tc1917(at)bellsouth.net Guest
Posted: Wed Jun 24, 2009 2:35 am Post subject: cuyunna |
I am going to step out in defense of the ole 202 cuyunna engine. I have had
three of them and I want to tell you this: I have never had one go out on
me or fail me because of something it did. It was all ME. I pushed it too
hard, bad fuel, lines, squeeze bulbs, plugs, argh. I have however, had the
supposed good ole rotax stop on me. I lost a crank with no sign of failure
and no real reason, it just seized. One of the little bearings was square I
guess and it went to lunch and took its buddies with them. I have had a
lots of fan belt problems with the rotax but cooling with the 20II was no
problem if you just kept it in its envelope. Never, I repeat, Never try to
outclimb a rotax with a 20II cause it is not the same and wont do it. So, I
guess apples and oranges. If you treat any engine correctly and stay within
its tolerances, you should have good luck with them. We are our worse
enemies. Ted Cowan, original firestar 447, kobra cuyunna, pterodactyl
cuyunna. Slingshot 912UL. By the way, I might have a fix for the rum rum
of the 912. I have to experiment on this concept and let you know. If it
is it, many will appreciate it. It might not be what we all throught it
might be. (hey, sounds like life, huh.)
George Myers
Joined: 10 Jan 2006 Posts: 76 Location: San Marcos, Texas
Posted: Thu Jun 25, 2009 7:19 pm Post subject: cuyunna |
Cuyuna..Lakota Souix word for birdshit or paratrooper. Literal translation
`falls from sky'
