Matronics Email Lists BBS Forum Interface to the Matronics Email Lists
johnd
Posted: Mon Jun 22, 2009 9:28 am Post subject: Instrument panel |
Hi Craig,
I used the same system for my panel, the one key thing I learned is that
having the thick border around the text you are printing is very
important. If you don't have it the text wont transfer over properly to
the mylar material and your labels will be toast.
You mention your planning to use the black, I initially tried the white
material and found it more difficult to use than the light brown than I
eventually used for my panel. I've read elsewhere that others have had
more troubles with the white material as well.
John Davis
N601JD - Jab 3300
Burnsville, NC
Craig Payne wrote:
Thanks! I'll be using the black on my white panel. So I think I could use
one of the other colors for practice and have all the black left for the
real panel.
Any other tips that you learned or is it just a matter of getting a feel for
it?
-- Craig
Posted: Mon Jun 22, 2009 10:13 am Post subject: Instrument panel |
Thanks. When you say "thick", how thick is enough?
-- Craig
johnd
Posted: Mon Jun 22, 2009 10:19 am Post subject: Instrument panel |
Hi Craig,
I ended up using a line about 1/10 of an inch, I started with a really thin line and had problems till I moved to a thicker line.
Good Luck, its a great labeling system once you get the hang of it...
John
Craig Payne wrote: [quote] [quote]--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com> (craig(at)craigandjean.com) Thanks. When you say "thick", how thick is enough? -- Craig --
Posted: Mon Jun 22, 2009 10:26 am Post subject: Instrument panel |
Thanks, any problem with text with no border?
-- Craig
From: owner-zenith-list-server(at)matronics.com [mailto:owner-zenith-list-server(at)matronics.com] On Behalf Of John Davis
Sent: Monday, June 22, 2009 12:15 PM
Subject: Re: Re: Instrument panel
Hi Craig,
John
Craig Payne wrote: [quote]--> Zenith-List message posted by: "Craig Payne" <craig(at)craigandjean.com> Thanks. When you say "thick", how thick is enough? -- Craig --
johnd
Posted: Mon Jun 22, 2009 10:41 am Post subject: Instrument panel |
Hi Craig,
You must use a border around each label to do the transfer process but you can remove the border after you've done that so your final text doesnt have to have a border. The think border just helps in the process to transfer the labels from the paper to the mylar material. Then you can trim it off.
John
Craig Payne wrote: [quote] <![endif]--> <![endif]-->
-- Craig
From: owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com) [mailto:owner-zenith-list-server(at)matronics.com (owner-zenith-list-server(at)matronics.com)] On Behalf Of John Davis
To: zenith-list(at)matronics.com (zenith-list(at)matronics.com)
Hi Craig,
John
annken100
Posted: Mon Jun 22, 2009 11:38 am Post subject: Re: Instrument panel |
Craig,
Like John said, a thick border around your graphics is important. It helps your graphics survive the shock of being dunked in water to release the carrier mylar. I used 1/8" borders because the white foil seems to be a bit more sensitive to the water dunk.
If you are using black lettering you should be able to skip the film step and transfer the toner directly. The only thing you need to experiment with is whether the toner alone is opaque enough over the color of your panel.
Let me know if you have more questions.
Good luck,
Ken
_________________ 601 XL / Corvair |
