A-2200 oil leak
Goto page 1, 2  Next
ces308
PostPosted: Sun Jun 07, 2009 4:57 pm    Post subject: A-2200 oil leak Reply with quote
Hi !
I am new to this list and I have a Kolb Mark 3 Xtra with a A-2200 jabiru solid lifter engine on it with 20.6 hrs on it. Everything has been going great but for a little seepage coming from the ,what looks to be ,the cam cover in the front of the engine under the crank shaft.My Question is, can I remove the 4 allen head bolts,remove the cover and either make a gasket of put a sealent on it to stop the leak?If I take the bolts out ,are they holding anything in side the engine in that area?
chris ambrose
Kolb M3X/Jab
N327CS
plus2s
PostPosted: Sun Jun 07, 2009 6:14 pm    Post subject: A-2200 oil leak Reply with quote
Hi Chris
Yes you can do that - It is the oil pump cover. We have also had a leak from the front cranshaft seal directly above the oil pump.
Keith
--- On Mon, 8/6/09, ces308 <ces308(at)ldaco.com> wrote:
Subject: A-2200 oil leak
To: jabiruengine-list(at)matronics.com
Received: Monday, 8 June, 2009, 12:57 PM
--> JabiruEngine-List message posted by: "ces308" <ces308(at)ldaco.com (ces308(at)ldaco.com)>
Hi !
chris ambrose
Kolb M3X/Jab
N327CS
http://forums.matronics.com/viewtopic.php?p=247230#24723= - The JabiruEngine-List Email Forum -nics.com/Navigator?JabiruEngine-List" target=_blank>http://www.matronics.rums.matronics.com/" ; -Matt Dralle, List Admin==========
JohnDRead(at)aol.com
PostPosted: Sun Jun 07, 2009 6:54 pm    Post subject: A-2200 oil leak Reply with quote
Hi Chris;
 If you go to the www.usjabiru.com web site you can down load the engine manual and that will show you all the detail you need. do not archive.
John Read
CH701 - Elbert CO - Jabiru 3300
Phone: 303-648-3261
Fax: 303-648-3262
Cell: 719-494-4567
In a message dated 6/7/2009 7:01:16 P.M. Mountain Daylight Time, ces308(at)ldaco.com writes:
--> JabiruEngine-List message posted by: "ces308" <ces308(at)ldaco.com>
Hi !
chris ambrose
Kolb M3X/Jab
N327CS
http://forums.matronics.com/viewtopic.php?p=247230#247230===============================================
_-= = Use utilities Day ================================================ - MATRONICS WEB FORUMS ================================================ - List Contribution Web Site sp;   ===================================================
An Excellent Credit Score is 750. See Yours in Just 2 Easy Steps!
ces308
PostPosted: Sun Jun 07, 2009 7:15 pm    Post subject: Re: A-2200 oil leak Reply with quote
Thank you....It looks like there is an O ring that goes around the housing??
What did you guys use for a sealent??
chris ambrose
Lynn Matteson
PostPosted: Mon Jun 08, 2009 9:50 am    Post subject: A-2200 oil leak Reply with quote
Don't make a gasket at that location. Use the preferred Loctite 515
sealant per the maintenance manual. If you use a gasket at that
location, you will set the cover too far away from the oil pump
rotor, and probably lose oil pressure. Follow the recommended
procedures in the manual.
What serial number is your engine?
Lynn Matteson
Jabiru 2200, #2062, 671.6 hrs
Sensenich 62x46 Wood prop
Status: flying
On Jun 7, 2009, at 8:57 PM, ces308 wrote:
Hi !
chris ambrose
Kolb M3X/Jab
N327CS
http://forums.matronics.com/viewtopic.php?p 47230#247230
Lynn
Kitfox IV-Jabiru 2200
N369LM
Lynn Matteson
Loctite 515, and NO gasket.
Lynn Matteson
Status: flying
housing??
chris ambrose
http://forums.matronics.com/viewtopic.php?p 47245#247245
Lynn
N369LM
Lynn Matteson
PostPosted: Mon Jun 08, 2009 12:40 pm    Post subject: A-2200 oil leak Reply with quote
Chris, I just got to thinking about something else.....if your engine
only has 20-some hours on it, it could be that the rings haven't
seated yet, and pressure is getting by the rings and putting excess
pressure inside the crankcase. I know you'd like to not have any
leaks, but if you put some hours on the engine, maybe the rings will
seat, and your seepage will go away all by itself.
Also, keep a good eye out for the valve clearances...mine were
getting too loose, too often.
Lynn Matteson
Jabiru 2200, #2062, 672.2 hrs
Status: flying
Hi !
chris ambrose
Kolb M3X/Jab
N327CS
Lynn
N369LM
ces308
PostPosted: Mon Jun 08, 2009 1:38 pm    Post subject: Re: A-2200 oil leak Reply with quote
Thank you Lynn,
I have thought about that also. I have done the valve adjustments per the manual along with the heads and the last check at 15hrs all were good.My next check is at 25hrs along with an oil change.It is very little,but there.The engine runs great...I have been very impressed with the power it has on my M3X.I will wait awhile before I do anything.What about oil?....I have used AeroShell 15-50 forever in my 172's O-320-e2d with terrific luck....what is your opinion on that...??
chris ambrose
ces308
PostPosted: Mon Jun 08, 2009 1:43 pm    Post subject: Re: A-2200 oil leak Reply with quote
...I forgot to tell you my engine is 22A-1228.
chris ambrose
zeprep251(at)aol.com
PostPosted: Mon Jun 08, 2009 4:25 pm    Post subject: A-2200 oil leak Reply with quote
Chris,
I recall someone one on the list mentioned that they had an oil pump cover that had a hole in it.It was leaking through the cover not around it.I never heard any more about it but it sounded like it had a thin spot in the aluminum.Just a thought.
G Aman MK3C 2200 Jabiru 435 hrs
Lynn Matteson
PostPosted: Tue Jun 09, 2009 2:30 am    Post subject: A-2200 oil leak Reply with quote
Well, I got a vote for 15-50 from a former worker at Shell Oil
Company. He said because it was multi-grade, it was thinner at low
temps and therefore got into the bearings quicker. But my flight
instructor/A&P/IA says he feels like he gets better overall
lubrication with single grade Aeroshell W100. Also, I have recently
read that a certain portion of the multigrade stuff is a chemical
that makes it multigrade, and that chemical is non-lubricating, so
some of the "quart of oil" is not oil, so I've gone back to the
straight W100 (SAE 50), and now I use it year around. I heat my
engine in the wintertime, so the oil is already somewhat thin when I
start my engine, so in a sense, I'm doing what the multigrade
does....sort of.
Lynn Matteson
Status: flying
On Jun 8, 2009, at 5:38 PM, ces308 wrote:
Thank you Lynn,
chris ambrose
http://forums.matronics.com/viewtopic.php?p 47352#247352
Lynn
N369LM
Lynn Matteson
PostPosted: Tue Jun 09, 2009 2:33 am    Post subject: A-2200 oil leak Reply with quote
Thanks, I was just going to look and see if you answered that. It
helps me and others to keep track of the engine history and what
Jabiru might have changed over the years. I'm not sure of when they
did it, but my engine had teflon-coated rocker arm bushings, which
failed, and that's why I mentioned checking the valve lash often.
When mine started to go bad, the first indication was a slightly
rough running engine, and loose valve adjustments. Setting them back
to .010" made it run well again. When this happened again, rather
soon, I started looking further and that's when I found brassy-
looking particles in the rocker covers.
Lynn Matteson
Status: flying
chris ambrose
http://forums.matronics.com/viewtopic.php?p 47355#247355
Lynn
N369LM
plus2s
PostPosted: Tue Jun 09, 2009 12:23 pm    Post subject: A-2200 oil leak Reply with quote
Hi Lynn
I replaced two rocker bushes at 900 hrs - now done 993 has been on Shell 15- 50 since the running in oil was drained at 45 hours. We have cold winters and warm summers and have fitted an oil thermostat
keith
--- On Tue, 9/6/09, Lynn Matteson <lynnmatt(at)jps.net> wrote:
Subject: Re: Re: A-2200 oil leak
Received: Tuesday, 9 June, 2009, 10:31 PM
--> JabiruEngine-List message posted by: Lynn Matteson <lynnmatt(at)jps.net (lynnmatt(at)jps.net)>
Thanks, I was just going to look and see if you answered that. It helps me and others to keep track of the engine history and what Jabiru might have changed over the years. I'm not sure of when they did it, but my engine had teflon-coated rocker arm bushings, which failed, and that's why I mentioned checking the valve lash often. When mine started to go bad, the first indication was a slightly rough running engine, and loose valve adjustments.. Setting them back to .010" made it run well again. When this happened again, rather soon, I started looking further and that's when I found brassy-looking particles in the rocker covers.
Lynn Matteson
Status: flying
chris ambrose
http://forums.matronics.com/viewtopic.php?p=247355#247355
Use the Matronics List Features Navigator to f="http://www.matronics.com/Navigator?JabiruEngine-List" target=_blank> http://forums.mat - List Contribution Web Site; -Matt Dralle, List Admin.=========
Lynn Matteson
PostPosted: Tue Jun 09, 2009 4:43 pm    Post subject: A-2200 oil leak Reply with quote
Hi Keith-
Did you look at all the rocker bushings when you did the two? I'm
surprised only two needed replacing.
I decided against the oil thermostat because of the extra fittings
involved, and instead installed a butterfly-type valve to regulate
the air to the oil cooler. It works very well until I forget
sometimes to open it and that's when I wished I had the 'stat. : ) I
can actually leave it closed all winter long (flying on skis), and
this gets me into the habit of sometimes forgetting it, but the
warning light gets my attention.
Lynn Matteson
Status: flying
On Jun 9, 2009, at 4:23 PM, Keith Pickford wrote:
Hi Lynn
keith
rough running engine, and loose valve adjustments... Setting them
Lynn Matteson
Status: flying
> chris ambrose
www.matronics.com/contribution _-
Lynn
N369LM
ces308
PostPosted: Tue Jun 09, 2009 5:39 pm    Post subject: Re: A-2200 oil leak Reply with quote
Thank guys,for the heads up on the engine.I will keep my eyes open for the problems.Anything else I should be looking for?
chris ambrose
m3x/jab 21.6hrs
plus2s
PostPosted: Tue Jun 09, 2009 5:47 pm    Post subject: A-2200 oil leak Reply with quote
Hi Lynn
Yes checked them all - the two I replaced were both on number one cyl. Will be doing a top overhaul before too long. Went with the oil thermostat as we have many people of different experience levels flying the aircraft and I wanted to keep it simple.
Also about to strip a earley hydraulic lifter engine (ser # 2440) that needs line boring after 500 hours.
Keith
Received: Wednesday, 10 June, 2009, 12:37 PM
Hi Keith-
Did you look at all the rocker bushings when you did the two? I'm surprised only two needed replacing.
I decided against the oil thermostat because of the extra fittings involved, and instead installed a butterfly-type valve to regulate the air to the oil cooler. It works very well until I forget sometimes to open it and that's when I wished I had the 'stat. : ) I can actually leave it closed all winter long (flying on skis), and this gets me into the habit of sometimes forgetting it, but the warning light gets my attention.
Lynn Matteson
Status: flying
plus2s
PostPosted: Tue Jun 09, 2009 5:59 pm    Post subject: A-2200 oil leak Reply with quote
Hi Chris
Only other thought at this stage is don't hurry to change from the straight (running in) oil if the oil burn has not settled - we have one motor done 42 hours and haven't changed to the multi grade yet.
Keith
--- On Wed, 10/6/09, ces308 <ces308(at)ldaco.com> wrote:
Subject: Re: A-2200 oil leak
Received: Wednesday, 10 June, 2009, 1:39 PM
chris ambrose
m3x/jab 21.6hrs
http://forums.matronics.com/viewtopic.php?p=http://foru - List Contribution We &nbs;--> http://www.======================
BobsV35B(at)aol.com
PostPosted: Tue Jun 09, 2009 6:37 pm    Post subject: A-2200 oil leak Reply with quote
Good Evening Keith,
Just out of curiosity, why do you want to use a different oil for break in than you do for normal use?
Following the recommendation of a local Boutique engine shop owner, I have broken in my last three engines using multigrade aviation oil. Seemed to work just fine. They all ran good, broke in fast and seem to be doing just fine. The rings were fully seated in way less than five hours. The first one I broke in that way was retired after running eighteen hundred hours without a cylinder being pulled or any major component needing service. I think the old mineral oil idea is just an ancient Old Wive's Tale!
Happy Skies,
Old Bob
In a message dated 6/9/2009 9:00:08 P.M. Central Daylight Time, kpickford(at)xtra.co.nz writes:
Hi Chris
Keith
A Good Credit Score is 700 or Above.ol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JunestepsfooterNO62>See yours in just 2 easy steps!
plus2s
PostPosted: Tue Jun 09, 2009 7:10 pm    Post subject: A-2200 oil leak Reply with quote
Hi Bob
That's interesting - as you say - is it an old wives tail - I believe Jabiru and Lycoming still recomend straight oil initially. I believed the reason was that the friction reducing additives would glaze the bores before the rings were bedded in. I'm certainly no expert on oils, but have had a good result with aviation multi grade with our variations of temperature here. And of course we could start another discussion on the best way to break in a new engine ???
Keith
Received: Wednesday, 10 June, 2009, 2:29 PM
Good Evening Keith,
Happy Skies,
Old Bob
Hi Chris
Keith
ist" target=_blank rel=nofollow>http://www.matronics.com/Navigator?JabiruEngine-List
BobsV35B(at)aol.com
PostPosted: Tue Jun 09, 2009 7:42 pm    Post subject: A-2200 oil leak Reply with quote
Agreed Keith,
Most shops are still recommending a "break in" oil, but many top shops have switched over to recommending using multigrade. I was an early adopter and have been very happy.
I did follow the recommendation to fly it hard right away. Seventy-five percent or higher with particular effort to keep cylinder pressures high..
I spent many hours as a young aviator slow timing engines. I now believe that was a major waste of time and I do not think the engines ever ran as good as do those that we break in hard and early. The slow time and heavy oils may have been needed fifty to sixty years ago when fits and finish were not as good as they are today.
My last two certificated engines I even broke in using lean of peak mixtures. That is a bit trickier because you have to be sure the mixture distribution to every cylinder is extremely accurate and well balanced, but it does work if all the bases are covered.
Unfortunately, I know of no way to do that with a Jabiru. I broke in a 3300 last year, but just used the mixture as it came from the factory. We did run it hard though and used multi grade oil. In an effort to get it ready for Sun and Fun, I flew the thing 24 hours in three days! Our son and his daughter flew off the rest of the time in a couple of days before taking it to the show.
Happy Skies,
Old Bob
In a message dated 6/9/2009 10:10:17 P.M. Central Daylight Time, kpickford(at)xtra.co.nz writes:
Hi Bob
That's interesting - as you say - is it an old wives tail - I believe Jabiru and Lycoming still recommend straight oil initially. I believed the reason was that the friction reducing additives would glaze the bores before the rings were bedded in. I'm certainly no expert on oils, but have had a good result with aviation multi grade with our variations of temperature here. And of course we could start another discussion on the best way to break in a new engine ???
Keith
Good Evening Keith,
Happy Skies,
Old Bob
Hi Chris
Keith
List href="http://www.matronics.com/Navigator?JabiruEngine-List">http://www.matronics.com/Navigator?JabiruEngine-List
ms.matronics.com/">http://forums.matronics.com
tp://www.matronics.com/contribution">http://www.matronics.com/contribution
A Good Credit Score is 700 or Above. See yours in just 2 easy steps!
Goto page 1, 2  Next
Page 1 of 2
