		captainron1(at)cox.net Guest
				 Posted: Mon Jun 01, 2009 12:22 pm    Post subject: WRT M3X prop boom measurements. |
				Hi Brad
 We got quite a List with a big library of pictures. If you need info on the Suzuki you can find it at FlyGeo(at)yahoogroups.com
 One of the moderators will approve you pretty quick. Have fun and post any questions that you can think of we have some very apt people there about the motor, and even two fellows that will sell you the whole motor package for the Kolb. If you got the money that's probably the best route to go.
 You could go back and review the libraries, all the posts are there. I think we have discussed that motor and the different types in great detail. Bob B can correct me but I think the latest motor that is consensus recommended for the big Kolbs is the 1.3l 16V SOHC from the 2000 Model Geo / Sprint. The little Kolbs can probably do fine with the 1. ltr Suzi motor.
 I am sure that pictures of my motor mount are already there but the latest batch has the final configuration with all the bracing that I felt were needed.
 I will post my most recent photos today sometime there.
 ---- Brad Stump <sky-king(at)inbox.com> wrote:
 Hay Ron,Iam thinking about starting to work on a Suzuki 1.3 non turbo to replace my Hirth by some time next year.Would like to see any pics as you progress..Thanks
 [quote] --
  |  | - The Matronics Kolb-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Dana
				 Posted: Mon Jun 01, 2009 3:47 pm    Post subject: WRT M3X prop boom measurements. |
				At 01:10 PM 6/1/2009, Ron  (at)  KFHU wrote:
  	  | Quote: | 	 		  My intent was to dissuade others from the notion that a prop is a reaction
 motor such as a rocket, i.e. throwing a mass backwards to cause Newton's
 law of equal reaction.
 A prop is not a rocket in that the mass originates in a rocket, but the
 prop does accelerate aft the air passing through it, and Newton's law of
 reaction says that the force exerted in pushing the air back is equal to
 the force the air exerts pushing the prop forward.  Thrust is equal to the
 mass flow times the velocity change, as I said.
 I'm not idly speculating... I kinda had to study this stuff when I was
 earning my aerospace engineering degree...
  	  | Quote: | 	 		  Anyway I am chuckling here thinking that drinking a Heineken after a long
 day and then posting something of a serious nature does not really further
 the cause of science.
 OK, I'm done with science/engineering for tonight too... don't care for
 Heineken, think I'll go open an Anchor Steam.
 -Dana
   The greatest threat to western civilization are people whose fear of
 other people's liberty exceeds the love of their own.
		JetPilot
				 Posted: Mon Jun 01, 2009 4:42 pm    Post subject: Re: WRT M3X prop boom measurements. |
				Captain Ron,
 It would be a rather expensive test that will surely have poor results.  Lots of prop testing has been done on Kolbs, and lots of other planes by Warp Drive,  Power Fin, And IVO.  These guys know a LOT about props, and have done the research.  Whenever I call any of these companies, they are very knowledgeable about prop/speed/motor combinations and what works, and what does not.  If they could sell more props and make a bunch of money by selling us new multi blade smaller diameter props that would work better, they would !  If you have doubts I would suggest you talk to some of these prop experts.  I'm just trying to save you the trouble and expense of an experiment that has a known outcome...
  _________________ "NO FEAR" -  If you have no fear you did not go as fast as you could have !!!
Kolb MK-III Xtra, 912-S |
		by0ung(at)brigham.net Guest
				 Posted: Mon Jun 01, 2009 7:31 pm    Post subject: WRT M3X prop boom measurements. |
				Long winded post about props.  If you are not interest hit delete.
 I have seen the charts that show small diameter props turning fast rpm's
 reach their maximum efficiencies at high speeds.  AND   large diameter
 props reach their maximum efficiencies at slow speeds.
 SO   when building a plane the first thing you want to do is to determine
 what the plane is to be designed to do.   That will determine the speed
 range of the design, the speed of the design will determine the prop
 diameter and pitch.
 That said, the most efficient prop is a "1" blade prop... you read it right
 "one" blade.  The problem with a one blade prop is keeping things in
 balance.  And yes it has been experimented with,  you have to have a counter
 balance on the other side,  and by playing with the angle of a pivot you can
 make it more or less a constant speed prop.  When it is pulling hard it will
 cone forward and if mounted at the correct pivot angle it will reduce the
 pitch,,,  when the plane is up to speed the centrifugal force causes it to
 run in a flatter coneing angle, increasing the pitch.   Why do I mention the
 one blade prop as the most efficient????  because every prop or wing going
 through the air has two types of drag acting on it.
 Drag:   drag may de subdivided into induced drag and parasite drag.  Induced
 drag is simply the drag created in the process of developing lift / thrust.
 In addition to the induced drag caused by the development of lift, there is
 parasite drag due to skin friction and form.  This term is used because
 parasite drag is not directly associated with the development of lift.
 Parasite drag is present ant time the wing or prop is moving through the
 air, even in a zero lift condition.
 The more blades the more parasite drag.  The more parasite drag, the more HP
 will be used up that is not creating lift / thrust,  the more hp not
 producing thrust  the less efficient the prop / wing.
 Now props work best when set to the best pitch angle at cruise, as to be
 able to use up the available HP.  Fast aircraft have a high pitch angle.
 And if set as a constant pitch, they have very poor takeoff performance.
 That is why they put on a variable pitch prop on fast aircraft.  So they can
 maximize the efficiency at both slow and fast speeds.   At the speed that
 the kolb line of aircraft fly,,  the variable pitch seems unnecessary.
 Because we get good take off performance and flight with one pitch.  Look at
 the production aircraft that fly in the speeds that the kolbs fly.  They
 have very simple fixed pitch props.  Generally a two blade prop.   Now as
 the HP increases and you start to have prop ground clearance problems, and
 you cant pitch the prop to use up the available HP in cruise, by setting the
 pitch for maximum efficiency,  then you add an additional blade.
 Now on a pusher there is a different reason to add the third blade sooner
 than you would on a tractor,  that is because of the noise developed by
 having a prop with greater pitch go into and out of the disturbed airflow.
 The smaller pitch on a three blade seem to make less noise.  But we trade
 the quieter operation  for less efficiency caused by increased parasite
 drag.
 On most aircraft the prop diameter is limited by ground clearance.    Has
 anyone ever  seen a Cessna 150, or a j5 cub with a 45 inch 6 blade prop?  If
 it were more efficient it would be the norm.
 Boyd Young
 Kolb MkIII C   580+ hours and counting
 Brigham City Utah.
		russ(at)rkiphoto.com Guest
				 Posted: Tue Jun 02, 2009 6:18 am    Post subject: WRT M3X prop boom measurements. |
				Boyd
 Excellent comments in re prop blades. Straightforward and, more
 importantly, accurate.
 Thank you
 Russ K
 On Jun 1, 2009, at 11:30 PM, b young wrote:
  rpm's
  determine
  speed
  diameter and pitch.
  it right
  a counter
  pivot you can
  hard it will
  reduce the
  causes it to
  mention the
  wing going
  drag.  Induced
  thrust.
  there is
  because
  through the
  the more HP
  to be
  angle.
  performance.
  they can
  speed that
  pitch.  Look at
  They
  Now as
  problems, and
  setting the
  sooner
  developed by
  airflow.
  trade
  parasite
  drag.
  clearance.    Has
  prop?  If
  Boyd Young
  Brigham City Utah.
				 Posted: Tue Jun 02, 2009 11:08 am    Post subject: WRT M3X prop boom measurements. |
				A couple of years ago I pretty much had said to Bob B pretty much what I will say again.
 The claim that a singe blade prop is more efficient than say a 2 blade prop does not stand the test of reason. I have heard that claim since I was a kid, that a one blade prop is better but never quite understood it even back then.
 As Bob just stated the one blade prop is supposedly more efficient because it always slices in undisturbed air.
 Well !!! As I said a couple of years ago that is false, the claim that a one blade prop is more efficient is false!
 Lets for example take my airplane in cruise flight I believe its a 80 inch bore spiral. In any one revolution of the prop you move forward 80 inches.
 Okay,,,?  so the second blade is always ahead of where the first blade was by 40 inches. In other words at all times unless maybe right at the beginning of the take off roll the following blade is always in undisturbed air. On a four blade prop each blade is always 20 inches forward  than the previous one and so on.
 Why we don't have a 4 blade prop on a J3? Well I doubt it was certified with one back in the Golden days of aviation. But I have seen glider tow airplanes using 4 blades for towing. On a J3 we are not going to see all that much difference in cruise but we will see it in climb. The drag of the airframe gets ever greater as the speed increases so prop efficiency will only help so much, but in a climb where the speed is low there we see the better efficiency, the exponential increase in drag is still less noticed at low air speeds. But in our draggy Kolbs we may see it for other reasons one of which the turbulent air for a pusher, there the multi blade will shine very nicely because it is able to "catch" more of the "crappy" air behind us.
 ---- russ kinne <russ(at)rkiphoto.com> wrote:
 Boyd
 Thank you
 Russ K
  rpm's
  determine
  speed
  diameter and pitch.
  it right
  a counter
  pivot you can
  hard it will
  reduce the
  causes it to
  mention the
  wing going
  drag.  Induced
  thrust.
  there is
  because
  through the
  the more HP
  to be
  angle.
  performance.
  they can
  speed that
  pitch.  Look at
  They
  Now as
  problems, and
  setting the
  sooner
  developed by
  airflow.
  trade
  parasite
  drag.
  clearance.    Has
  prop?  If
  Boyd Young
  Brigham City Utah.
 kugelair.com
		sky-king(at)inbox.com Guest
				 Posted: Tue Jun 02, 2009 11:34 am    Post subject: WRT M3X prop boom measurements. |
				Hi Russ,
 I hope i'am not asking a dumb question here,but I need some advice.My engine's peak Hp is at 6500 rpm,I climb out at 700-800 fpm,and cruse at 65-70 mph.If I increase the pitch of my 3-blade prop, will I increase my cruse or climb rate?
 [quote] --
				 Posted: Tue Jun 02, 2009 11:56 am    Post subject: WRT M3X prop boom measurements. |
				Ron, you are referencing the the wrong "Bob"
 I have stayed out of this pointless joust fest (with the exception of
 the heli viewpoint)  because
 it has gone beyond my attention span.
 Important update:  between beers I have managed to complete the steel
 gear leg installation with a healthy
 guess as to alignment, hauled the old beast up the hill to the summer
 bug infested shelter (carpenter bees the size of wrens) and somehow
 managed
 to avoid dinging another delicate surface.  I have a Powerfin 2 blade
 hub creeping via UPS across the USA that I will be
 comparing with my current 2 blade WD setup.  To be fair it will be
 65" powerfin against 70" WD so it really isn't
 apples to apples.
 By the time I get the wings back on with the assistance of my
 brother, the summer should be half over. With any luck I may? get as
 much time
 in this season as John H. did in one week.  -nahhh
 BB
 On 2, Jun 2009, at 3:07 PM, Ron (at) KFHU wrote:
  forward 80 inches.
  Boyd
  Thank you
  Russ K
 > rpm's
 > diameter
 > determine
 > speed
 > diameter and pitch.
 > it right
 > a counter
 > pivot you can
 > hard it will
 > reduce the
 > causes it to
 > mention the
 > wing going
 > drag.  Induced
 > thrust.
 > there is
 > because
 > lift.
 > through the
 > the more HP
 > to be
 > angle.
 > performance.
 > they can
 > speed that
 > unnecessary.
 > pitch.  Look at
 > They
 > Now as
 > problems, and
 > setting the
 > sooner
 > developed by
 > airflow.
 > trade
 > parasite
 > drag.
 > clearance.    Has
 > prop?  If
 > Boyd Young
 > Brigham City Utah.
  kugelair.com
				 Posted: Tue Jun 02, 2009 2:10 pm    Post subject: WRT M3X prop boom measurements. |
				Brad
 You should be asking Boyd Young or John  Hauck. They're much more
 informed than  I am.
 In any case I think testing is the only way to know for sure.
 Russ K
 On Jun 2, 2009, at 3:35 PM, Brad Stump wrote:
  Hi Russ,
		Dana
				 Posted: Tue Jun 02, 2009 3:09 pm    Post subject: WRT M3X prop boom measurements. |
				At 03:07 PM 6/2/2009, Ron  (at)  KFHU wrote:
  	  | Quote: | 	 		  A couple of years ago I pretty much had said to Bob B pretty much what I
 will say again.
 even back then...
 For aircraft like ours, I agree that there wouldn't be much if any
 measurable advantage to a one blade prop, and the associated problems would
 outweigh any slight advantages.  However, they have been used to advantage
 on some model airplanes... control line "speed" ships that can do 200mph,
 with engines turning around 30,000 rpm.  With such tiny props turning so
 fast, the blades ARE close enough together that going to one blade helps.
 -Dana
   A goverment that fears arms in the hands of it people should also fear ROPE!
		Dana
				 Posted: Tue Jun 02, 2009 3:10 pm    Post subject: WRT M3X prop boom measurements. |
				At 03:35 PM 6/2/2009, Brad Stump wrote:
  	  | Quote: | 	 		  I hope i'am not asking a dumb question here,but I need some advice.My
 If your prop is already pitched optimally for climb, increasing the pitch
 will improve your cruise at the expense of climb.  If it's pitched too flat
 for best climb, you'll improve both.  If you already have too much pitch
 for best cruise, both may suffer.
 Generally a prop is pitched for a good compromise between climb and cruise,
 often a bit more one way or another... so you hear people talk about a
 "climb prop" or a "cruise prop".  On a typical small slow plane, IIRC the
 difference is about 2" of pitch.
 -Dana
				 Posted: Tue Jun 02, 2009 3:51 pm    Post subject: WRT M3X prop boom measurements. |
				Sorry about the mix up.
 Its kinda fun but its getting boring, I think I have reached the end of my stamina on this subject.
 Good for you about the gear legs, I am ever more worried about the ones that came with the kit on my M3x. with the big motor which I estimate my power unit flying weight complete to be around 200 pounds. Them skinny 7075 legs will not take much to start looking like a soggy noodles.
 managed
 apples to apples.
 much time
 BB
  forward 80 inches.
  Boyd
  Thank you
  Russ K
 > rpm's
 > diameter
 > determine
 > speed
 > diameter and pitch.
 > it right
 > a counter
 > pivot you can
 > hard it will
 > reduce the
 > causes it to
 > mention the
 > wing going
 > drag.  Induced
 > thrust.
 > there is
 > because
 > lift.
 > through the
 > the more HP
 > to be
 > angle.
 > performance.
 > they can
 > speed that
 > unnecessary.
 > pitch.  Look at
 > They
 > Now as
 > problems, and
 > setting the
 > sooner
 > developed by
 > airflow.
 > trade
 > parasite
 > drag.
 > clearance.    Has
 > prop?  If
 > Boyd Young
 > Brigham City Utah.
  kugelair.com
 kugelair.com
				 Posted: Wed Jun 03, 2009 7:51 am    Post subject: WRT M3X prop boom measurements. |
				 	  | Quote: | 	 		   Hi Russ,
 Brad
 Lets think out loud here.
 With a plane with a constant speed prop they always set to  a fine pitch for
 takeoff allowing max rpm.   This equals max take off performance, climb
 rate.
 When the same plane gets up to speed they increase the pitch, reducing the
 rpm.  This gives them a little faster cruse.  It allows the prop to use up
 the HP with out over reving.
 This becomes a larger factor when the aircraft speed is above 130 - 150   or
 so.
 In your case,  if you climb at 6500 at wot,,, then at straight and level you
 will be over reving.   So you have to pull the power back.  If you increase
 the pitch you will climb at (lets say for example)  6250 rpm..  at that rpm
 your engine is not putting out the full rated hp.(slower climb)   But in
 straight and level flight you will pull 6500  and put the full hp to the
 prop. Thus going faster, because you have not had to pull the power back.
 Boyd Young
				 Posted: Wed Jun 03, 2009 3:47 pm    Post subject: WRT M3X prop boom measurements. |
 -Dana
  	  | Quote: | 	 		  >>>>>>>>>>>>>>>>>.
 Dana
 For a 1 blade to do its job effectively I would think that it should be
 installed on a slick go fast plane.  The cruise would be in keeping with the
 large pitch angle needed to use up the HP. And less of the HP being used up
 as parasitic drag.  To put it on a slow aircraft the prop would use up the
 hp but be stalled,  therefore not creating the thrust that it could do on a
 faster craft.
 And as for the 1 blade design being the most efficient,,  I should have
 clarified it by saying in cruise,  and in a tractor configuration, where it
 is not slapping the large pitch against the disturbed air,,   climb would
 probably not be as good even with the pitch reducing coning angle.
 Boyd Young
		lucien
  Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
				 Posted: Wed Jun 03, 2009 5:33 pm    Post subject: Re: WRT M3X prop boom measurements. |
				[quote="by0ung(at)brigham.net"] 	  | Quote: | 	 		   Hi Russ,
 That sounds about like the envelope of my old FSII. Mine had the 503 with 3.47:1 C box and 68" WD 3-blade taper tip. I'd say thats about the best combo you can get on the FSII, tho admittedly I only had one other FSII in my area to actually compare to. He had the 2.58 B box and a 2 blade woody, I could outclimb him just a little bit, tho he seemed to have a little higher top end than my best climb pitch setting.
 For a while I ran about 6400 on climbout on mine but it would easily get to redline in level flight. The rule of thumb of bumping just up to redline at WOT straight and level will give the best compromise. With the prop set that way on my FSII that gave me about 6200 on climbout which was still plenty good climb and gave a comfortable 65mph cruise at about 5300. Just under 3 gph.
 I sure kinda miss that plane.... don't know if I ever mentioned that....
 LS
  _________________ LS
Titan II SS |
		aslsa.rng(at)gmail.com Guest
				 Posted: Wed Jun 03, 2009 8:28 pm    Post subject: WRT M3X prop boom measurements. |
				http://www.ultraligero.net/Cursos/varios/helice_de_una_pala.pdf
 [url=http://www.ultraligero.net/Cursos/varios/helice_de_una_pala.pdf][/url]Rick
 On Wed, Jun 3, 2009 at 6:35 PM, b young <by0ung(at)brigham.net (by0ung(at)brigham.net)> wrote:
 [quote] --> Kolb-List message posted by: "b young" <by0ung(at)brigham.net (by0ung(at)brigham.net)>
  -Dana
  Dana
  faster craft.
  Boyd Young
  http://forums.matronics.com
  le, List Admin.
				 Posted: Thu Jun 04, 2009 3:09 am    Post subject: WRT M3X prop boom measurements. |
				Boyd,
 Thank you and others who have offered advice.Iam going to increase the pitch this week-end and see if this will make go faster.
 [quote] --
		JetPilot
				 Posted: Thu Jun 04, 2009 7:12 am    Post subject: Re: WRT M3X prop boom measurements. |
				Prop pitch will have a huge effect on your cruise and top speed.   I have done a lot of experimenting with it on my MK III Xtra with the 912-S and 3 blade Warp Drive prop.
 When I pitched for 5800 RPM climb, which is the maximum RPM for the Rotax 912-S, I get the best acceleration and climb, but cruise speed is horrible.  It takes a lot more RPM, power, and fuel to cruise at 75 MPH.  All my high end speeds were way down, top level flight speed is limited by RPM.  If all one ever did was climb, the low pitch / high RPM setting might be ok, but for overall flying, it really sucks
 With the prop set for 5200 RPM climb, I give up a couple hundred feet per minute in climb, but 75 MPH cruise is achieved at a much lower RPM, and  power setting with significantly lower fuel usage, and top level flight speed is much better.   The cruise with lots of pitch in the prop is so much improved, I will gladly give up a couple hundred RPM in climb.    The added advantage is that not running the engine to its absolute maximum RPM should increase its life.   The Rotax 912-S is designed to run at high RPM's, but the 5500 - 5800 RPM range is time limited by Rotax for a reason, and it will probably increase the engines life keep it at 5500 RPM and below and just not to try to get every last HP out of it.
		lucien
				 Posted: Thu Jun 04, 2009 7:33 am    Post subject: Re: WRT M3X prop boom measurements. |
				 	  | JetPilot wrote: | 	 		  Prop pitch will have a huge effect on your cruise and top speed.   I have done a lot of experimenting with it on my MK III Xtra with the 912-S and 3 blade Warp Drive prop.
 Mike |
 BTW, this is also true of the 2-strokes but a bit higher degree than the 912. It's a common misconception that they last longer running at 6000+ rpm continuously. Actually, the "sweet spot" for continuous operation with them is in the 5200 to 5500 range, at somewhere in the neighborhood of 2/3 throttle.
 Also, they can't run at full throttle on a continuous basis. The TBO goes down significantly when they're run wide open all the time regardless of the rpm and something will eventually give (usually the con rod big end is the first to go). Especially the 582, tho the 503 and 447 can take that for a while longer.
 The 912 is sturdier in that regard as they can run WOT continuously below 5500 rpm (IIRC from the operator's manual).
 The sweet spot on my 912ULS seems to be around 5050 rpm....
 LS
Titan II SS |
