albertakolbmk3
Joined: 13 Jun 2009 Posts: 69 Location: Innisfail, AB
Posted: Sat Jun 13, 2009 1:24 pm Post subject: Oil Injection... OK to change type??? |
Hi,
First off I would like to say hi to everyone on the board. I purchased a kolb MK3 2 months ago. Just finishing my hours toward my ultralight permit. I have a 582 with oil injection and am wondering if it's ok to go from a synthetic to a mineral oil even after the engine has run exclusively on synthetic. It was run using Bombardier XP-S full synthetic 2 cycle oil. Is it better to stay with what the previous owner has been running. I'm not trying to be cheap but the local dealer wants $70 CAN for a gallon. I've had dirtbikes all my life and have never run synthetic in any thing I own and have never had any issues. I change my oil religiously.
Tony
h20maule(at)hotmail.com Guest
Posted: Sat Jun 13, 2009 2:29 pm Post subject: Oil Injection... OK to change type??? |
how do i send a message to everyone like you just did? I have a firestar amphib that I am trying to sell and I need to get the word out
daniel
| Quote: | Subject: Oil Injection... OK to change type???
Date: Sat C 13 Jun 2009 14:24:57 -0700
--> Kolb-List message posted by: "albertakolbmk3" <cheriebraun(at)xplornet.com>
Hi C
Thanks C
Tony
http://forums.matronics.com/viewtopic.php?p=247979#247979
Archive Search & Download C 7-Day Browse C Chat C FAQ C
Lauren found her dream laptop. Find the PC that’s right for you. |
aslsa.rng(at)gmail.com Guest
Posted: Sat Jun 13, 2009 3:19 pm Post subject: Oil Injection... OK to change type??? |
Tony, I'd check with Lockwood Aviation about oil compatability. Certain types, most notably Pennzoil Air Cooled and Pennzoil Marine will congeal when combined.
Rick
On Sat, Jun 13, 2009 at 4:24 PM, albertakolbmk3 <cheriebraun(at)xplornet.com (cheriebraun(at)xplornet.com)> wrote:
[quote]--> Kolb-List message posted by: "albertakolbmk3" <cheriebraun(at)xplornet.com (cheriebraun(at)xplornet.com)>
Hi,
Tony
le, List Admin.
Posted: Sat Jun 13, 2009 3:39 pm Post subject: Oil Injection... OK to change type??? |
Yes C make sure its not marine
daniel
Date: Sat C 13 Jun 2009 18:16:02 -0500
Subject: Re: Oil Injection... OK to change type???
Tony C I'd check with Lockwood Aviation about oil compatability. Certain types C most notably Pennzoil Air Cooled and Pennzoil Marine will congeal when combined.
Rick
On Sat C Jun 13 C 2009 at 4:24 PM C albertakolbmk3 <cheriebraun(at)xplornet.com> wrote:
| Quote: | --> Kolb-List message posted by: "albertakolbmk3" <cheriebraun(at)xplornet.com>
Hi C
Thanks C
Tony
le C List Admin.
| Windows Live™ SkyDrive™: Get 25 GB of free online storage. Get it on your BlackBerry or iPhone. [quote][b]
Arksey(at)AOL.COM Guest
Posted: Sat Jun 13, 2009 5:51 pm Post subject: Oil Injection... OK to change type??? |
the 503 rotax in my firestar had been run on a synthettic oil prior to my purchase....I took the advice of Lockwood aviation on the use of Pennzoil 2 cly air cooled . I have used it for about 200 hours of flying time and it has worked fine. Lockwood aviation have run a lot of rotax engine test on different 2 cycle oil. You might give them a call and ask about their test results.....it is interesting.....
JIM SWAN
firestar ll, 503, N663S
Eaton Rapids, Mi. 48827
PH 517-663-8488 runway 2300' E & W (42-28.58N 084-44.69 W )
A Good Credit Score is 700 or54365/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JunestepsfooterNO62>See yours in just 2 easy steps!
lucien
Joined: 03 Jun 2007 Posts: 721 Location: santa fe, NM
Posted: Sat Jun 13, 2009 6:09 pm Post subject: Re: Oil Injection... OK to change type??? |
| albertakolbmk3 wrote: | Hi,
Tony |
You'll be fine changing oils, the engine won't notice the switch. A dino oil will be a little better in terms of corrosion protection anyway as it sticks to surfaces better than synthetic. I always used the pennzoil air cooled which I think has recently been rebranded to something else.
Make sure the new grade you switch to meets the API TC specification (tho a TCW-III oil will work acceptably in the 582 also if that's the only grade available).
As for the oil injection I suppose you should drain it out before changing the oils (I always ran premix so never did maintenance on the oil injection).
If you're worried about congealing for the short time you'll have a little of the old oil in the system, test a mix of the two in a petri dish first....
LS
_________________ LS
Titan II SS |
capedavis(at)yahoo.com Guest
Posted: Sat Jun 13, 2009 6:43 pm Post subject: Oil Injection... OK to change type??? |
i RAN PENNZOIL AIR COLLED 492ho urs never had the head off only had it rebuilt to sell it! 503 SC firestar KXP. Chris
Sent: Saturday, June 13, 2009 8:48:49 PM
Subject: Re:Oil Injection... OK to change type???
JIM SWAN
[quote][b][b]
pj.ladd(at)btinternet.com Guest
Posted: Sun Jun 14, 2009 3:25 am Post subject: Oil Injection... OK to change type??? |
I change my oil religiously.>>
You get the local local Reverend to do it? What a good idea, I must try
that. Perhaps just saying a prayer over it would work.
Cheers
Pat
Posted: Sun Jun 14, 2009 5:44 am Post subject: Oil Injection... OK to change type??? |
For sale is a Kolb Firestar seaplane amphibian (single seat)...Comes with spare Full Lotus monofloat! The plane has just been refurbished and has new paint C cables C fuel lines C WarpDrive prop C Full Lotus monofloat C wheels/tires C brakes C nose cone and much more. 40 hrs total time on airframe (since restoration) and engine (overhauled Rotax 582). Airplane was built in 1993 but sat most of its life indoors. The airframe probably has about 200 hrs on it total. The plane has electric start C electric flaperons C and electric landing gear. The landing gear runs off a jack screw and retracts into the plane behind the pilot seat. The plane cruises at 85 MPH and gets about 4gph. I am selling the plane because I need a bigger plane with more than one seat. Avionics include EIS (engine information system) Altimeter and Airspeed indicator. This plane will go anywhere and is flown 4-5 times a week. This plane is perfect for anyone seeking a good time flying. Flight demonstration is available upon request. h20maule(at)hotmail.com (h20maule(at)hotmail.com) is my email address. Buy this plane now for $14 C000!
http://www.youtube.com/watch?v=nUh7Wei9trk&feature=related
http://www.youtube.com/watch?v=I5-JDJxJluo&feature=related
http://www.youtube.com/watch?v=G34CQViHgqM&feature=related[url=http://www.youtube.com/watch?v=nUh7Wei9trk&feature=related][/url]
[quote] From: pj.ladd(at)btinternet.com
Subject: Re: Kolb-List: Re: Oil Injection... OK to change type???
Date: Sun C 14 Jun 2009 12:24:00 +0100
--> Kolb-List message posted by: "pj.ladd" <pj.ladd(at)btinternet.com>
You get the local local Reverend to do it? What a good idea C I must try
Cheers<
Dana
Posted: Mon Jun 15, 2009 2:39 pm Post subject: Oil Injection... OK to change type??? |
At 06:27 PM 6/13/2009, daniel myers wrote:
| Quote: | how do i send a message to everyone like you just did?
You just did...
-Dana
If vegetarians eat vegetables,..beware of humanitarians!
russ(at)rkiphoto.com Guest
Posted: Mon Jun 15, 2009 5:13 pm Post subject: Oil Injection... OK to change type??? |
Pat
I think swearing while you do it qualifies --
Russ
On Jun 14, 2009, at 7:24 AM, pj.ladd wrote:
must try that. Perhaps just saying a prayer over it would work.
Cheers
Pat
Posted: Tue Jun 16, 2009 1:41 am Post subject: Oil Injection... OK to change type??? |
I think swearing while you do it qualifies --( no one else seems to have
picked it up)
Hi Russ
My oil change doesn`t make me swear. I have a sort of vacuum pump gismo that
drags the oil out of the filler tube. Slowish but clean. Beats fiddling
around between the engine and the top of the cabin cage where there is no
room..
Good story sent to me this morning.
There has been a very pleasant parking warden who has worked outside Bristol
Zoo for the last 25 years. £1 for cars. £5 for coaches. Rrecently he did not
turn up and eventually the Zoo authorities rang the Bristol Council for a
replacement. "Not our responsibility` said the Council "We dont pay him`.
"Not ours" said the Zoo "We don`t pay him"
Seems that noone paid him. He just turned up and pocketed the parking money,
estimated at £400 per day, for 25 years and is now living in Spain..
Heh! heh! heh!
Cheers
