		Bill1200
  Joined: 19 Oct 2008 Posts: 111 Location: medford oregon
				 Posted: Thu Jul 09, 2009 10:52 am    Post subject: Replacing -52 compressor |
				Wasn't getting pressure to build up while flying again. (last time was the snot valve not seating) This time I disconnected the line from the compressor to the snot valve, started it up, no pressure coming from compressor, zero. So, question is how difficult is it to remove and replace the compressor, looks incredibly difficult to get at all the attachment bolts.
				 Posted: Thu Jul 09, 2009 11:17 am    Post subject: Replacing -52 compressor |
				I am not qualified to discuss the compressor removal Bill, as I only
 watched it being replaced one time, BUT ....
 It very well could be your compressor that is bad, but before you go
 yanking it, one of the things I usually do is to hook up 500 psi air and
 blow it back in the line you just disconnected at the snot valve, but
 blow it in BACKWARDS!  I mean, reverse pressurize the line so it is
 putting pressure back towards the compressor.
 Why?
 Because it is very easy to have a cracked line .... The line that runs
 from the compressor to the snot valve breaks ALL THE TIME.  So much so
 that Doug Sapp sells a hose to replace the original one with a flex
 line.  Smart thing to do by the way in my opinion, but some disagree.
 Whatever.  The bottom line is that you could easily have a cracked line,
 a broken flare, etc.
 Another place to be especially aware of is the BANJO FITTING!  This
 thing leaks ALL the time!  If you are testing this thing by running the
 engine and putting your finger over the line to see if any air is coming
 out, this can easily lead you to believe you have a bad compressor when
 in fact what you might have is just a bad leak.
 Hooking up air and blowing it backwards into that line will allow you to
 listen for leaks.  There may be other ways to do it, but that is what I
 have done personally.  There is a one way check valve up past the Banjo
 fitting on the compressor that will keep the air from going back into
 the compressor.
 So yes.. It could be a bad compressor... But if you haven't checked
 carefully... It could also be a leaking line.
 Mark Bitterlich
		jan.mevis(at)informavia.b Guest
				 Posted: Thu Jul 09, 2009 12:51 pm    Post subject: Replacing -52 compressor |
				It can also be the shear pin coupling. So the compressor may still be ok,
 but you have to unmount it to check or replace the shear pin (after having
 done the tests Mark indicated). Replacing the compressor takes quite some
 time if you don't have the Russian tools (and even with the Russian tools,
 it's a time demanding job; you'll need a lot of patience). Only six bolts,
 but three of them of course at an inaccessible place.
 Jan
		Bill1200
				 Posted: Thu Jul 09, 2009 8:30 pm    Post subject: Re: Replacing -52 compressor |
				Thanks guys, have been talking with Doug. Disconnected the banjo fitting and cleaned it out. Ran the engine with the banjo fitting off. No air coming from compressor. One other thing he suggested was a stuck valve in the piston itself. Will work on that Saturday, not looking good. Appreciate the help.
		HawkerPilot2015
				 Posted: Fri Jul 10, 2009 7:17 am    Post subject: Re: Replacing -52 compressor |
				Put a surgical glove over the top of the compressor and pull the prop through.....
 If the glove is drawn towards the compressor you can begin to eliminate problems.
 And it sucks (no pun intended) to replace that mofo.
		Bill1200
				 Posted: Fri Jul 10, 2009 8:29 am    Post subject: Re: Replacing -52 compressor |
				Mark, I like the back pressurization idea for future trouble shooting, with no air coming from the compressor I think the problem is in there. My question for you is how to make the connections for such a hose. I'm guessing one end with a typical scuba tank connection, the other end with the appropriate sized male threaded piece to fit the tube from the compressor. Can a scuba shop do this if I give them the fittings?
				 Posted: Fri Jul 10, 2009 11:41 am    Post subject: Replacing -52 compressor |
				I have been lucky enough to make a few adapters that allow me to mate
 AN-4 or AN-6, to the Russian "sorta AN-5's".  I say "sorta", because
 they are obviously metric, but the size is roughly that of an AN-5
 fitting, which is rather rare by the way.  The Russian flares are the
 same as ours, so you can take any Russian line, cut off the end,
 re-flare it and put a standard AN fitting and sleeve on the same hard
 line.  Or you can do it the other way around.  You usually have to take
 the metric thread on portion and enlarge the hose "hole" to allow it to
 fit right on a standard U.S. line.  There are a lot of folks much better
 qualified to do this than me that read this list.  I think Doug Sapp
 could make one for you.  I do not use scuba tanks, so I really don't
 know the answer to what you are asking, but anything is do-able really.
 The trick is to have a regulator.  If you put 2000 psi straight from a
 scuba tank into a line like that, it would be a bad thing.  I have an
 actual 3000 psi nitrogen bottle with regulator that I use as a source.
 I know.. Not everyone has something like that.  Just be careful to not
 put more than 700 psi or so into the line.
 Mark
