Arksey(at)aol.com Guest
Posted: Sat Jun 13, 2009 6:22 pm Post subject: Flat tire (non event) |
well i am for sure a old pilot....but have not landed with a flat tire....what you did worked so it was ok .....but did you check the tires prior to take-off? if not you should....On my firestar the tires were sort of old when I purchased it and I noticed a slow leak in one....I replaced both tires with new tires and tubes...I think it pays to keep good tires on a plane...I check tires on pre flight by stepping on them....glad things worked ok for you...
JIM SWAN
firestar ll, 503, N663S
Eaton Rapids, Mi. 48827
PH 517-663-8488 runway 2300' E & W (42-28.58N 084-44.69 W )
A Good Credit Score is 700 or54365/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JunestepsfooterNO62>See yours in just 2 easy steps!
