Gear Box Ratio
Ken Potter
PostPosted: Mon Jun 29, 2009 4:23 am    Post subject: Gear Box Ratio Reply with quote
Hi folks. I am trying to determine the ratio of my Rotax 582 C Box. The serial number on the front case is 7042. Does anyone know of site with serial number lookup to determine ratio from the numbers??
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
98% Complete
C-FJKP (marks reserved)
Lanark, Ontario
Tom Jones
PostPosted: Mon Jun 29, 2009 5:20 am    Post subject: Re: Gear Box Ratio Reply with quote
Ken, I don't think there is any way to look up the gear ratio. It should be stamped on the front of the gear box right behind the prop and just above the drain plug. It will be one of these numbers, 2.62, 3.00, 3.47, or 4.10.
If yours doesn't have the ratio stamped you can count the engine revolutions with one turn of the prop flange. Look in the intake or pull the plugs and count the times the piston returns to the starting point with one complete revolution of the prop flange. Example, if it is less than 3 your ratio is 2.62. More than 3 and and less than 4, it is 3.47, etc.
Tom Jones
Classic IV
Ellensburg, WA
Lynn Matteson
PostPosted: Mon Jun 29, 2009 8:09 am    Post subject: Gear Box Ratio Reply with quote
Isn't there an exposed flywheel that you can mark, and thereby get
the exact ratio?
Lynn Matteson
Jabiru 2200, #2062, 687.3 hrs
Sensenich 62"x46" Wood prop
Status: flying
Tom Jones
Classic IV
Ellensburg, WA
http://forums.matronics.com/viewtopic.php?p 50578#250578
Lynn
Kitfox IV-Jabiru 2200
N369LM
akflyer
PostPosted: Mon Jun 29, 2009 8:40 am    Post subject: Re: Gear Box Ratio Reply with quote
the exact ratio?
Lynn Matteson
Status: flying
Tom Jones
Classic IV
Ellensburg, WA
Yep, there is a nice big hole in the side of the gear box. Just mark the hardy joint and count how many times it turns with one prop revolution.
DO NOT ARCHIVE
Leonard Perry aka SNAKE
Soldotna AK
Avid "C" / Mk IV
582 (87 hrs and counting on the rebuild)
IVO IFA
Full Lotus 1450
hander outer of humorless darwin awards
jridgway
PostPosted: Thu Jul 02, 2009 12:46 pm    Post subject: Re: Gear Box Ratio Reply with quote
I remember reading in one of the KITFOX service letters that all they ever delivered was a 3:1. Hope this helps.
Jack
Ken Potter
PostPosted: Wed Jul 08, 2009 3:34 am    Post subject: Re: Gear Box Ratio Reply with quote
Thanks to everyone for their advice. I took Leonards advice and marked the Hardy Joint and turned the prop. It was 3:1 so I suspect that Jack was right, that this was the standard for Kitfox at the time.
Cheers
Ken
Ken Potter
Model II, No. 483
Rotax 582, C-Box,
98% Complete
Lanark, Ontario
