occom
Posted: Tue Jul 14, 2009 3:44 pm Post subject: Mod IV wheels and brakes |
I have a Mod IV with 8" aluminum wheels that have a 3 lug iron disc bolted to them. I have not flown this yet but wanted to rebuild the brakes.
After installing the Matco rebuild kit and bolting it all back together I noticed that neither disc runs true with about 1/8" or more of radial runout. Both run true axially.
I can't detect any real damage to this setup and wondered is this typical of Kitfox's. How does it affect braking?
dwight purdy
Posted: Tue Jul 14, 2009 3:56 pm Post subject: Mod IV wheels and brakes |
I have had that problem after the tires were changed and they bent the rims. I re-cut the lugs some and shimmed the one that did not clean up. The brakes do not work well if the run out much.
Dwight Purdy
Model II
_________________ dwight
model II |
dave
Posted: Tue Jul 14, 2009 6:29 pm Post subject: Re: Mod IV wheels and brakes |
Dave,
Question is what it not running true ?
Wheel , hub or tabs welded on........ Put on a lathe and spin it.
Go from there.
Rotor itself likely not the cause.
Dave
Hundreds of Kitfox Movies
Most viewed Kitfox on youtube
Most popular on youtube
Highest rated on youtube |
patreilly43(at)hotmail.co Guest
Posted: Tue Jul 14, 2009 6:30 pm Post subject: Mod IV wheels and brakes |
Dave C The Mod 3 I am rebuilding had a 1/16" aluminum shim between the brake disc and the rim on one mounting bolt. The wheels I have are pretty well beat up so it isn't surprising the disc is shimmed. But C that would be what you call axial run out I think. Seems like 1/8 " radial run out would be quite alot of radial run out. I don't know how you would correct radial runout except to relocate & redrill 3 new mounting holes in the disc C if I am understanding your radial C axial terminology.
Pat Reilly
mod 3 582 Rebuild
Rockford C IL
Subject: Re: Kitfox-List: Mod IV wheels and brakes
Date: Tue C 14 Jul 2009 19:52:36 -0400
Dwight Purdy
Model II
dave
Posted: Tue Jul 14, 2009 6:39 pm Post subject: Re: Mod IV wheels and brakes |
[quote="dwight purdy"]I have had that problem after the tires were changed and they bent the rims. I re-cut the lugs some and shimmed the one that did not clean up. The brakes do not work well if the run out much.
Dwight Purdy
Model II
HArd to bend ATV wheels if you use the correct tools.
http://www.cfisher.com/kingfox.html
Dave
lcfitt(at)sbcglobal.net Guest
Posted: Tue Jul 14, 2009 7:21 pm Post subject: Mod IV wheels and brakes |
Dave,
I'll take a stab at this. First, as I understand your post, when you spin
the wheels, the brake linings run true with the disk as it spins,but the
disk dances up and down between the linings. If this is the case, I think
the worst case scenario would be a slight out of balance when you leave the
ground and the wheel continues to spin a bit.
Many guys trim the brake disk in a fashon that eliminates all metal not
touching the linings with three tabs that connect to the bolts. You could
do this by marking the disks as they spin and using a metal cutting band
saw. The metal is cast iron and cuts pretty easily.
I just re-read your post and it appears that they might already be trimmed.
If so try rotating them by 1/3rd and see if this trues it a bit. Are you
the original buider? If they they are trimmed and don't run true, I don't
think braking would be seriously affected as some will drill lightening
holes in the braking face without diminishing brake effeciency. The latter
is just an opinion, though.
If I misunderstood what is not running true, disregard.
Lowell Fitt
Cameron Park, CA
Model IV-1200 R-912 UL
Covering
dwight purdy
Posted: Tue Jul 14, 2009 8:23 pm Post subject: Mod IV wheels and brakes |
Dave
I have never been able brake down the tire from rim after installed with
that black goo. The place I take them used to do a nice job. I think the new
young hires are the problem. This is not strictly an ATV shop but they do
allot of small lawn tires. Those are steel though.
Dwight Purdy
model II
model II |
dwight purdy
Posted: Tue Jul 14, 2009 8:43 pm Post subject: Mod IV wheels and brakes |
I guess I had axial and radial turned around.
Dwight Purdy
model II
model II |
