Typical Cruise
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith650-List
pequeajim
PostPosted: Fri Jul 03, 2009 7:46 pm    Post subject: Typical Cruise Reply with quote
What is the typical cruise for a 650, say at 8-9000 feet with a Jabiru 3300?
Does anyone know this yet?
Also, do the wing lockers take away some of the strength in the wings?[/list]
- The Matronics Zenith650-List Email Forum -
http://www.matronics.com/Navigator?Zenith650-List
pequeajim
PostPosted: Tue Jul 07, 2009 6:19 pm    Post subject: Re: Typical Cruise Reply with quote
Is there anyone flying a 650 with a 3300 in it?
pequeajim
PostPosted: Thu Jul 09, 2009 7:52 pm    Post subject: Re: Typical Cruise Reply with quote
Is there anyone on this list?
chuck960
PostPosted: Thu Jul 09, 2009 8:06 pm    Post subject: Re: Typical Cruise Reply with quote
I'll let you know when I get mine in the air but why would it be any different than a 601?
lwinger
PostPosted: Thu Jul 09, 2009 8:08 pm    Post subject: Typical Cruise Reply with quote
Yes, but I'm finding that most posts don't get any response.
Larry Winger
Tustin, CA
650/Corvair
Installing canopy
On Thu, Jul 9, 2009 at 8:52 PM, pequeajim <pequeajim(at)gmail.com (pequeajim(at)gmail.com)> wrote:
[quote]--> Zenith650-List message posted by: "pequeajim" <pequeajim(at)gmail.com (pequeajim(at)gmail.com)>
http://forums.matronics.com/viewtopic.php?p=252405#252405
s List Un/Subscription,
www.matronics.com/Navigator?Zenith650-List" target="_blank">http://www.matronics.com/Navigator?Zenith650-List
ronics.com/" target="_blank">http://forums.matronics.com
Matt Dralle, List Admin.
Larry Winger
Tustin, CA
Plans building 601XL/650 with Corvair
Installing fuel system
www.mykitlog.com/lwinger
pequeajim
PostPosted: Fri Jul 10, 2009 3:20 am    Post subject: Re: Typical Cruise Reply with quote
lwinger wrote:
Yes, but I'm finding that most posts don't get any response.�
Is it because there are not that many 650 builders on here, not interested, just not that many 650 builders as a whole?
pequeajim
PostPosted: Fri Jul 10, 2009 3:22 am    Post subject: Re: Typical Cruise Reply with quote
I wouldn't know, is there any difference from a 601 as far as cruise with a 3300?
brianrobertwood(at)gmail.
PostPosted: Fri Jul 10, 2009 4:04 am    Post subject: Typical Cruise Reply with quote
Well, I am here lurking, but all I know is what I read. I bought plans,
but am "on hold", first for lack of funds, and second, I am waiting for
more information concerning the break-ups. The one here in Brazil shook me
up a little, the builder was very active on a list here in Portuguese, and
he was very careful, very professional. It just doesn't make sense. I feel
like some important information is missing. The Brazilian FAA does not
investigate experimental accidents, so more potential information is lost.
I like the design, I trust the Heintz family, I like the plane, I have
seen the results of the flutter tests in Germany. Everything looks good.
So why the break-ups?
Brian
Em Fri, 10 Jul 2009 00:52:52 -0300, pequeajim <pequeajim(at)gmail.com>
escreveu:
http://forums.matronics.com/viewtopic.php?p 52405#252405
Brian R. Wood
JH Manutencao
Anapolis. Goias, Brazil
pequeajim
PostPosted: Fri Jul 10, 2009 4:28 am    Post subject: Re: Typical Cruise Reply with quote
So is the cruise basically the same as the 601XL? I am looking for a LS compliant aircraft that I can replace my Lightning with and build over time at home. I would like it to have the capabilities to be sporty, and cruise at 150+ at altitude, yet more roomy than say, a Sonex.
My Lightning is a great aircraft, but I can't afford to keep it right now with my "lack of" work going on. I don't expect the 650 to have to performance of the Lightning, but somewhat close would be good. This is what I am trying to establish.
I also want to try building a metal aircraft this time around.
Also, are there any other Zodiac forums out there? This one seems to be a bit anemic...
Jim!
PatrickW
PostPosted: Fri Jul 10, 2009 4:32 am    Post subject: Re: Typical Cruise Reply with quote
I lurk here too. Airframe mostly completed for my XL with a lot of 650 stuff on it.
Zenith doesn't advertise their low wing aircraft line in the print magazines anymore. So I wonder if they are moving away from that market? If so, then there may never be very many 650 builders. How many of the four seat 640's were built after they stopped advertising them...?
Would be a good question to ask them at Oshkosh...
- Pat
pequeajim
PostPosted: Fri Jul 10, 2009 4:45 am    Post subject: Re: Typical Cruise Reply with quote
- Pat
I will, thanks...
z601(at)anemicaardvark.co
PostPosted: Fri Jul 10, 2009 4:58 am    Post subject: Typical Cruise Reply with quote
It's designed as an LSA. Therefore, I would expect the maximum speed (as
designed) to be that of an LSA.
You might be able to tweak more speed, but given the open questions about the
XL, and the fact they share a lot of components, how wise that may be is open
to question.
You can check on my aircraft construction
progress at: http://www.mykitlog.com/santaigo
Jim B. Belcher
BS, MS Physics, math, Computer Science
A&P/IA
Instrument Rated Pilot
General Radio Telephone Certificate
Retired Aerospace Technical Manager
PostPosted: Fri Jul 10, 2009 5:10 am    Post subject: Typical Cruise Reply with quote
stuff on it.
There's a recession going on. Some of the magazines have reduced the number of
pages because advertisers as a whole have had to cut back on advertising. I
believe I remember the publisher saying GA News had reduced the page count by
16. He said lack of advertising was the sole reason. Look at the thickness of
Trade-a-Plane a couple of years ago vs now, as an example.
I suspect Zenith was already feeling the effects of the recession. With all
the negative publicity from the XL, I'd bet their sales are down, which
probably means their advertising budget is down. Hopefully, this is not an
endless spiral downward.
I do believe I have seen them advertising in Kit Planes every month, though.
That may be a mix of ads for the 750 and the 650.
Do not archive.
Jim B Belcher
BS, MS Physics, Math, Computer Science
A&P/IA
Retired aerospace technical manager
mcjon77
PostPosted: Fri Jul 10, 2009 9:10 am    Post subject: Re: Typical Cruise Reply with quote
150mph+ in a Zodiac? Nope. The 650 is essentially a 601XL with a few redesigns. The canopy is larger, allowing for a taller pilot. Also, the landing gear was strengthened, an the rudder was slicked back more.
As far as cruise speeds with the 3300, most of the numbers I have heard, even at altitude are in the low (to mid) 130's. This makes sense, because the 100hp 601XLs (continental and corvair) are in the mid to high 120's. This is at about 8k msl. Also, keep in mind that the 650 has the same wing as the 601XL, so IF there is a problem with the 601XL wing, then it most likely exists in the 650 as well. This is what one of the above posters was referring to when he mentioned waiting for more information about the in-flight breakups.
For the kind of speed you are talking about. I know of only 3 aircraft that can do that with a Jabiru 3300, and still qualify as LSAs. The Lighning, the sonex, and the sonerai. Europa is coming out with an LSA wing for their birds, so they might be an option later.
Jon McDonald
Building Sonex #1287
Next up CH 701 Very Happy
Doug.Norman(at)sportaviat
PostPosted: Fri Jul 10, 2009 10:07 am    Post subject: Typical Cruise Reply with quote
I'm not a 650 owner, but I am a 601 owner. Here's my understanding and my
experiences on the characteristics you're looking at.
The 650 solves a couple of user gripes - headroom, canopy closure, and
stodgy look of the rudder. The angle of incidence of the wing is back to
where it was a couple of years ago. It was reduced a few years ago based on
reported better performance from builders in Spain. Now it's raised so as to
provide a better view in cruise.
There are a few other small changes to the wing such as gussets on the
inboard side of the ailerons (I had these added when I was up at AMD for my
annual - it took a total of 45 min to manufacture and install the pieces).
The main gear was changed a couple of years ago. The airplane now sits
higher on the gear, and offers less of an angle of attack during the take
off run. The airplane must be rotated, it won't fly off on its own.
As far as speeds go, I see 105-110 knots TAS at 2450 rpm burning 5.7-6.3 gph
with the Continental O-200a. I have a bit more than 340 hours on the
airplane, and I keep records of every flight. This is what it gets. On a
cool day, one can see higher IAS near sea level (the best I've experienced
is 114 IAS during a Florida winter day at 1500 MSL).
With respect to LSAs, your speed is limited by the LSA definition. No faster
than 120 kts at max continuous power. One of the cub look-alikes now offers
a trick engine which can put out 180hp for a short time and this makes it a
phenomenal short field performer and initial climb.
I've had no trouble with my airplane; none at all. And I use it for both
pleasure and business travel. The reduced MTOW is troublesome; but I'm
pretty sure that will be returned to the 1320 soon. Its legs are marginal
for real cross country with the Continental in my view. I travel often at
the airplane's margins (300-400 nm) and the winds decide whether I can make
the trip without a stop while maintaining sufficient reserves.
The airplane is great to fly. Frankly, I purchased it for its sporty flight
characteristics and I have a little fear that the sportiness may be
engineered out of it to make it more acceptable to the broader masses. I was
b o r e d by the Cessna/piper 4 bangers. It felt like taking the family
truckster (nat'l lampoon / chevy chase reference) when you were dreaming of
the little sport car. It does require attention to fly when one is first
learning the airplane. In fact (true story), there were two CFIs I couldn't
clear to fly the airplane (I'm a CFI and I initially used the plane for
flight instruction). Both of these CFIs couldn't land the Zodiac. Both were
big-iron flyers - high wing loading. This tracks with the latest info from
the insurance industry.
Whatever you choose to build and/or fly, have fun with it!
Doug Norman
AMD Zodiac N601DN
Post new topic   Reply to topic    Matronics Email Lists Forum Index -> Zenith650-List All times are GMT - 8 Hours
