		rwhunter(at)integra.net Guest
				 Posted: Tue Jul 14, 2009 6:56 pm    Post subject: Tube Bender |
				What size tube bender do you guys recommend.  I am about to bend the
 brake lines and that looks to be 1/4.  How about further down the line
 for bending other lines.
 Rob Hunter
 40432
 Fuselage
		AirMike
				 Posted: Wed Jul 15, 2009 2:55 am    Post subject: Tube Bender |
				You also need the 3/8" bender channel for the fuel lines.
 Also, buy or borrow a GOOD QUALITY 37 degree flare tool.
 There are a lot of crappy products out there.
 Check out the posts on the Bonaco lines for brakes and fuel
  _________________ See you OSH '18
Q/B - sold. |
		johngoodman
				 Posted: Thu Jul 16, 2009 5:09 am    Post subject: Tube Bender |
				AirMike wrote:
  	  | Quote: | 	 		   Also, buy or borrow a GOOD QUALITY 37 degree flare tool.
 ..and if you've never seen the tool used to make a flare, have someone
 demonstrate it.  It was obvious to this builder.
		drfred(at)suddenlinkmail. Guest
				 Posted: Thu Jul 16, 2009 6:10 am    Post subject: Tube Bender |
				Ditto on this post.  I have a friend who replaced the entire fuel line
 system in his L19.  Then he found out about his crappy flare tool and
 got to redo the whole system again.  Couple days down the drain.  A drop
 or two of oil on the tool also helps.  Also, make sure you have filed
 and taken all the burrs off the end of the tube before you flare.  The
 burrs and chinks are the nidus to start a crack in the flare.  I used
 some fine scotch brite to polish the ends before flaring.  Rise out the
 tubing to get rid of any bugs/chips etc before final installation.
 Dr Fred.
 Bill Mauledriver Watson wrote:
  <MauleDriver(at)nc.rr.com>
  ...and if you've never seen the tool used to make a flare, have
  someone demonstrate it.  It was obvious to this builder.
				 Posted: Thu Jul 16, 2009 11:22 am    Post subject: Tube Bender |
				It was NOT obvious to this builder
