Posted: Wed Jun 24, 2009 3:20 am Post subject: R: VGs |
I>>
If I put on the wings the VGs, the speed cruise increases or decreases?
Charly
you will not notice any difference in the cruise but the stalling speed will
be lower by about 5mph
Pat
sky-king(at)inbox.com Guest
Posted: Wed Jun 24, 2009 12:39 pm Post subject: R: VGs |
My stall speed lowered by 10 mph.
[quote] --
Posted: Wed Jun 24, 2009 3:51 pm Post subject: R: VGs |
Subject: Re: R: VGs
Brad S:
That is an impressive improvement.
What was your stall speed prior to, and after installation of
VGs?
At what altitude did you conduct your tests?
What were the differences in stall characteristics prior to and after
installation of VGs?
How did the VGs affect speed at your normal cruise power setting?
Did you test stall in ground effect, before and after?
What airplane are you flying?
Would you please expand on your experience flying this airplane before and
after?
If I could get a 10 mph reduction in stall speed in ground effect, I could
land at 20 mph.
mkIII - Always impressed with the dramatic improvements in aircraft
performance and handling after installation of VGs.
_________________ John Hauck
Titus, Alabama |
Posted: Thu Jun 25, 2009 1:36 am Post subject: R: VGs |
performance and handling after installation of VGs. >>
John,
you are fighting a rearguard action but by crackey you are doing it very
well.
Pat
Posted: Thu Jun 25, 2009 3:08 am Post subject: R: VGs |
At 06:50 PM 6/24/09 -0500, you wrote:
land at 20 mph.
John,
The only way to find out is to try them. Why depend on others to do the
research for you? It only takes about $10 for materials and a few minutes
of your time to make them.
See "Vortex Generators" at:
http://www.jackbhart.com/firefly/fireflyindex.html
Posted: Thu Jun 25, 2009 3:38 am Post subject: R: VGs |
Hi John,
To answer some of your questions,I will first throw in a disclaimer.Iam not a 1000 hr or more pilot,just a dumb old country boy who likes to fly.
My stall speed prior to vg's was 42mph indicated and 32mph after,there is very possible a + or - a few mph because of all the things that we know that can cause errors.
There is not a lot of difference in stall handling before or after,Iam flying a Kolb mk3 and she has a very gentle stall, and no tendency to drop a wing,there never was any violence as reported by some others.
In ground effect before vg's in the 42-45mph range the plane would just drop to the runway,after the vg's I can get down into the 32-35mph range and the plane just seems to settle to the runway.
I hope this helps someone.
[quote] --
Posted: Thu Jun 25, 2009 4:48 am Post subject: R: VGs |
| Quote: | The only way to find out is to try them.
Morning Jack:
I have tried VG's, several times. I have also done a side by side flight
comparison between my fat old bird and a much lighter MKIII. The results of
those flights did not convince me to install VGs on my airplane.
This last flight West was interesting. There were times when I could have
used a lot more lift. Then there were times when I wished I had spoilers
installed on my wings. At the Rock House, in the desert of SE Oregon, we
watched our Kolbs attempting to fly and flying while tied down. Then there
was the difficult time at Grants, NM, where we were trying to deal with a
density altiutude of 9,300 feet, severe turbulence, cross wind, and dust
devils, on take off. I don't know if VGs would have helped me at Grants or
not.
Titus, Alabama |
Posted: Thu Jun 25, 2009 5:06 am Post subject: R: VGs |
can cause errors.
| Quote: | In ground effect before vg's in the 42-45mph range the plane would just
Brad S:
A 10 mph decrease in stall speed is still a very impressive number.
In ground effect I get the same flight characteristics as you on the FSII I
was flying with VGs. The break at stall was very gentle. Other than that,
I could not find any other improvements in flight over a FSII without VGs.
My experience with Kolb aircraft indicates they fly as well without as they
do with VGs except for the very gentle break on landing. As far as extra
steep climbs, steep turns, and great control right through the mush/stall,
they all do it without VGs.
I have discovered I can make good landings if I stall the airplane closer to
the ground. If I stall it a foot above the ground, it will drop a foot. If
I don't want to take the chance of dropping in, I can always fly the Kolb to
the ground above stall speed.
Titus, Alabama |
Posted: Thu Jun 25, 2009 5:08 am Post subject: R: VGs |
Patrick:
No fight intended.
Trying to learn.
Titus, Alabama |
robcannon
Joined: 22 Jun 2008 Posts: 39 Location: British Columbia
Posted: Thu Jun 25, 2009 6:25 am Post subject: Re: R: VGs |
Kolb Mark II, Hks 700 E, 550 lbs empty, 180 lb pilot, 2000'asl. Initial flights with no vg's I was surprized and unhappy with my high stall speed of 38 mph power off. I added vg's as an experiment with low expectations. You should have seen my face when I landed after the first flight with vg's. Ten dollars worth of hardware store flashing and a days messing around and my stall dropped minimum 10 mph. That's right TEN mph ! TEN DOLLARS - TEN MPH. Stall characteristics did not change that much - clean break around 26, but will mush along in full control right down to 26.
The advantages here are obvious. The disadvantages are minuscule. Top speed does not seem affected, but my testing would not be very accurate as my plane is easily goes over vne, and low speed is my focus, so I didn't do very scientific testing. I thought washing the wing would be a hassle but the soft bristle brush I use doesnt seem to notice the vg's.
If anyone wants to make there own I'll send you a pattern one and instructions. I tested different adhesives and decided upon indoor/outdoor carpet tape from wallmart. It's sticky shit that is never coming off and is much cleaner to use than any liquid adhesive ( just happens to come in a roll the same width as the vg's). I put a rivet in the ones in front of the prop just in case but in hindsite I don't think it was necessary. Try it you'll like it !! Rob Cannon
robcannon
Posted: Thu Jun 25, 2009 6:45 am Post subject: Re: R: VGs |
Oh yeah, forgot the landing part. I can now land at fifteen mph in ground effect. ............. Just kidding ..... With my 26 mph stall, I cant land this slow as my tail will be too low. I built tall gear legs and I can get down pretty slow (32 - 35) but any slower and the tail hits first.
The advantage is a huge safety margin at slow speeds. Theoretically I could fly approaches at 39 mph ( with a 1.5 safety factor), but I fly them at 45 - 50. If I have an engine failure, I can do a 180 at 45-50 and be around quicker and higher. blah,blah,blah, Rob
Dana
Posted: Thu Jun 25, 2009 9:34 am Post subject: R: VGs |
At 10:26 AM 6/25/2009, robcannon wrote:
| Quote: | ...my stall dropped minimum 10 mph.... The disadvantages are minuscule...
Perhaps... but one thing concerns me. My UltraStar supposedly stalls at
25mph (it's 30mph indicated). It gets risky to fly an airplane when the
wind is a significant fraction of your stall speed (one half is the usual
rule of thumb). As a PPG pilot also, you can imagine I'm quite sensitive
to this. As it is, I hesitate to fly on breezy days; I'd hate to lower
that flyable threshold at all.
-Dana
Question Authority and the authorities will question you!
JetPilot
Posted: Thu Jun 25, 2009 11:32 am Post subject: Re: R: VGs |
-Dana
Dana,
Your understanding of this is wrong. What you do not want is a gust causing a loss of airspeed and stall in the airplane. VG's expand your flying envalope and increase your safety margain aginst gust induced stall. Lets take a Firestar, say it stalls at 30 MPH. If you approach at 40 MPH, a 10 MPH gust could place you at the stall speed. With the same firestar with VG's, if you stall at 22 MPH with VG's, a 10 MPH gust would not cause a stall, it would take an 18 MPH gust to put you at stall speed. This equals increased safety.
You have taken something that is generally true, and misapplied it. The danger is when an airplane stalls very slow, and is ALSO have a very low approach speed. The VG's do not mean that you have to fly your approaches slow if you are in windy weather. VG's actually INCREASE safety and your protection against gust induced stalls.
Mike
Question Authority and the authorities will question you! |
Kolb MK-III Xtra, 912-S |
JetPilot
Posted: Thu Jun 25, 2009 11:34 am Post subject: Re: R: VGs |
-Dana
Dana,
Your understanding of this is wrong. You are misapplying a generality that applies to slow flying airplanes where the approach speed is very close to what its stall speed is. What you do not want is a gust causing a loss of airspeed and stall in the airplane. VG's expand your flying envelope and increase your safety margin against gust induced stall. Lets take a Firestar, say it stalls at 30 MPH. If you approach at 40 MPH, a 10 MPH gust could place you at the stall speed. With the same Firestar with VG's, if you stall at 22 MPH with VG's, a 10 MPH gust would not cause a stall, it would take an 18 MPH gust to put you at stall speed. This equals increased safety.
Mike
JetPilot
Posted: Thu Jun 25, 2009 11:35 am Post subject: Re: R: VGs |
| Dana wrote: |
-Dana
Dana,
Mike
Posted: Thu Jun 25, 2009 12:26 pm Post subject: R: VGs |
Mike B:
So...I increase my approach speed 10 to 15 mph and I am good to go without
VGs.
I'm not concerned over the small amount of difference in speed between "with
and without VGs" when I stall at 30 mph IAS in ground effect. Even if I
stalled at 40 mph in ground effect, I still would not be concerned about my
approach speeds of 50 to 60 mph IAS.
I'm very conservative when it comes to stall and approach speeds. I usually
shoot my approaches at 50 to 60 mph IAS, even on my short 750 ft strip.
VGs aren't going to do a whole lot to improve safety. We are talking of
very slow speeds with and without. Most average pilots should be able to
adjust a couple mph.
What makes landing with zero ground roll so important?
MKIII
Titus, Alabama |
JetPilot
Posted: Thu Jun 25, 2009 1:14 pm Post subject: Re: R: VGs |
John H,
My ground roll is most assuredly longer than yours is, even with VG's.. I need bigger brakes !!!
Mike
Posted: Thu Jun 25, 2009 1:41 pm Post subject: R: VGs |
Mike B:
Get some good MATCO's with 3/4" axles and tapered roller bearings. I have
had mine since I wiped off the main gear 9 years ago next week.
In fact, they are so good they slow the mkIII down before touch down.
hehehe
Titus, Alabama |
Posted: Thu Jun 25, 2009 1:52 pm Post subject: R: VGs |
At 03:24 PM 6/25/09 -0500, you wrote:
John,
Zero ground roll is a splat, but it what is important is a low energy
landing. Where this is useful is when you are landing on an unfamiliar
landing area. The slower you can fly the plane at touch down the less
likely you are going to bend something or tear out a leg socket. Why risk
the plane? This does not rule out the use of a high energy approach to
landing. Also, this is why it is important to learn to three point. VG's
will knock the energy down by 5 to 10 mph. In this case it can make the
difference of flying or trucking it home. I have done both and flying is
much more fun.
Fly safe.
Jack B. Hart FF004
Winchester, IN
zeprep251(at)aol.com Guest
Posted: Thu Jun 25, 2009 2:05 pm Post subject: R: VGs |
Think I'll put 3 sets on ,then I can hover.
G.Aman mk-3c
