		Rical26
				 Posted: Mon Jun 22, 2009 5:03 am    Post subject: 582 on floats question?? |
				HI, I'm looking to buy a kitfox 3 or 4 and wondering if a 582 will be
 good enough on floats (with a passenger). I'm looking at Puddlejumpers
 amphies floats, about 150LBS. Any comments and numbers would be appreciated!
 Noel, I think  you had a 582 with IVO IFA, was it good enough??
 regards
 Richard
  |  | - The Matronics Kitfox-List Email Forum - |  |   |  Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:
		Float Flyr
				 Posted: Mon Jun 22, 2009 6:08 am    Post subject: 582 on floats question?? |
				I think the plane would have been good enough to carry two depending on
 weight.
 My plane has an MTOW of only 950lb and I've never gone over that weight.
 Full tanks, myself, fishing and emerg gear comes out around 35 lb short of
 that weight.  The 582 has very high power to weight ratio the Ivo lets you
 take advantage of all of it.
 Just of the record with the ivo my initial ROC from sea level is above
 1500ft/min.  Tanks full.  Climb to altitude under 3000 averages just over
 100 ft/min.  As far as I can make out I use around 4 gal/ hr cruising and
 close to twice that doing T&Gs.
 Noel
  _________________ Noel Loveys
Kitfox III-A
Aerocet 1100 Floats |
		Rical26
				 Posted: Mon Jun 22, 2009 11:44 am    Post subject: 582 on floats question?? |
				Thanks Noel for your reply.Sorry, but what is ROC? Climb to altitude
 under 3000' is only 100 ft/min with floats?
 Richard
  weight.
  Noel
		Float Flyr
				 Posted: Tue Jun 23, 2009 7:42 am    Post subject: 582 on floats question?? |
				Rate of climb.. I also made a typo it was supposed to be just over
 1000'/min...  Flying with a 100 ft/min ROC isn't what I'd consider safe
 unless you were out on the praries.
 I also forgot to say my plane is one of the last model II to be built and
 was wupposed to be upgraded to model III... It has the under cambered wings
 and is less than 600 lb tare.
 Noel
Kitfox III-A
		akflyer
				 Posted: Tue Jun 23, 2009 8:04 am    Post subject: Re: 582 on floats question?? |
				you guys are getting some pretty darn good performance.  My buddies KF II on wheels, 582 72" IVO IFA climbs about 1200 FPM and around 700 FPM on floats solo with 9 gallons in the nose tank, a little less if you fill the 12 gallon wing tank.  My Avid with same engine and prop only gets about 900 FPM solo with 28 gallons.
  _________________ DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
IVO IFA
Full Lotus 1450
I would rather die trying to live, than to live trying not to die.... |
		Float Flyr
				 Posted: Tue Jun 23, 2009 8:38 am    Post subject: 582 on floats question?? |
				No speed... 75-80 on a good day.  But with the Ivo IFA I do get rocket ship
 climb at close to 900 lb.
 I'm getting close to getting the 'Fox back in the air with the new 912.
 Noel
Kitfox III-A
		Lynn Matteson
				 Posted: Tue Jun 23, 2009 9:13 am    Post subject: 582 on floats question?? |
				My sympathies, Noel.                   Just kidding. : )
 Lynn Matteson
 Jabiru 2200, #2062, 682.9 hrs
 Sensenich 62x46 Wood prop
 Status: flying
 On Jun 23, 2009, at 3:08 PM, Noel wrote:
  	  | Quote: | 	 		   I'm getting close to getting the 'Fox back in the air with the new
  912.
  Noel
  _________________ Lynn
Kitfox IV-Jabiru 2200
N369LM |
		Rical26
				 Posted: Wed Jun 24, 2009 3:23 am    Post subject: 582 on floats question?? |
				Thank you so much Noel for your info..
 I'm from Ottawa Ontario, Canada
 Richard
  Noel
		Ken Potter
  Joined: 18 Aug 2007 Posts: 85 Location: Lanark, Ontario
				 Posted: Fri Jun 26, 2009 9:40 am    Post subject: Re: 582 on floats question?? |
				Richard;
 I'm in Lanark Village just west of Ottawa.  There are several Kitfoxs in Eastern Ontario.  My own Mk II is just nearing completion  (582 c box). I have a set of Zenair floats which I have purchased as I plan to keep it at my cottage.  Give me a call at  613 259-3242 if you want to chat or come up and take a look at the plane.
 Cheers
 Ken
  _________________ Ken Potter
Model II, No. 483
Rotax 582, C-Box,
99% Complete
C-FJKP
Lanark, Ontario |
