Door fit
johnfcliff(at)googlemail.
PostPosted: Mon Jul 06, 2009 7:23 am    Post subject: Door fit Reply with quote
One of my doors bows out proud of the fuselage along its lower edge,
evidently the door frame is too curved along the bottom.
Has anyone else encountered this and tried remodelling the frame
(perspex not in yet) with gentle heat ?
Or any other ideas ?
John Cliff
#0259
rampil
PostPosted: Mon Jul 06, 2009 8:16 am    Post subject: Re: Door fit Reply with quote
Hi John,
Nearly every Europa I have seen in the field (i.e., out of the build
environment) has this issue. It seems to happen more rapidly in
warm environments like Florida. Many fixes have been proposed,
none agreed upon. Moving the strut helps the rear bulge, but not the
base of door bulge. A few folks re-engineered the shoot bolt mechanism
to add a third locking point at the bottom of the door into the side of
the fuselage. I don't know if this is effective in the long term.
Ira
Doing my 5th year Annual
Ira N224XS
fklein(at)orcasonline.com
PostPosted: Mon Jul 06, 2009 8:43 am    Post subject: Door fit Reply with quote
John,
I too have encountered this...Bud Yerly had a fairly comprehensive
post some time ago about this condition and how to deal with it.
Fred
A194
believed to be clean.
grahamsingleton(at)btinte
PostPosted: Mon Jul 06, 2009 9:36 am    Post subject: Door fit Reply with quote
rampil wrote:
Hi John,
Ira
Ira N224XS
don't do this, not approved in UK, it weakens the door sill too much..
You can make a nylon wedge/latch that will work just as well. Mal McLure
did it this way years ago. Neat and effective. Might have been Bob
Berube's idea although Jonti Docker suggested it too. He used to make
all the fuselage mouldings
Graham
europa471
PostPosted: Tue Jul 07, 2009 4:20 am    Post subject: Door fit Reply with quote
I ¨adjusted¨ the door curve as I was doing the wide body mod.
After removing the required section of inside skin, the frame is very
flexible and can be held at the desired curve while fitting the new
inside moulding.
Lance Sandford in OZ
John Cliff
#0259
