COAXIAL CABLES recommendations
Thruster87
PostPosted: Fri Jun 26, 2009 9:51 pm    Post subject: COAXIAL CABLES recommendations Reply with quote
Any recommendations for which coax can be used to wire the radio and the transponder ???? RG 400 - Standard cable for radio installations. Double shielded stranded conductor, MIL-DTL-17 spec. Approved for certified aircraft.
PN 11-09202 $2.75 ($3.55AUD)
RG 142 - Low loss coax cable for GPS, TPX, and DME installations. Double shielded solid conductor, MIL-C-17 spec. Approved for certified aircraft.
PN 11-00043 $2.95 ($3.80AUD)
RG 58A/U - Standard cable for experimental avionics installations. Single shielded stranded conductor, jacket type – PVC. For experimental aircraft only.
PN 11-03920 $0.46 ($0.59AUD)
RG 58C/U - Standard cable for experimental avionics installations. Single shielded stranded conductor, jacket type – Non-PVC. For experimental aircraft only.
PN 11-04258 $0.46 ($0.59AUD) Thanks
floyd wilkes
PostPosted: Sat Jun 27, 2009 3:22 am    Post subject: COAXIAL CABLES recommendations Reply with quote
I used RG58A/U for my radios and VOR. Same stuff that is on my 65 Cherokee
that has been working for 40 years.
I used the RG 400 for the GPS antenna.
The reason for the 58 was cost savings. If you check ebay you can find RG
400 for $1.00 per foot. At that price, I would have used it for everything.
Floyd Wilkes
Zodiac 601XL
Floyd Wilkes
PostPosted: Sat Jun 27, 2009 7:50 am    Post subject: COAXIAL CABLES recommendations Reply with quote
Cherokee that has been working for 40 years.
find RG 400 for $1.00 per foot. At that price, I would have used it
for everything.
Floyd Wilkes
Zodiac 601XL
Good thought. RG58 is pvc and polyethylene
for insulation . . . the best we knew how
to do in WWII. RG-400 and cousins are modern,
high temperature materials and double shielded
to boot. The best we know how to do in 2009.
It's a plugs, points and coil versus electronic
ignition kind of decision. Both will function
as advertised.
( -Thomas Paine 1776- )
