mismatched egt's
carlisle
PostPosted: Sat Jun 20, 2009 2:28 pm    Post subject: mismatched egt's Reply with quote
Hi folks...I've been lurking for some time and finally need to chime in with a question.
My Model II Kitfox is almost 20 years old now and I've only put 150 hours on it. I let it sit idle for 4 years without running the 582 Rotax and decided to resurrect it this summer. Did a top overhaul and inspected the crank (didn't split the case), buttoned it up with new gaskets after decarbonizing everything and it runs fine. When I had the cylinders off, everything looked spotless. Good needle bearings on the con rods, etc. Cylinders don't even look broken in with new looking crosshatching on the walls.
Problem is this. Carbs won't match no matter what I do. Front cylinder runs hotter all the time. I've adjusted the jet needle, put in larger main jet (.175), matched the slides, etc and the fron always runs 100 to 150 deg hotter. Plugs show it too. The front ones are obviously leaner with only slight browning of the insulator.
So the question is, if my crank seals are failing, wouldn't that lean BOTH the carbs out or are these symptoms something else?
Tom Jones
PostPosted: Sat Jun 20, 2009 5:47 pm    Post subject: Re: mismatched egt's Reply with quote
No, the crankcase is sealed between the cylinders. A leak can affect just one cylinder.
Here's a link to the CPS Rotax maintenance articles. Scroll down to number 59, "Leak testing".
http://www.800-airwolf.com/articles.htm
For what its worth, gage errors can cause the temps to read different. Although 100 to 150 degrees is quite a bit.
Tom Jones
Classic IV
Ellensburg, WA
dave
PostPosted: Sat Jun 20, 2009 6:46 pm    Post subject: Re: mismatched egt's Reply with quote
Sounds like you need crank seals.
Contact toll free 866-418-4164 - can ship out seals overnight to you or we can re seal it for you
Dave
Rotax Dealer, Ontario Canada
http://www.cfisher.com/
Awesome *New Forum *
http://rotaxaircraft.com/forum/
http://www.youtube.com/profile_videos?user=kitfoxflyer
WurlyBird
PostPosted: Sun Jun 21, 2009 6:27 pm    Post subject: Re: mismatched egt's Reply with quote
I doubt this is the case since you say your plugs are also indicating the difference, but it could be exasperating the situation. My EGT display went bad and started indicating 75+ degrees difference. The first test I did was swap wires from the front and rear exhaust ports. Left needle was higher then the right before and after the swap so I knew it was the instrument which prevented me from digging into the carbs (that day at least). Good luck with it.
James
James
Kitfox 3 / 582 / GSC prop
The ink is still drying on my new certificate
akflyer
PostPosted: Tue Jun 23, 2009 8:31 am    Post subject: Re: mismatched egt's Reply with quote
why go straight for crank seals? First thing to do is what Whurly said. Swap EGT senders and see if the high reading follows a sender or the display. Akflyerbobs did the same thing and it was the display not the seals. Another thing to check is for any corrosion or loose connections where the senders plug into the display. Any added resistance in a connection will cause a huge error in the reading. Start the checks at the most obvious (and cheapest and easiest to fix) then move on to bigger and more expensive / time consuming repairs.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
582 (87 hrs and counting on the rebuild)
IVO IFA
Full Lotus 1450
hander outer of humorless darwin awards
dave
PostPosted: Thu Jun 25, 2009 7:14 am    Post subject: Re: mismatched egt's Reply with quote
Here is what he said >> The plugs indicated a difference in temps >> so why would changing leads change ? I assuming he is showing a leaner reading on both plugs and EGT reading .
Dave
akflyer
PostPosted: Thu Jun 25, 2009 8:48 am    Post subject: Re: mismatched egt's Reply with quote
yep, had my head square in my a$$ on that one.. I thought I read it all but guess I didn't. I was thinking of an issue akflyerbob had that was very similar, we changed seals and it did not do anything to the high reading. ended up being the EGT indicator not the leads.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
patreilly43(at)hotmail.co
PostPosted: Thu Jun 25, 2009 3:13 pm    Post subject: mismatched egt's Reply with quote
 The front cylinder usually runs cooler than rear due to cold air entering cowling and hitting front cyl first on air cooled. I had a 30 horse C fan cooled C Kohler engine on an ultralite C no cowling C but it had cooling baffels on the engine. I ran a colder plug on the rear cylinder. It gave a more uniform burn color on the front and rear plugs. It was a pusher set up rather than a tractor. Has anybody tried different heat range plugs between front and rear cylinders? Seems like water cooled wouldn't have the greater temp differencial as an air cooled.
Pat Reilly
Mod 3 582 Rebuild
Rockford C IL
Subject: Re: mismatched egt's
Date: Thu C 25 Jun 2009 08:14:35 -0700
--> Kitfox-List message posted by: "dave" <dave(at)cfisher.com>
Dave
> Problem is this. Carbs won't match no matter what I do. Front cylinder runs hotter all the time. I've adjusted the jet needle C put in larger main jet (.175) C matched the slides C etc and the fron always runs 100 to 150 deg hotter. Plugs show it too. The front ones are obviously leaner with only slight browning of the insulator.
> So the question is C if my crank seals are failing C wouldn't that lean BOTH the carbs out or are these symptoms something else?
Rotax Dealer C Ontario Canada
http://forums.matronics.com/viewtopic.php?p=249961#249961
Archive Search & Download C 7-Day Browse C Chat C FAQ C
&gt===
carlisle
PostPosted: Thu Jun 25, 2009 5:02 pm    Post subject: Re: mismatched egt's Reply with quote
Have switched probes and even replaced them without much difference.
BUT...When I switched to the next-up main jet size in both carbs (.165mm up to .175mm) and moved the jet needle one notch richer, the problem was fixed. Now EGT's are within 25 to 50 deg of each other and plugs have nice brown tint to the insulator and look the same.
Boy I love these 2-stroke engines. They kind of force you to go the extra mile and understand their workings more than most 'start and go' engines. Knowledge is power!
Here's another theory. I have individual air filters on each carb instead of the single oval filter who's lumen is common to both carbs. I wonder if the one up front experiences a little different 'ram air' pressure as a result and might cause the front to run leaner.
akflyer
PostPosted: Fri Jun 26, 2009 10:56 am    Post subject: Re: mismatched egt's Reply with quote
dont know if you have read the articles by Mike Stratman about the proper care and feeding of your 2 stroke, but it does make you understand the different circuits on the carbs and how to properly tune them instead off guessing at what you need to do.
I am right at sea level so I have 2 jets. 170s in winter 165s in summer.
DO NOT ARCHIVE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
