AirMike
Posted: Tue Jun 23, 2009 6:49 pm Post subject: Fuel tank leak testing |
Getting a bit crazy - worrying about fuel tank leaks. Anyways, I bought the Vans fuel tank test kit. The kit is fine, but it is hard to find a leak-proof balloon. All the balloons seem to sag after a bit causing you to worry if it is leaking or not. you really need to use a mylar balloon and helium.
Anyway, I have the wings temporarily mounted with hardware store bolts, so I took the bull by the horns today and filled one tank with auto gas. This should provide definitive evidence of any leak. Figure that I will drain it and place the fuel in the other tank to test it.
PS: Does anyone know of a fuel dye that will not mess up my fuel system when I put it in my Toyota SUV???
_________________ See you OSH '18
Q/B - sold. |
Kelly McMullen
Posted: Tue Jun 23, 2009 7:25 pm Post subject: Fuel tank leak testing |
Marvel Mystery Oil will give it a red tint.
On Tue, Jun 23, 2009 at 7:49 PM, AirMike <Mikeabel(at)pacbell.net (Mikeabel(at)pacbell.net)> wrote:
OSH '08 or Bust (busted) be there someday
Q/B Kit - FWF end game
http://forums.matronics.com/viewtopic.php?p=249742#249742
le, List Admin.
A&P/IA, EAA Tech Counselor
KCHD |
Posted: Wed Jun 24, 2009 2:36 am Post subject: Fuel tank leak testing |
This might help find obvious leaks in the bottom of the tanks and maybe the back bulkhead, but probably not in the top of the tank. The ballon test gives a little pressure to simulate flying.
Do not archive.
Jesse SaintSaint Aviation
352-427-0285
On Jun 23, 2009, at 11:24 PM, Kelly McMullen <apilot2(at)gmail.com (apilot2(at)gmail.com)> wrote:
[quote]Marvel Mystery Oil will give it a red tint.
On Tue, Jun 23, 2009 at 7:49 PM, AirMike <[url=mailto:Mikeabel(at)pacbell.net]Mikeabel(at)pacbell.net (Mikeabel(at)pacbell.net)[/url]> wrote:
Ron B.
Posted: Wed Jun 24, 2009 12:52 pm Post subject: Re: Fuel tank leak testing |
Just tested with 100LL two days ago. I had already air tested them when I completed them , but wanted to test them with fuel before painting them. So far so good.
I mounted a tubing on the vent line and bent it upward a couple inches. As the fuel temperature rose the fuel level also rose. When fuel came out the raised vent, I would assume this would be a true test. Most of the air should be out and tank full of fuel. We had the tanks on saw horses and level.
Ron
