		gengrumpy(at)aol.com Guest
				 Posted: Mon Jun 15, 2009 3:05 pm    Post subject: hot starts |
				For those flying with the IO-540 and who have a good deal of
 experience with hot starts.
 Hot starts are defined as 80+F on the ramp, and trying to start from
 10 - 30 minutes after landing with engine at normal operating temps.
 I've been using Tim's method, but not always successful in 1) getting
 it running and then 2) keeping it running.
 Yesterday, once I did get it running, it was surging badly and turning
 the boost pump on seemed to settle it out.
 If you have a tried and true technique on getting it started when it's
 hot, please share.
 Thanks - grumpy
 N184JM
		Kellym
				 Posted: Mon Jun 15, 2009 3:39 pm    Post subject: hot starts |
				I don't know about the IO540, but suspect it is like the IO360 I now
 fly. Any start other than 1st start of the day or when plane has sat
 long enough for engine to get back to cool to touch crankcase is a hot
 start.
 I just leave mixture at cutoff, use maybe 1/8 to 1/4" throttle, start
 cranking and after 4 blades slowly add mixture until it catches. Works
 99.94% of time.
 Miller John wrote:
  For those flying with the IO-540 and who have a good deal of experience
  with hot starts.
  Hot starts are defined as 80+F on the ramp, and trying to start from 10
  I've been using Tim's method, but not always successful in 1) getting it
  hot, please share.
  Thanks - grumpy
  N184JM
KCHD |
		flysrv10(at)gmail.com Guest
				 Posted: Mon Jun 15, 2009 3:40 pm    Post subject: hot starts |
				Here is what works for me..... 90% of the time:
 First, make sure you either have an impulse coupler on the mag or a
 "Shower of Sparks".  Rebuilt engines, may not have a mag with an
 impulse coupler.
 With mixture full rich, run the fuel pump for couple of seconds.
 Push the throttle forward passed 1/2 way point, mixture lean, then
 crank.  At this point, my engine coughs, runs a few blades and dies.
 I repeat the same procedure again and it fires up.
 If it does not cough on the first try, it is a sign for me that the
 engine has cooled sufficient enough that I need to do the above
 procedure with the mixture rich.  In which case, the engine does not
 cough but fires right up.
 I am sure there are as many hot start procedures s there are IO-540.
 Find what works for your engine.
 On Mon, Jun 15, 2009 at 6:58 PM, Miller John<gengrumpy(at)aol.com> wrote:
  For those flying with the IO-540 and who have a good deal of experience with
  hot starts.
  Hot starts are defined as 80+F on the ramp, and trying to start from 10 - 30
  Yesterday, once I did get it running, it was surging badly and turning the
  If you have a tried and true technique on getting it started when it's hot,
  please share.
  Thanks - grumpy
  N184JM
 Rob Kermanj
		dlm46007(at)cox.net Guest
				 Posted: Mon Jun 15, 2009 3:51 pm    Post subject: hot starts |
				I use this procedure unless the CHTs are ambient.
 This always works for me. For hot starts we pretend it's a turbine. Throttle
 cracked, mixture idle cutoff. Run boost pump with mixture in cutoff for a
 few seconds. Ignition on for the starting magneto and crank. Smoothly move
 the mixture from idle cutoff to rich as the engine fires. Second magneto on
 then boost pump to prevent any surging. Flooded start same procedure but
 throttle full open. As it fires, second magneto on and retard throttle
 quickly. Boost pump on to prevent surging.
		rene(at)felker.com Guest
				 Posted: Mon Jun 15, 2009 4:03 pm    Post subject: hot starts |
				I would not say that I have a lot of experience....but I will throw my 2
 cents in.....
 Two weekends ago I flew 8 young eagle flights in a row.  Air temp, right at
 80.  So I had a lot of hot starts.  Here is the method and it was not all
 that great, but it did start the engine.
 No Priming......
 Throttle 1/2 inch
 Mixture full lean
 Crank the engine until it fires at least a little
 Mixture rich
 Advance throttle
 If it is running.....big if....Advance the throttle to 1800 RPM or full if
 it does not get to 1800 RPM
 Run engine at high RPM for 20-30 seconds.
 Turning on the pump did not help.
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
		Tim Olson
				 Posted: Mon Jun 15, 2009 4:08 pm    Post subject: hot starts |
				That's the method I use, basically.   I'd say I've been 99.5%
 successful with it.  I can maybe remember 5 starts in 495
 hours that didn't go too well...and that was usually either
 because I didn't richen it quick enough to keep it running,
 or I flooded it after not richening it enough, by using the
 pump.
 I think it would work good for most people, as it's a common
 method used on many lycomings in many makes and models, but,
 I can only say for sure that it works well for me with:
 IO-540
 Lightspeed on Right side (top plugs)
 Mag with impulse coupling on Left side
 Precision Fuel Injection System
 I personally think the lightspeed is probably what makes
 this plane start so well compared to any other plane I've
 flown.  I don't ususally get many blades passing by before
 it's purring right along.
 Tim Olson - RV-10 N104CD
 Kelly McMullen wrote:
  start.
  99.94% of time.
 > hot, please share.
 > Thanks - grumpy
 > N184JM
 > do not archive
		Kelly McMullen
				 Posted: Mon Jun 15, 2009 5:13 pm    Post subject: hot starts |
				You are so correct, it will depend on fuel injection and ignition
 setup. Airflow Performance or others with purge valve will be
 different.
 Precision injection does not need any priming, although it may help to
 bump the boost pump to have pressure a second or two quicker than
 enginge pump will provide it. Shower of sparks or equivalent with turn
 or push to start ignition switch should have non-retard mag grounded
 when start is activated.
 I don't find the boost makes any difference with my Mooney's IO-360
 for anything but cold starts where plenty of priming is needed.
 On Mon, Jun 15, 2009 at 5:01 PM, Tim Olson<Tim(at)myrv10.com> wrote:
  pump.
  IO-540
 > I don't know about the IO540, but suspect it is like the IO360 I now fly.
 > Any start other than 1st start of the day or when plane has sat long enough
 > for engine to get back to cool to touch crankcase is a hot start.
 > 99.94% of time.
 >> with hot starts.
 >> hot, please share.
 >> Thanks - grumpy
 >> N184JM
 >> do not archive
A&P/IA, EAA Tech Counselor
KCHD |
				My technique is similar to these.  I'm really happy with how well it works.  I've definitely been in hot-start hell with other planes.
 I use this for hot or cold starts.  It works fine for both.  I usually have to crank a wee bit longer when it's hot.
 Throttle full
 Mixture rich
 Boost on until PSI peaks, usually about 5 seconds
 Mixture lean
 Throttle open about 1/4 inch
 Left mag on (SlickStart w/ retard points)
 crank, then mixture s-l-o-w-l-y to full rich when it fires
  right mag on
 Works like a charm.
 Dave
 just passed 400 hours
 On Mon, Jun 15, 2009 at 5:01 PM, Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)> wrote:
   	  | Quote: | 	 		  --> RV10-List message posted by: Tim Olson <Tim(at)myrv10.com (Tim(at)myrv10.com)>
  That's the method I use, basically.   I'd say I've been 99.5e
  pump.
  IO-540
   	  | Quote: | 	 		   --> RV10-List message posted by: Kelly McMullen <kellym(at)aviating.com (kellym(at)aviating.com)>
  I don't know about the IO540, but suspect it is like the IO360 I now fly. Any start other than 1st start of the day or when plane has sat long enough for engine to get back to cool to touch crankcase is a hot start.
   I just leave mixture at cutoff, use maybe 1/8 to 1/4" throttle, start cranking and after 4 blades slowly add mixture until it catches. Works 99.94% of time.
  Miller John wrote:
  	  | Quote: | 	 		   --> RV10-List message posted by: Miller John <gengrumpy(at)aol.com (gengrumpy(at)aol.com)>
  For those flying with the IO-540 and who have a good deal of experience with hot starts.
  Hot starts are defined as 80+F on the ramp, and trying to start from 10 - 30 minutes after landing with engine at normal operating temps.
  I've been using Tim's method, but not always successful in 1) getting it running and then 2) keeping it running.
  Yesterday, once I did get it running, it was surging badly and turning the boost pump on seemed to settle it out.
  If you have a tried and true technique on getting it started when it's hot, please share.
  Thanks - grumpy
  N184JM
  http://forums.matronics.com
  le, List Admin.
 Dave Saylor
 AirCrafters LLC
 140 Aviation Way
 Watsonville, CA 95076
 831-722-9141 Shop
 831-750-0284 Cell
		jim(at)CombsFive.Com Guest
				 Posted: Tue Jun 16, 2009 6:20 am    Post subject: hot starts |
				I had 10 young eagle flights two weeks ago, on a 75 Deg F day- Fuel Pump - OFF (No Prime)- Throttle - Wide Open- Mixture - Cutoff- Crank till it fires- Mixture - Ease it in (Too fast will flood it (Again!))- Throttle - Close to high idleWorked for me - But not a real pretty start, but got the fan running Jim CN312F - 75 hours   [quote][b]
				 Posted: Tue Jun 16, 2009 7:48 am    Post subject: hot starts |
				Jim,
             Next time try the exact same procedure but with the fuel pump on and see if it works better for you. To be clear…
  - Mixture – Cutoff
 - Fuel Pump - On
 Robin
 From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Susan
  Sent: Tuesday, June 16, 2009 7:19 AM
  Subject: Re: hot starts
  - Mixture - Cutoff
  Jim C
  N312F - 75 hours
     	  | Quote: | 	 		  |   http://www.matronics.com/Navigator?RV10-List  | 	  0123456789
  Checked by AVG - www.avg.com
  06/15/09 05:54:00
		Tim Olson
				 Posted: Tue Jun 16, 2009 8:18 am    Post subject: hot starts |
				One thing I could add to the hot start commentary is that while
 I do find hot starts to be no problem at all for me, the
 engine does not run as smooth during taxi on a hot start.
 I attribute this to vapor in the lines that builds up, but
 I can't guarantee that I'm correct.  All I know is that
 as I taxi, it burbles more than cold.  Once you pour the
 coals on though, you have so much fuel flow I think the
 added cool fuel flowing probably decreases the temps and
 the vapor disappears, because it never affects my power
 at higher throttle.....just leaned idle.
 Robin Marks wrote:
  	  | Quote: | 	 		   Jim,
  - Mixture – Cutoff
  - Fuel Pump - On
  Robin
  [mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Susan
  *Sent:* Tuesday, June 16, 2009 7:19 AM
  *To:* rv10-list(at)matronics.com
  *Subject:* Re: hot starts
  - Mixture - Cutoff
  Jim C
  N312F - 75 hours
  *http://www.matronics.com/Navigator?RV10-List*
  *http://forums.matronics.com*
  *http://www.matronics.com/contribution*
  06/15/09 05:54:00
		Deems Davis
				 Posted: Tue Jun 16, 2009 8:53 am    Post subject: hot starts |
				I just went through this with Don Rivera (at) Airflow Performance, and the
 roughness/surging during taxi with a hot engine is caused by the engine
 heating/vaporizing the fuel in the distribution lines from the spider to
 the cylinders. If you've got a plenum it also exacerbates the problem
 for obvious reasons. Depending on  fuel flows (at) Take Off  there is a
 possibility of going to smaller nozzles which increases the psi in the
 lines. insulating them only makes it worse according to Don, as it takes
 longer for the lines to cool.
 Deems Davis N519PJ
 Tim Olson wrote:
  Robin Marks wrote:
 > Jim,
 > - Mixture – Cutoff
 > - Fuel Pump - On
 > Robin
 > *From:* owner-rv10-list-server(at)matronics.com
 > - Mixture - Cutoff
 > Jim C
 > N312F - 75 hours
 > 06/15/09 05:54:00
				 Posted: Tue Jun 16, 2009 9:13 am    Post subject: hot starts |
				I agree with Tim.  I taxi at 1400 after a hot start or else the engine may
 not even keep running.  After several minutes it gets better.
 Also, over the winter I worked on oil temp and baffling.  I am not committed
 to saying I fixed my high oil temp problem, it has been to cool here so far
 this year, but it is looking like I did.  So, although I am not convinced
 yet, my engine runs better after a hot start than it did last year.  I will
 wait until the temps get up into the high 90s on the ground before I declare
 victory........
 I did fly out of Vegas in May, it was in the 80's and I did not get a
 cylinder head temp warning or an oil temp warning....last year I got
 both......it was an almost straight climb to 14,500 this year.......I
 normally climb at between 110 and 120 indicated......
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
				 Posted: Tue Jun 16, 2009 10:02 am    Post subject: hot starts |
				Do you lean aggressively after start? I taxi with 1000-1200 no problem.
 Engine will quit with too much fuel or too little for the amount of air.
				 Posted: Tue Jun 16, 2009 10:13 am    Post subject: hot starts |
				Also what is the value of your temp warning? 350f? 400f? 450f?  For me
 250-360f is green range; 361-420f yellow range; 421+ red range. Lycoming
 temp limits are higher. We initially had yellow temp conditions until we cut
 down the air dams and then removed them completely, located AZ.
				 Posted: Tue Jun 16, 2009 10:37 am    Post subject: hot starts |
				Yes I lean aggressively, being at ~4500 feet I need to or the plugs will
 foul.  I only have to pick up the RPMs after a hot start.....it is
 embarrassing to have the engine stop while you are on the taxi
 way.....passengers get concerned also.  After a cold (regular) start I keep
 it at 1000 rpm.
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
				 Posted: Tue Jun 16, 2009 10:40 am    Post subject: hot starts |
				For the CHT I have it set (warning) at 420.  Last year I ran 380 to 400 in
 cruse climb and 380 in low level cruse.  I have not seen 400 yet this year,
 and cruse is closer to 350 on low level cruse.
 I cut my fences down a little, but they are still there....
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
				 Posted: Tue Jun 16, 2009 11:18 am    Post subject: hot starts |
				Try the boost pump on for taxi when hot
				 Posted: Tue Jun 16, 2009 1:53 pm    Post subject: hot starts |
				Well I tried the fuel pump on and off just after the start but could not really tell a difference.  Like Tim, I noticed a little roughness on the taxi to the runway. But it always cleared up after a minute or so of running.  I do lean aggressively once the engine is running for taxi.It's for sure a little hard to start once it gets warmed up.  Only once have I had to crank twice to get a running engine (I jumped on the mixture too soon).But that day I did a lot of starts in a short period of time (10 starts in 4 hours).  Burned 20 gallons that day flying the young eagles.  It was fun.Jim CN312F----------------------------------------Jim,            Next time try the exact same procedure but with the fuelpump on and see if it works better for you. To be clear...- Fuel Pump - OFF (No Prime)- Throttle - Wide Open- Mixture - Cutoff- Fuel Pump - On- Crank till it fires- Mixture - Ease it in (Too fast will flood it (Again!))- Throttle - Close to high idleRobinFrom: owner-rv10-list-server(at)matronics.com[mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of SusanSent: Tuesday, June 16, 2009 7:19 AMTo: rv10-list(at)matronics.comSubject: Re: hot startsI had 10 young eagle flights two weeks ago, on a 75 Deg F day- Fuel Pump - OFF (No Prime)- Throttle - Wide Open- Mixture - Cutoff- Crank till it fires- Mixture - Ease it in (Too fast will flood it (Again!))- Throttle - Close to high idleWorked for me - But not a real pretty start, but got the fan runningJim CN312F - 75 hoursChecked by AVG - www.avg.com06/15/09 05:54:00   [quote][b]
		fdombroski
				 Posted: Tue Jun 16, 2009 6:12 pm    Post subject: Re: hot starts |
				I find that leaning the engine for taxi will minimize the rough running, especially when hot...
 Cheers,
 Frank
 N46WD Grinning
  _________________ Frank Dombroski
Multiple Offender RV-8, 7A, 10 x 2
RV-10 2.0 N46VT  2015
KSMQ Somerset Airport NJ |
