In any event, the idea that sport pilots are less well trained than
private pilots needs to be shot down in flames whenever it comes up. There's
no reason in the word a sport pilot should be any less well trained than a
private pilot. (This was a hot button issue for my CFI-SP examiner, as it is
for me.)
The sport pilot rule is still controversial in some quarters. Accepting
anything less than the same level of safety in aircraft that is given by
part 23, and anything less than the same standard of training as a private
pilot, can only harm the cause - because it gives the naysayers ammunition.
Gig Giacona
Posted: Tue Jun 02, 2009 1:39 pm Post subject: Re: Putting Flutter Issue to Bed |
The issue I was trying to address with added training is the one that the NTSB calls out regarding decreased elevator pressure in the higher G edges of the flight envelope. I have no personal evidence that these exist but I'll take the NTSBs word for it until my plane is flying. I intend to address this during phase 1 testing. I have it scheduled in for hour 28.
| tonyplane(at)bellsouth.ne wrote: | Gig,
roll or pitch.
Tony Graziano
Gig Giacona
Posted: Tue Jun 02, 2009 1:52 pm Post subject: Re: Putting Flutter Issue to Bed |
| jmaynard wrote: |
Why should there be a weight added? The GVT shows that the system, as designed, works. Putting extra weight out in the wing can only add additional stress on the design and God only knows what that will do.
The G force gradient can be dealt with with training if it exists. You have a flying example can you tell me if the G force gradient does in fact exist? And if so are you capable of flying the plane with that gradient now that you know about it? If the answer to that last one is yes then you have just proved my point about training if you can't you need to ground yourself.
for me.)
I doubt anyone thought you'd have the same level of safety in S-LSA as you would with part 23 aircraft. Why do you think the the FAA limited the weight to 1320 lbs and only allowed it to be a pilot plus one aircraft. The answer is to keep down the damage on the ground and the body count down in an accident. Otherwise they would let LSA pilots fly 172s with 4 people on board in VFR/Day only.
paulrod36(at)msn.com Guest
Posted: Tue Jun 02, 2009 2:23 pm Post subject: Putting Flutter Issue to Bed |
<?xml:namespace prefix="v" /><?xml:namespace prefix="o" /><![endif]--> Paul--- Has anybody played with the idea of installing two equal strength coil or flat springs somewhere at the bottom of the control stick, to add resistance as the stick increases deflection? They might have to be fairly stiff, but they might deter the heavy-handed or unwary from bankin' and yankin'. Just a thought.
Paul R.
Posted: Tue Jun 02, 2009 2:54 pm Post subject: Putting Flutter Issue to Bed |
Hi Paul,
I am an experienced engineer, but my field is electronics rather than
mechanical or aeronautical design. I don't know the best way to deal
with the stick design problem. I really hope the experts at
Zenair/Zenith will design and issue an appropriate change.
That said, I will make a comment or two based on things I have heard
- mostly on this list.
I think adding springs or bungie cords to the stick would make the
forces heavier, but might not have any impact on the real
problem. The real problem seems to be that it gets progressively
easier to pull G's as you pull more G's. So, if you are already
pulling 3 G's a little more pull on the stick might get you to 6 G's
rather than 3.2.
The change that seems to be a more appropriate fix is to add a dense
weight to the bottom of the stick. This would be impacted by pulling
G's so that the more force on the weight the harder it gets to
increase the load on the wings. This would still present the nice
light stick forces when the plane is lightly loaded with G's but make
it progressively more difficult to add more load.
Paul
XL Grounded
At 03:22 PM 6/2/2009, you wrote:
| Quote: | Paul--- Has anybody played with the idea of installing two equal
Paul R.
