				 Posted: Fri Jun 12, 2009 3:12 pm    Post subject: Last Rivet |
				At 3:58 this afternoon I set the final rivet in a nut plate in the fuselage root fairing mount....It was a great feeling especially since I never had to drill out a bad one!!!   .  Those from the Yahoo group will recall that as my moniker...Rick Sked
 Sent via BlackBerry by AT&T
 Date: Fri, 12 Jun 2009 17:17:46 -0500
 To: rv10-list(at)matronics.com<rv10-list(at)matronics.com>
 Subject: Re: RV10-List: Door Fit
 They get better but the action you = use is pull in and forward on the handle and that brings the back one in = too. The seals work REAL well so for us northerners it's nice that = they're tight.
 On Jun = 12, 2009, at 4:36 PM, "Les Kearney" <kearney(at)shaw.ca (kearney(at)shaw.ca)> = wrote:
 Hi
 As I work to fit my doors, I have come to realize = that getting the door pins into the guides will be a bit of a problem. This = will be especially so when the weather seals are installed. The doors fit quite = well at present but do require that they be pulled in, for and aft. Unless I = grow a third hand, this could be a bit of a problem. I will be seeing if I can = adjust the door fit to alleviate this issue, but if not I am wondering what = others have done to deal with this problem.
 Inquiring minds need to = know=E2=80=A6
 Cheers
 Les
 #40643 =E2=80=93 Living in a f/g = world
        	  | Quote: | 	 		  |  href=3D"http://www.matronics.com/Navigator?RV10-List">http://www.matronics= .com/Navigator?RV10-List href=3D"http://forums.matronics.com">http://forums.matronics.com href=3D"http://www.matronics.com/contribution">http://www.matronics.com/co= ntribution  |
  | 	  =  	  | Quote: | 	 		  |   _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D          - The RV10-List Email Forum - _-=3D Use the Matronics List Features Navigator to browse _-=3D the many List utilities such as List Un/Subscription, _-=3D Archive Search & Download, 7-Day Browse, Chat, FAQ, _-=3D Photoshare, and much much more: _-=3D _-=3D   --> http://www.matronics.com/Navigator?RV10-List _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D               - MATRONICS WEB FORUMS - _-=3D Same great content also available via the Web Forums! _-=3D _-=3D   --> http://forums.matronics.com _-=3D _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D _-=3D             - List Contribution Web Site - _-=3D  Thank you for your generous support! _-=3D                              -Matt Dralle, List Admin. _-=3D   --> http://www.matronics.com/contribution _-=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D  |
		rene(at)felker.com Guest
				 Posted: Fri Jun 12, 2009 3:32 pm    Post subject: Last Rivet |
				Sorry Rick, but I hate to tell you…….I said the same thing about 15 months ago when I thought I did my last rivet.  Since then, I have lost count as to how many I have added.  To tell you the truth, I miss that part and I am currently trying to talk my wife into letting me build another airplane, a Zenith 750 this time.  So far, her answer has been NEVER…..
 But since you are keeping track, how many “good” rivets have you drilled out.  I started on the Yahoo group and it seems like that was just yesterday.
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of ricksked(at)embarqmail.com
  Sent: Friday, June 12, 2009 5:01 PM
  To: Rv
  Subject: Last Rivet
  Rick Sked
  Subject: Re: Door Fit
  On Jun = 12, 2009, at 4:36 PM, "Les Kearney" <kearney(at)shaw.ca> = wrote:
 Hi
 Cheers
 Les
 =    	  | Quote: | 	 		  |   3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D generous support!                    -Matt Dralle, List Admin. href="3D">http://www.matronics.com/contribution 3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D=3D  |
 ~,    gӓ
				 Posted: Fri Jun 12, 2009 4:04 pm    Post subject: Last Rivet |
				Not counting the SB's I'd bet it is less than 20..Since the paint is done and it has been assembled once there can't be any more left. These nut plates are the ones you leave off until the support is riveted to the fuselage....Mel Asberry is coming in Monday for the Air worthiness Inspection...Rick Sked
 Date: Fri, 12 Jun 2009 17:28:06 -0600
 Subject: RE: RV10-List: Last Rivet
 Sorry Rick, but I hate to tell you=E2=80=A6=E2=80=A6.I = said the same thing about 15 months ago when I thought I did my last rivet.=C2=A0 Since then, I = have lost count as to how many I have added.=C2=A0 To tell you the truth, I miss = that part and I am currently trying to talk my wife into letting me build another = airplane, a Zenith 750 this time.=C2=A0 So far, her answer has been = NEVER=E2=80=A6..
 But since you are keeping track, how many = =E2=80=9Cgood=E2=80=9D rivets have you drilled out.=C2=A0 I started on the Yahoo group and it seems like that = was just yesterday.
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
 From:= owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of =ricksked(at)embarqmail.com
 To: Rv
 Subject: RV10-List: Last Rivet
 At 3:58 this afternoon I set the final rivet in a = nut plate in the fuselage root fairing mount....It was a great feeling especially = since I never had to drill out a bad one!!!  . Those from the Yahoo group will = recall that as my moniker...
  Rick Sked
 They get better but the action you =3D use is pull = in and forward on the handle and that brings the back one in =3D too. The = seals work REAL well so for us northerners it's nice that =3D they're = tight.
  On Jun =3D 12, 2009, at 4:36 PM, "Les Kearney" = <kearney(at)shaw.ca> =3D wrote:
 Hi
 As = I work to fit my doors, I have come to realize =3D that getting the door pins into = the guides will be a bit of a problem. This =3D will be especially so when = the weather seals are installed. The doors fit quite =3D well at present but = do require that they be pulled in, for and aft. Unless I =3D grow a third = hand, this could be a bit of a problem. I will be seeing if I can =3D adjust the = door fit to alleviate this issue, but if not I am wondering what =3D others have = done to deal with this problem.
 Inquiring minds need to =3D know=3DE2=3D80=3DA6
 Cheers
 Les
 #40643 =3DE2=3D80=3D93 Living in a f/g =3D world
   	  | Quote: | 	 		  | =C2=A0href=3D3D"http://ww= w.matronics.com/Navigator?RV10-List">http://www.matronics=3D = .com/Navigator?RV10-List = href=3D3D"http://forums.matronics.com">http://forums.matroni= cs.com = href=3D3D"http://www.matronics.com/contribution">http://www.= matronics.com/co=3D ntribution  |
 =3D   	  | Quote: | 	 		  | =C2=A0 = 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D = 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D = generous support! = =C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0=C2= =A0=C2=A0=C2=A0=C2=A0=C2=A0=C2=A0 -Matt Dralle, List Admin. = href=3D"3D">http://www.matronics.com/contribution = 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D3D=3D= 3D  |
 ~,   g=D3=93
		n801bh(at)netzero.com Guest
				 Posted: Fri Jun 12, 2009 5:26 pm    Post subject: Last Rivet |
				Go for the 750... I LOVE my 801 and I am close to ya here in jackson Hole. If ya ever get up this way I can give you some STOL time.
 Ben Haas
 N801BH
 www.haaspowerair.com
