		| Author | Message |
		| jeff(at)rmmm.net Guest
		| Back to top |  |
		| topglock(at)cox.net Guest
				|  Posted: Tue Jul 14, 2009 11:10 am    Post subject: Tank Leak Found |   |
				| Jeff,
 If you can't get the Pro Seal to work, my suggestion would be to pull
 the tank.  Once out, you might as well replace it, so the Tap process is
 a non issue.  Don't heat the tank, especially in the A/C.
 When installing the new tank, you might try lining the original glass
 layups (if they still exist) with a thin felt.  That way the tank can
 move, slightly.
 Jeff - baby Blue
 JEFF ROBERTS wrote:
  	  | Quote: |  	  | To All that responded... THANKS! After applying pressure to the tank and using a water soap mixture I
 have located a 2 inch crack in the tank running diagonal from the corner
 of the glass lay-up in the tunnel. Its where the glass is bonded onto
 the tank to hold it in. It looks like a stress crack as the non giving
 glass may have pulled on the tank as it flexed. I'm now in agreement
 with Steve in that these tanks should not be glassed in but rather
 fitted in a way that allows some movement. Okay too late for me now...
 It is however in an area that I can reach it to repair it either using
 pro-seal or the tap plastics product.
 Options:
 1. I used the messy pro seal to seal my sender unit in the top of the
 tank a few years back and it works well. I'm concerned about not being
 able to compress a patch around it or over it though. Maybe once it sets
 up thats not necessary. ???
 2. The video on the Tap plastics Polyweld Greg sent sounds like a better
 way to go as a permanent patch. This one though may require me to cut an
 additional hole behind the access hole and then repair that later.
 BUT... how do I make sure all the fumes are out of the tank after
 draining it so I don't blow myself up
  ( trying to flame treat the to be repaired area on the tank. Maybe continuing to pump air into the tank
 and allow the fumes to eventually evaporate thru the filler cap. Any
 other Ideas to help me avoid burning off any facial hairs are welcome.
 Best regards and thanks to all!!
 Jeff R.
 A258 - N128LJ / Gold Rush 191 hours and down for repairs.
 size  color="#000000" face="courier new,courier">
 href="http://www.matronics.com/Navigator?Europa-List">http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| acrojim7534(at)YAHOO.COM Guest
				|  Posted: Tue Jul 14, 2009 11:24 am    Post subject: Tank Leak Found |   |
				| Jeff
 The patch was a "feel good thing" I did. I was unsure how well the pro seal would work and I felt the need for insurance.
 The tank about three or four years later developed a crack like you have. It had also cracked at the edge of the fiberglass layup in the tunnel. I had to replace the tank and I did NOT glass  it in. Its free standing...
 Once I got the tank out I had a look at the original patch.. It was still sealed tight. I took pliers and tried to pull it off, I got it removed, but it was in torn in several pieces by the pliers.
 Jim Brown
 --- On Tue, 7/14/09, JEFF ROBERTS <jeff(at)rmmm.net> wrote:
  	  | Quote: |  	  | From: JEFF ROBERTS <jeff(at)rmmm.net>
 Subject: Tank Leak Found
 Date: Tuesday, July 14, 2009, 6:14 PM
 After applying pressure to the tank and using a water soap mixture I have located a 2 inch crack in the tank running diagonal from the corner of the glass lay-up in the tunnel. Its where the glass is bonded onto the tank to hold it in. It looks like a stress crack as the non giving glass may have pulled on the tank as it flexed. I'm now in agreement with Steve in that these tanks should not be glassed in but rather fitted in a way that allows some movement. Okay too late for me now... It is however in an area that I can reach it to repair it either using pro-seal or the tap plastics product.
 Options:
 1. I used the messy pro seal to seal my sender unit in the top of the tank a few years back and it works well. I'm concerned about not being able to compress a patch around it or over it though. Maybe once it sets up thats not necessary. ???
 2. The video on the Tap plastics Polyweld Greg  sent sounds like a better way to go as a permanent patch. This one though may require me to cut an additional hole behind the access hole and then repair that later. BUT... how do I make sure all the fumes are out of the tank after draining it so I don't blow myself up
  ( trying to flame treat the to be repaired area on the tank. Maybe continuing to pump air into the tank and allow the fumes to eventually evaporate thru the filler cap. Any other Ideas to help me avoid burning off any facial hairs are welcome.
 Jeff R.
		| Back to top |  |
		| gregoryf.flyboy(at)comcas Guest
				|  Posted: Tue Jul 14, 2009 11:56 am    Post subject: Tank Leak Found |   |
				| I too, have good things about pro-seal being used (non-poly situations). It certainly seems the safer way to go…
 The other route, I would personally run air through the tank, bottom to top, for a minimum of 2 weeks, while the gas and fumes are excised out of the plastic.
 With the fuel issues, time involved, and cutting an access hole, maybe this method is a bit demanding.
 Greg
 _____________________________
 Options:
 <?fontfamily><?param Helvetica>Jeff R.
 <?/fontfamily>
 <?pre><?b><?font size=2 color="#000000" face="courier new,courier">
		| Back to top |  |
		| kjburns(at)btinternet.com Guest
				|  Posted: Tue Jul 14, 2009 12:10 pm    Post subject: Tank Leak Found |   |
				| Purging petrol fumes, I was told by a welder of petrol tanks that he ran a car exhaust in to the tank to purge it of petrol fumes and also air !
The alternative solution would be purge with an inert gas, IE nitrogen,this is done when working on natural gas pipelines.
 Make sure any pockets that could hold inflammable mix is purged,personally I would check the completeness of the purge with a gas detector .. also check adjacent areas for fuel puddles & Fumes
 Kevin
 --- On Tue, 14/7/09, Jim Brown <acrojim7534(at)YAHOO.COM> wrote:
  	  | Quote: |  	  | From: Jim Brown <acrojim7534(at)YAHOO.COM> Subject: Re: Tank Leak Found
 Date: Tuesday, 14 July, 2009, 8:21 PM
 Jeff
 need for insurance.
 Jim Brown
 Options:
 necessary. ???
 Jeff R.
 repairs.
		| Back to top |  |
				|  Posted: Tue Jul 14, 2009 1:46 pm    Post subject: Tank Leak Found |   |
				| I believe I'm going to pro seal the crack and use the patch idea. Maybe
before I replace the tank in the future the new Europa will come up
 with an alternitive plan for doing this or a new tank. Maybe they
 should consider a metal option.
 Thanks again guys. Hoe to see you all at Rough River!!
 Jeff R.
 On Jul 14, 2009, at 2:08 PM, Jeff B wrote:
  	  | Quote: |  	  |
 Jeff,
 is a non issue.  Don't heat the tank, especially in the A/C.
 move, slightly.
 Jeff - baby Blue
 > Options:
  ( trying to flame treat > the to be repaired area on the tank. Maybe continuing to pump air
 > hairs are welcome.
 > Jeff R.
 > href="http://www.matronics.com/contribution">http://
		| Back to top |  |
		| fklein(at)orcasonline.com Guest
				|  Posted: Tue Jul 14, 2009 2:43 pm    Post subject: Tank Leak Found |   |
				| On Jul 14, 2009, at 2:43 PM, JEFF ROBERTS wrote:
  	  | Quote: |  	  | I believe I'm going to pro seal the crack and use the patch idea. Maybe before I replace the tank in the future the new Europa will
 come up with an alternitive plan for doing this or a new tank.
 Best of luck to you Jeff...
 This thread prompts me to review my build log photos, and I'm noticing
 that I extended Layup #2 all the way to the bottom corners of the tank
 in hopes of preventing a stress concentration where the #2 layup ends
 as shown in Fig. 5 of chapter 16 in the manual. I thank Ron Pagoris
 for that tip, and I also plan to add the foam and bond-break sheet
 between the bottom of the tank and fuselage in order that the tank
 have uniform support across its bottom
 At this point of course, I regret having bonded all the FG support
 tapes directly to the tank and not allowing the tank to "float" on the
 support tapes, but I'm hoping that I'll be able to dodge the bullet
 which has caught Jeff and others. What I truly regret is hearing that
 little voice which questioned the notion of rigidly bonding in the
 tank...promptly ignoring it...and essentially going by the book.
 Fred
 A194
 believed to be clean.
		| Back to top |  |
				|  Posted: Tue Jul 14, 2009 3:43 pm    Post subject: Tank Leak Found |   |
				| Jim, and all,
I'm going to use the pro seal approach and keep an eye on it. I would
 like to use the patch but have no material. Question... Since it is a
 patch why not just use a local piece of fuel can material. I thought
 Id' follow your advice and and rough it up with 80 grit on both the
 patch and the tank plus clean them with acetone before application.
 Sound okay to you all?
 Jeff R.
 On Jul 14, 2009, at 2:21 PM, Jim Brown wrote:
  	  | Quote: |  	  | Jeff
 standing...
 Jim Brown
 > To: europa-list(at)matronics.com
 > Options:
 > hairs are welcome.
 > Jeff R.
		| Back to top |  |
		| paul.the.aviator(at)gmail Guest
				|  Posted: Tue Jul 14, 2009 7:05 pm    Post subject: Tank Leak Found |   |
				| Hi Jeff,
 I don't know if this is a dumb idea or not, but I was wondering is it is practical to seal up the tank, put Proseal on the leak and then connect a vacuum pump to the tank to suck the sealant into the crack.
 Proseal is awfully messy stuff, but is it has a good track record for blocking up leaks in petrol tanks/
 Paul
		| Back to top |  |
				|  Posted: Wed Jul 15, 2009 6:11 am    Post subject: Tank Leak Found |   |
				| Paul,
Sounds like a good Idea. John Lawton gave me the Idea to drill the ends
 of the crack to stop it and maybe the vac could pull a little in the
 ends of the crack... Couldn't hurt I guess. It's a very thin crack so
 I'm not sure if the vac could pull the thick goo into the crack itself.
 Jeff R.
 On Jul 14, 2009, at 10:01 PM, Paul McAllister wrote:
  	  | Quote: |  	  | Hi Jeff,
 Paul
		| Back to top |  |
		| rampil
				|  Posted: Wed Jul 15, 2009 6:45 am    Post subject: Re: Tank Leak Found |   |
				| Hi All!
 I don't think you will get much traction by sucking down the tank to pull
 proseal through a crack - it is fairly viscous stuff.  I would just scuff sand
 the  area around the crack and lay it on thick.
 Ira
 Ira N224XS
		| Back to top |  |
				|  Posted: Wed Jul 15, 2009 10:36 am    Post subject: Tank Leak Found |   |
				| Jeff, use a patch of some sort, even if it's just milk carton material.
Encase it in Pro Seal.
 Jeff - Baby Blue
 JEFF ROBERTS wrote:
  	  | Quote: |  	  |
 Jim, and all,
 patch why not just use a local piece of fuel can material. I thought Id'
 follow your advice and and rough it up with 80 grit on both the patch
 and the tank plus clean them with acetone before application. Sound okay
 to you all?
 Jeff R.
 > Jeff
 > standing...
 > Jim Brown
 >> Options:
  ( trying to flame treat >> the to be repaired area on the tank. Maybe continuing to pump air
 >> hairs are welcome.
 >> Jeff R.
 Checked by AVG - www.avg.com
		| Back to top |  |
				|  Posted: Wed Jul 15, 2009 12:05 pm    Post subject: Tank Leak Found |   |
				| Roger that... Just waiting for my ACS order of the expensive goo!!
Probably won't get here till Friday. I also had my Whelen power supply
 go down to, and a few other things to change while the bird is in the
 nest. So I'll keep busy while I'm waiting.  Id rather be flying ;o(
 Jeff R.
 On Jul 15, 2009, at 1:32 PM, Jeff B wrote:
  	  | Quote: |  	  |
 material.  Encase it in Pro Seal.
 Jeff - Baby Blue
 JEFF ROBERTS wrote:
 > Jim, and all,
 > Thanks,
 > Jeff R.
 >> Jeff
 >> free standing...
 >>  Jim Brown
 >>> product.
 >>> Options:
  ( trying to >>> flame treat the to be repaired area on the tank. Maybe continuing
 >>> Jeff R.
		| Back to top |  |
		| rparigor(at)suffolk.lib.n Guest
				|  Posted: Wed Jul 15, 2009 12:20 pm    Post subject: Tank Leak Found |   |
				| Hi Jeff
 Good luck on your repair.
 May I suggest a few things:
 **Get hold of an "old" tank and try a practice repair. Motorcycle or snowmobile or old gas can
 **I know that Lyc case repairs are done pulling a vacuum with thick windshield polyurethane that actual gets sucked in, try it on your practice piece
 **For hahas, try a practice repair with Proseal and also one with Redux
 **Don't know if you could get to tunnel, but if you can reinforcing with BID like I did, would probably layup 1 BID with Redux/peelply, then 2 BID with Aeropoxy/BID after cure. This would be to prevent further cracking. I would drive in some wedges to raise front of tank before glassing
 **With wedges driven to lift tank in front, I would use low expansion foam and fill between fuse and tank to help support tank instead of having a 18 gallon cantelever on aft BID supports
 **I like the idea of using a patch with Proseal that is somewhat flexible, this way if crack moves a little, it will not point load bond. McMaster sells plenty of rubber. I purchased some fuel pump diaphragm repair rubber with cloth reinforcement I used for fuel sensor gasket I kinda like, perhaps get hold of a piece and try it on your test sample
 See album for some pics:
 http://www.europaowners.org/modules.php?set_albumName=album233&op=modload&name=gallery&file=index&include=view_album.php
 Ron Parigoris
 from [Neville Eyre]	[Permanent Link]
 Subject: 	Re: Fuel Tank Cleaning before Soldering Iron
 Date: 	Fri, 14 Mar 2003 09:11:04
 Hi All,
 After ALL the fuel has been drained, purge the fumes out with Carbon Dioxide,
 either
 from a MIG welding plant, or from a brewery bottle. A bottle can be hired
 from most drink supply depots for not a lot of money.
 Leave the gas running until all smell of fuel has gone, and let a little trickle
 all the while you are working on the tank.
 Ensure the tip of the iron is clean.
 Nev.
 Tony Renshaw <tonyrenshaw> 03/11/03 11:52am >>>
 Gidday,
 I am wondering after reading Paul McAllisters website about the
 recommendations for preping the fuel tank before I attack it with my
 soldering iron to install the Europa fuel probe (magnetic). The question is
 that I was only going to drain it of fuel and wash it out with water, but I
 now fear that I need to do more than that. Does the plastic absorb some of
 the fuel that would make things dangerous for me if I keep to my original
 plan?
 Reg
 Tony Renshaw
 And if you must "gut"her:
 A)  Curious question, if you needed to replace tank in XS, how would you  do
 it?        Remove upholstery, cut up  seatback from the kink,cut across the
 front at the kink, over the top,  and down the baggage bay,and across just
 above the tunnel,lift top  off. Spread in front and behind the top with auto
 scissor jacks / lumber  to open the fuselage out, do this with heat on it and over
 a full day, [  softly, softly ] and the tank will come out. I have done this a
 few   times, only once did I have to saw the tank up as it had swollen [
 After the  first 50 or so tanks suplied, they don't swell now ] To repair the
 joint of  the cut off top, you need to cut away the outer skin, dig out the foam,
 5 min'  back in place, do a 2 Bid lay up onto the outer face of the INNER
 skin, micro  some foam onto the wet lay up, allow to cure. Sand the foam to flush
 and do a  two Bid lay up over the foam onto the outer skin. Usual scuffing
 practises  apply.
 B) If a leak developed in tank, could it be repaired in  place?
 Kingsley  summed it up about right, I have done this 3 times [ all to tanks that
 had  been drilled by the owners ! ] I prefer to use tank sealing ''goo '', use
 the 2 hour one, the 1/2 hour sets too fast. On small holes, I have used
 AN525 screws and AN970-3 washers with the goo  on.
 Visit -  www.EuropaOwners.org
		| Back to top |  |
