partner14
Posted: Mon Jul 06, 2009 9:51 pm Post subject: LSE cooling |
For those of you with the Lightspeed ignition, how are you cooling the main box? Spruce carries several cooling fans, most with multiple ports. Is this the only answer?
40636 |
orchidman
Joined: 10 Jul 2006 Posts: 277 Location: Oklahoma City - KRCE
Posted: Tue Jul 07, 2009 5:01 am Post subject: Re: LSE cooling |
| partner14 wrote: | | For those of you with the Lightspeed ignition, how are you cooling the main box? Spruce carries several cooling fans, most with multiple ports. Is this the only answer? |
I am using Stein's 3 output fan.
1. LSE
2. 430W
3. 327
That's all I needed.
_________________ Gary Blankenbiller
RV10 - # 40674
(N2GB Flying) |
bcondrey
Posted: Tue Jul 07, 2009 6:07 am Post subject: LSE cooling |
I have a 3 port avionics blower. One of the ports is split into 2
outputs to feed each of my LSE ignitions (3/8" air inlets). According
to Klaus you don't need much volume, just something to move the air
around so just about anything you pick will do fine.
Bob
rebrunk42(at)gmail.com Guest
Posted: Tue Jul 07, 2009 7:56 am Post subject: LSE cooling |
that's what i use. hooking one port to the cooling intake port on the
unit. klaus said to do it that way. robert
On Jul 7, 2009, at 12:51 AM, partner14 wrote:
Don A. McDonald
40636
http://forums.matronics.com/viewtopic.php?p 51881#251881
roadmaps
Posted: Mon Jul 13, 2009 5:56 pm Post subject: LSE cooling |
What did you or others use to transition from the cooling fan tubing to the
Lightspeed cooling port
John Testement
N311RV
#40321 Flying
bcondrey
Posted: Mon Jul 13, 2009 6:52 pm Post subject: LSE cooling |
I used a piece of 5/8" SCAT and found a nylon pipe thread to 3/8 ID barb fitting at the HW store. Then attached some 3/8 I'd tubung from there to the LSE cooling port. I actually have 2 LSEs so I put a tee in the line also.
Bob
orchidman
Posted: Tue Jul 14, 2009 3:33 am Post subject: Re: LSE cooling |
I used a 3/4" long piece of 3/8" I.D. plastic tubing on the LS and then the tubing from Stein slipped right over the plastic tubing. Slit both of them and then zip tie them. Made a very simple, tight, firm connection.
RV10 - # 40674
(N2GB Flying) |
Posted: Tue Jul 14, 2009 11:44 am Post subject: LSE cooling |
an adapter from home depot works well. robert brunkenhoefer N661G
flying
to the
John Testement
N311RV
#40321 Flying
