aslsa.rng(at)gmail.com Guest
Posted: Mon Jul 20, 2009 6:09 pm Post subject: Changing HKS Throttle from pull open to pull closed |
Frank, Called the Bing Agency this afternoon and Charlie, the owner, was out. He'll be back on Wednesday and I'll try again. The light bulb went off this evening and I thought of the 912 / 914 Illustrated Parts Catalog. Sure enough in section 22, Bing Carb, I found all the parts. If you don't have a copy it can be had from R.O.A.N. Rather long download. You'll also want a copy of the 912 Installation Manual. On page 96 it shows how the various parts work together and giving instructions for proper set up.
IPC # Rotax Part # Side # RQD Description
45 963025 cyl 1 1 Throttle valve lever
45 963020 cyl 2 1 " " "
46 241847 2 Allen Screw M5 X 12
47 847740 2 Graduated Sleeve
48 827800 2 Washer A 5.5
49 842030 4 Lock Nut M5
50 938289 2 Return Spring
56 851071 cyl 1 1 Support
56 851073 cyl 2 1 "
58 241440 2 Adjustment Screw M6 X .75
59 942541 4 Hex Nut M6 X .75 height 3mm
NOTE: The return spring may be the same on both engines, I have no way of telling
Well, that should be all the parts required to change over from a pull open throttle to a pulled closed one.
Rick Girard
I decided to send this again as for the archives so the subject would reflect the content
