Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
s.clive.richards(at)homec Guest
Posted: Mon Jun 15, 2009 1:14 am Post subject: XL Testing UK |
All XL Builders
From our LAA WEB SITE
Testing of Chris Heinz mods appears to be immanent and may resolve your problems.
Clive
Permission to test fly Zenair CH 601 XL Granted by UK CAA
Following a briefing meeting at Gatwick with the CAA flutter and structures experts, the CAA has now given permission for the LAA to start the flight program on a modified Zenair CH601 XL fitted with aileron mass balances and wing attachment reinforcements. This permission temporarily exempts the aircraft from the MPD which currently grounds the type, so that the effectiveness of the modifications can be explored. LAA Engineering are now awaiting the arrival of the test equipment which has been specified to record the behaviour of the airframe during the flutter testing. Once the equipment is installed and wired up, flight tests will explore the ASI calibration, flutter behaviour, cg range, pitch stability and the sensitivity of the elevator trim tab. The flight testing will take place from a farm strip near Cambridge.
jaybannist(at)cs.com Guest
Posted: Mon Jun 15, 2009 5:53 am Post subject: XL Testing UK |
Clive,
"May resolve your problems"?? Must the scientific community go back and prove to the British CAA Bureaucrats that the world is round ? The Zodiac XL has been load tested twice, passing both times. The German scientists PROVED that there is NOT a flutter problem with the XL, and yet the Brits insist on testing a solution to a problem that doesn't exist. Is it because they didn't do the tests themselves that they have totally disregarded all the testing that has been done on the XL ?? I guess we MUST allow that the Brit Bureaucrats' intelligence is superior to that of everyone else in the world. Talk about hard-headed arrogance !!
Jay Bannister
jmaynard
Joined: 27 Feb 2008 Posts: 389 Location: Fairmont, MN (FRM)
Posted: Mon Jun 15, 2009 6:19 am Post subject: XL Testing UK |
On Mon, Jun 15, 2009 at 09:51:11AM -0400, jaybannist(at)cs.com wrote:
| Quote: | The Zodiac XL has been load tested twice, passing both times.
Static load testing, only...good in and of itself, but not everything.
| Quote: | The German scientists PROVED that there is NOT a flutter problem with the
have totally disregarded all the testing that has been done on the XL ????
There's one thing that the German testing didn't cover: what happens if
there's no tension on the aileron cables? It's well and good in the US to
say that the cable tensions must be maintained as a sufficient solution to
the problem, but the accepted standard in the aeronautical engineering world
is to have no flutter issues with slack cables. The Germans didn't test that
scenario. It's not unreasonable for the British to say that cable tension
alone is not sufficient.
| Quote: | I guess we MUST allow that the Brit Bureaucrats' intelligence is superior
to that of everyone else in the world.? Talk about hard-headed arrogance
It's not the British bureaucrats. It's the accepted standards of
aeronautical engineering. *EVERY* aeronautical engineer I've ever spoken to
has said that having unbalanced ailerons is not acceptable as a matter of
principle.
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
http://jmaynard.livejournal.com http://www.tronguy.net
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
_________________ Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC |
Gig Giacona
Joined: 10 Jan 2006 Posts: 1409 Location: El Dorado Arkansas USA
Posted: Mon Jun 15, 2009 6:36 am Post subject: Re: XL Testing UK |
| jmaynard wrote: | On Mon, Jun 15, 2009 at 09:51:11AM -0400, jaybannist(at)cs.com wrote:
there's no tension on the aileron cables? |
Come on Jay, this one is easy. The airplane becomes uncontrollable and flutter will be the least of your concerns.
601XL Under Construction
d.goddard(at)ns.sympatico Guest
Posted: Mon Jun 15, 2009 7:21 am Post subject: XL Testing UK |
I think I recall seeing that they claimed no issue with tensions as low as
10 lbs. So there appears to be some flexibility there. No tension is so far
outside the acceptable range that I don't think it should be tested a that
level.
jmaynard
Posted: Mon Jun 15, 2009 7:39 am Post subject: XL Testing UK |
level.
Actually, they tested down to 5 pounds. I agree that slack cables are a
problem in other ways - but then, take a look at what happened when they
examined the Dutch Zodiac fleet: over half of the airplanes had them.
Even so, if every aeronautical engineering reference says that unbalanced
ailerons aren't acecptable, how can we complain when a regulatory authority
takes them at their word?
aerobat
Posted: Mon Jun 15, 2009 8:55 am Post subject: Re: XL Testing UK |
Did the Germans test at their max weight of 450kg or higher weights as in UK and US. It could make a difference !
Gig Giacona
Posted: Mon Jun 15, 2009 10:18 am Post subject: Re: XL Testing UK |
| aerobat wrote: | | Did the Germans test at their max weight of 450kg or higher weights as in UK and US. It could make a difference ! |
As far as flutter is concerned it really shouldn't make any difference.
jonaburns
Posted: Mon Jun 15, 2009 10:33 am Post subject: Re: XL Testing UK |
Jay,
You say that *EVERY* Aeronautical Engineer states this is unacceptable...
Isn't CH an Aeronautical Engineer?
Has *EVERY* Engineer you have talked to designed and flown MORE aircraft than CH?
Many of us still question your "Experts" who continue to support speculation and refuse to admit they were WRONG on the Flutter issue, and WILL NOT release their so called engineering for independent review.
There may be an issue, and there may not be. Everyone should be free to decide their own risk level and you and I have obviously decided differently. Until there is hard proof that there is an issue we will continue to agree to disagree.
There are a few that won't accept anything but a design flaw and will do anything they can to fulfill that assumption.
To those calling Scott crazy and reckless because he chooses to fly his airplane because of blind belief in a government agency is beyond me. I guess we all need faith in something.
We all know that government agencies are without flaw or political motivation, right?
Calling an unfinished plane "grounded" is another issue I have. It isn't "Grounded" it is abandoned. If it isn't legal to fly, it isn't an aircraft yet, and can't be grounded. Your choice of not finishing the build is your own, just like hundreds of other kits wasting away in attics, basements, and hangers.
My kids have a "grounded" space ship out back... It has the best avionics the Home Depot can offer. The stickers have stayed on for 3 years.
Jon Burns
Sabrina
Posted: Mon Jun 15, 2009 11:16 am Post subject: Re: XL Testing UK |
psm(at)att.net Guest
Posted: Mon Jun 15, 2009 11:55 am Post subject: XL Testing UK |
Welcome back Sabrina! I am delighted to hear
from you again. I was worried you were gone for good.
Of course I would like to meet you (with
appropriate chaperone) when you visit Washington
State. Just let me know where and when. I don't
think I am ready to fly my XL but I have another
(even nicer) plane at my disposal for the next
year. I would be happy to fly anywhere in the
state to meet you. I am all current and legal,
so I could take you up if you want. The plane
looks a lot like a 150 but performs somewhere between a 172 and 182.
I'll have to consider the name, St. Pauli Girl,
before agreeing. If I wind up selling it I
shouldn't name it. I don't think anyone will pay
a fair price, but I feel I have already received
my money's worth on the airframe. Four years of
great activity is worth a lot to me. On the
other hand, I have a very nice engine and
avionics that many builders wouldn't pay the
price for. I'm not going to give them away to
anyone (except perhaps someone I really like)
just because I am reluctant to fly the plane. I
am considering building another airframe that can
use the same engine and avionics.
I, for one, never thought you were responsible
for any of the flaming that goes on regularly
here. I am afraid I can't say the same about
myself. I try to be "Professional" and stay away
from personal attacks, but there are many here who don't see it the same way.
Paul
Camas, WA (1W1)
At 12:16 PM 6/15/2009, you wrote:
I'm back...
I just wanted to make sure it was not me who was
causing the list to flame. It can flame very well on its own.
I just finished my 2,000th consecutive day of
school without being sick, absent or tardy. My
U.S. Student pilot certificate issued June 3d
and my IL motorbike permit issued that same
day. I just finished with the ACT this
Saturday and the SAT the Saturday before
that. No scores on those yet. I did score a
perfect 800 on the May 2d SAT Subject Test: Math
Level 2. I have been riding side by side with
my dad on my motorcycles the past weekâreally
cool! I take the M permit course this
week. If I pass, the Secretary of State may
issue an M permit next week. Until then, I
ride my 16th birthday present: a 1985 Honda CB125S...
Paul, I will be in Washington State next month,
what do you say we get St. Pauli Girl in the
air? (Hope you don't mind me naming her for you.)
bryanmmartin
Posted: Mon Jun 15, 2009 3:05 pm Post subject: XL Testing UK |
I believe there are a few standard category aircraft that don't have
balanced ailerons. These are mostly vintage airplanes with a
relatively low value for Vne. For these airplanes it was considered
acceptable not to have balanced ailerons. I am not familiar with any
of these aircraft types, but I have heard of them. I can't cite any
specific examples. Maybe someone else can? I seem to recall mention
that some early Cubs were designed that way.
On Jun 15, 2009, at 2:33 PM, jonaburns wrote:
Jay,
unacceptable...
aircraft than CH?
independent review.
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
_________________ --
Bryan Martin
do not archive. |
z601(at)anemicaardvark.co Guest
Posted: Mon Jun 15, 2009 3:53 pm Post subject: XL Testing UK |
On Monday 15 June 2009 17:59, Bryan Martin wrote:
I think all the J3s were built thus. I know that the Short Wing Pipers
(Vagabond, Clipper, Pacer, TriPacer, and Colt) did not have balanced
ailerons. The TriPacer flies at about the same speed as the 601XL, but I am
unaware of any flutter incidents with one that was properly maintained.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
grs-pms(at)comcast.net Guest
Posted: Mon Jun 15, 2009 5:03 pm Post subject: XL Testing UK |
As I noted a few weeks ago, The Ercoupe is one vintage airplane on which
aileron balance weights were not required. They were initially fitted but
subsequent analysis and testing showed that they were not needed and the
factory recommended their removal. These Ercoupes had fabric-covered wings.
(Some later Ercoupes were produced with metal covering the same basic
structure.) The metal covered leading edge was not a D-tube structure: i.e.
the metal was not attached to the lower chord of the main spar. Torsional
stiffness of the wing was realized by a system of diagonal ribs. I believe
Vne was 146 mph, but it's been a long time since I flew one so that may be
wrong.
George Swinford
Juan Vega Jr
Posted: Mon Jun 15, 2009 5:52 pm Post subject: XL Testing UK |
check the -
Piper cub
cessna 140 and 150
Erocoupe
Taylor craft
sopwith Pup
Tiger Moth
stinson
Juan Vega Jr
check the -
Piper cub
cessna 140 and 150
Erocoupe
Taylor craft
sopwith Pup
Tiger Moth
stinson
Tim Juhl
Joined: 21 Mar 2006 Posts: 399 Location: "Thumb" of Michigan
Posted: Mon Jun 15, 2009 7:28 pm Post subject: Re: XL Testing UK |
My Champ does not have balanced ailerons. My buddy just built a 80% replica of a Tiger Moth - it doesn't have balanced ailerons either.
_________________ ______________
CFII
Champ L16A flying
Zodiac XL - Jabiru 3300A
Working on fuselage |
n801bh(at)netzero.com Guest
Posted: Mon Jun 15, 2009 8:27 pm Post subject: XL Testing UK |
Something did. I doubt it was "analysis and testing". There is a history of intergranular corrosion of Ercoupe wing attach fittings, leading to failure and wing separation. As for the observed fluttering, that may or may not have been an accurate observation. Failure analysis of the wreckage should determine that one way or the other.
I had the sad experience of witnessing a fatal in-flight breakup. My observations did not agree in all respects with the eyewitness who was standing right beside me. I now take eyewitness observations, my own included, with a grain of salt.
George
Posted: Tue Jun 16, 2009 1:53 am Post subject: XL Testing UK |
JAY<?xml:namespace prefix = o ns = "urn:schemas-microsoft-com:office:office" />
The request for a design modification was made by the LAA engineers who have to issue Permits to fly on behalf of our CAA (not British CAA Bureaucrats, ) before the German tests were completed. These things take time as engineering resources are limited & the home builder had to carry out the work.
Some builders on the list were asking for a zenith designed mod so a tested one will be available if tests are successful
As you are experimental in US it will be up to you if you carry the work out, in UK it will probably be mandatory but XLs will be then be released to fly.
Clive
G-CBDG 305 hrs 601HD not affected by above but it flys much slower.
