Weight and Balance on 601XL / Corvair
Goto page 1, 2  Next
Davcoberly(at)wmconnect.c
PostPosted: Sat Jun 20, 2009 8:42 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
To all,
I got the scales from my local EAA and did my W & B today. Empty weight seems to high at 820 lbs this is with a Corvair full oil, interior installed, drained all the fuel that the drains would drain but didn't run the engine until dry, it has wing lockers, landing nav and strobe lights, aileron trim, full panel of steam gauges plus GPS.
The CG computes out OK but still seems heavy on empty weight. What ya think?
David Coberly 601XL / Corvair [quote][b]
psm(at)att.net
PostPosted: Sat Jun 20, 2009 9:02 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Hi Dave,
First weighing on my XL with full panel, essentially no interior, no fuel, no oil, and Jabiru 3300 was around 715. I think the Continental or Lycoming adds around 100 pounds, and I guess the Corvair would be similar.
Paul
XL grounded
At 09:30 AM 6/20/2009, you wrote:
[quote]To all,
[/b]
jaybannist(at)cs.com
PostPosted: Sat Jun 20, 2009 9:15 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
David,
My 601XL with a Corvair engine weighed in at 841 lbs. The weight was roughly equal on all three wheels. I didn't think I had added that much weight either, but I guess the scales don't lie. I honestly don't know where all the extra weight comes from. Beyond "norms", I have a single-axis autopilot, insulated firewall, upholstered side panels and seats, parking brake valves, dual sticks, long range fuel tanks and an instrument access panel, I don't have wing lockers, aileron trm, wheel fairings, right side brakes and only have a little paint. I didn't do any "beefing up" of the airframe as I built. So I guess it is what it is, and I wouldn't know where to reduce weight by any significant amount.
Jay Bannister
jmaynard
Don't complain. Mine is 850 pounds empty.
That's supposed to be done with unusable fuel still in the tanks, so you're
probably pretty close (if not a touch low; I'd expect to be able to drain
fuel from the tanks that the engine can't use to run reliably).
Jay Maynard, K5ZC, PP-ASEL, CFI-SP http://www.conmicro.com
Fairmont, MN (KFRM) (Yes, that's me!)
AMD Zodiac CH601XLi N55ZC http://www.tronguy.net/N55ZC.shtml
Jay Maynard, K5ZC
AMD Zodiac XLi N55ZC
z601(at)anemicaardvark.co
PostPosted: Sat Jun 20, 2009 10:40 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
On Saturday 20 June 2009 11:57, Paul Mulwitz wrote:
Hi Dave,
My understanding is that the Continental is heavier than either the Rotax or
the Jabiru. The Lycoming is heavier than the Continental, and the Corvair is
heavier than that.
You pays your money, you makes your choice, I believe the phrase is.
You can check on my aircraft construction
progress at: http://www.mykitlog.com/santaigo
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Retired Aerospace Technical Manager
Jeyoung65(at)aol.com
PostPosted: Sat Jun 20, 2009 11:23 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
David, Where did you place your battery and what size (Wt.) was it.?
Did you have a problem with your CG? Also what are you using for the max. cylinder temp. and oil temp. Jerry of GA DO NOT ARCHIVE
In a message dated 6/20/2009 11:46:52 A.M. Eastern Standard Time, Davcoberly(at)wmconnect.com writes:
To all,
A Good126575x1222585064x1201462784/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JunestepsfooterNO62>See yours in just 2 easy steps!
annken100
PostPosted: Sat Jun 20, 2009 12:42 pm    Post subject: Re: Weight and Balance on 601XL / Corvair Reply with quote
Jim,
Your understanding of the weight of a Corvair engine is not accurate. The Corvair weighs slightly less than a Continental O-200.
As I understand it, the popular engines used in 601 by order of weight from lightest to heaviest is: Rotax, Jabiru 3300, Corvair, Continental O-200, and Lycoming O-235.
I don't know where the Subaru engines fall in the weight order.
Ken Pavlou
601 XL / Corvair
PostPosted: Sat Jun 20, 2009 12:49 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
On Saturday 20 June 2009 15:42, annken100 wrote:
Jim,
Corvair weighs slightly less than a Continental O-200. As I understand it,
O-235. I don't know where the Subaru engines fall in the weight order.
Interesting. Thanks for the update.
The data I've seen on Corvairs has shown them to be heavier than the
Continental. I do have the data sheets on on O200, and an O200 laying here,
awaiting rebuild. But, as I don't have a Corvair, I'll bow to your knowledge
in this area.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
PostPosted: Sat Jun 20, 2009 1:22 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Jay,
Well it's good to know mine is inline with others weight. Mine also has the dual sticks I forgot about. At least the CG falls within limits from just pilot and no fuel to two people and all the fuel up to 1320 gross it's just I will have to watch the fuel weight and baggage with two fair size people aboard.
Thanks, David Coberly 601XL / Corvair [quote][b]
PostPosted: Sat Jun 20, 2009 1:23 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Jerry,
I am using the Odyssey 680 mounted on the rear carry thru behind the passenger seat as in WW's 601 manual. I'm really not sure on the max cht and oil temps someone else might pipe in on this to be sure. David Coberly 601XL / Corvair
bryanmmartin
PostPosted: Sat Jun 20, 2009 2:12 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Mine is 815. The description of your airplane pretty well fits mine
except for the engine. Mine has no paint on the exterior, just
polished aluminum. I also have a cabin heater installed that weighs
about seven pounds and cabin and firewall insulation.
GPS.
ya think?
Bryan Martin
N61BM, CH 601 XL,
RAM Subaru, Stratus redrive.
do not archive.
Bryan Martin
do not archive.
PostPosted: Sat Jun 20, 2009 2:42 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Thanks Dave, think I am going to move mine from the firewall. Jerry of GA DO NOT ARCHIVE
In a message dated 6/20/2009 4:23:39 P.M. Eastern Standard Time, Davcoberly(at)wmconnect.com writes:
Odyssey 680
A Good Credit1222585064x1201462784/aol?redir=http://www.freecreditreport.com/pm/default.aspx?sc=668072%26hmpgID=62%26bcd=JunestepsfooterNO62>See yours in just 2 easy steps!
PatrickW
PostPosted: Sat Jun 20, 2009 3:07 pm    Post subject: Re: Weight and Balance on 601XL / Corvair Reply with quote
Earlier XL's have a lot more 016 in them.
Newer ones have a lot more 025. Mine is mostly 025, except for some 016 in the tail.
Don't know if that would make much difference or not. I'm guestimating that mine is going to come in around 775 with Corvair & BRS and minimal everything else.
Pat
Patrick
XL/650/Corvair
N63PZ (reserved)
PostPosted: Sat Jun 20, 2009 3:38 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Bryan,
Same here polished except fiberglass parts painted I also have cabin heat valve and ducting so it sounds like I'm right in the ballpark with my weight.
Thanks, David Coberly [quote][b]
PostPosted: Sat Jun 20, 2009 3:39 pm    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Pat,
I also thought of that on the skins that were thinner on some parts in the past that would make some difference. David Coberly   Do not Archive [quote][b]
davgray(at)sbcglobal.net
PostPosted: Sun Jun 21, 2009 2:38 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Mine came in at 812 lbs with the .016 rear skins. An Excel Graphical Spreadsheet can be downloaded at this address.
My engine with Roy Szarafinski's 5th Bearing w/ no dynamo or intake/exhaust manifolds weighed 216 lbs
http://www.ch601.org/builder%20resources.htm
Configuration: Every Part that William Wynne Makes for a 2700 cc , .060 Overbore Corvair Engine including: WW SS Intake manifold Marvel Schebler MA3-SPA Carburetor Falcon Heads An-6 SS Fuel Lines WW SS Exhaust manifold WW Motor Mount WW Nitrided Crankshaft WW Deep Oil Pan & Top Plate Warp Drive HP 66 inch 2 bladed Prop WW Reconditioned Rear Accessory Case-Oil Pump-Remote Oil Filter 13 inch spinner & bulkhead Safety Shaft
Roy Szarafinski's 5th bearing
Minimal paint/polished aluminum
Landing Lights, Navigation Lights, Strobe Lights, Taxi Lights Upholstery, .060 instrument panel, Nut plated top forward skin, FW Battery Mount w/ 18 Ahr 15 lb battery Single point ground, Overvoltage Protection, Rear Deck Mic & Accessory Ele. Two Axis Electric Trim Ventral Belly Access Panel Anywhere Map ATC GPS KLN 90B GPS, Narco Escort II Nav/Com, Dynon EFS-D10A, Auto Meter gauges, VDO Tach King 76A Transponder, Blind Encoder, Panel Dimmer, Andair Fuel Valve & Gascolator and Braided SS AN-6 fuel lines from main spar forward.
Gary Ray
davgray(at)sbcglobal.net (davgray(at)sbcglobal.net)
psm(at)att.net
PostPosted: Sun Jun 21, 2009 3:13 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
Hi Gary,
I guess your engine weight explains why the Corvair approach is so much heavier than a Jabiru 3300.
The Jab. comes from the factory weighing 178 pounds (if I remember correctly). That includes the engine, propeller mount flange, integral alternator, starter, integral dual magnetos, dual distributors with spark plug wiring, 12 spark plugs, carburetor, mechanical fuel pump, intake distribution tubing, exhaust tubing, muffler, tail pipe, fiberglass ducts for cooling air (replace baffling) . I think that weight also includes engine mount isolators and voltage regulator too, but I am not sure.
Paul
XL grounded
At 03:35 AM 6/21/2009, you wrote:
[quote]My engine with Roy Szarafinski's 5th Bearing w/ no dynamo or intake/exhaust manifolds weighed 216 lbs [b]
PostPosted: Sun Jun 21, 2009 3:39 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
I also have the WW front starter that was installed prior to weigh in.
pmaxpmax(at)HOTMAIL.COM
PostPosted: Sun Jun 21, 2009 4:39 am    Post subject: Weight and Balance on 601XL / Corvair Reply with quote
My 601XL/Corvair weighs 777 pounds, starter and all. The battery is behind the passenger's seat.
I don't know Jabirus were so much heavier than Corvairs.
Phil Maxson
Northwest New Jersey
mcjon77
PostPosted: Sun Jun 21, 2009 10:46 am    Post subject: Re: Weight and Balance on 601XL / Corvair Reply with quote
pmaxpmax(at)HOTMAIL.COM wrote:
...I don't know Jabirus were so much heavier than Corvairs...
Theiy're not. Jabirus are about 40-50lbs lighter than corvairs.
Jon McDonald
Building Sonex #1287
Thinking ahead about a Zenith CH 701 Very Happy
Goto page 1, 2  Next
Page 1 of 2
