pilotdds(at)aol.com Guest
Posted: Wed Jul 22, 2009 4:14 pm Post subject: Aux fuel tanks |
I added a removable 20 gal aux tank in the baggage bay.I tested it but have not found the extra fuel necesary.
dlm46007(at)cox.net Guest
Posted: Wed Jul 22, 2009 5:10 pm Post subject: Aux fuel tanks |
I was not suggesting that the 10 routinely be operated above the Van's
suggested gross of 2700. It is certainly possible to operate the aircraft
with considerable additional fuel on board, subject to CG, weight and
structural considerations. I have set the gross for my 10 at 2800 pounds;
primarily because I never want , in case of incident, to argue with FAA or
insurance company, about being over gross. Having on several occasions
landed a Cessna in IMC carrying a load of ice, I know it is possible to
encounter conditions with payloads which are not workable. My point is that
with proper planning and good judgment there are many options in the safe
use of these aircraft. If one plans ahead, the versatility can be
dramatically improved without significant penalty
wayne.e(at)grandecom.net Guest
Posted: Thu Jul 23, 2009 4:51 am Post subject: Aux fuel tanks |
I wasn't aware that there were two 10's with gear collapse. I know about the recent on, which sounds like he stalled it high and pan caked in hard. What happened on the other one?
Wayne Edgerton N602WT
Time: 02:39:41 PM PST US From: "Chris and Susie" <vhicy(at)bigpond.com (vhicy(at)bigpond.com)> Subject: Re: Aux fuel tanks
Dick we have just come back from a 42 hour trip in outback Australia.
Most of the time we were fine with fuel but as another has pointed out
fuel in some areas can be extremely expensive. An extra hour range would
be great here. The option of filling further on would be great.
I have spoken to an engineer at Vans regarding making the the outer bay
of wing also fuel and his response was like other RV's it actually
strengthens the wing however other areas have to be considered like Max
weight. He would not put anything on paper.
An extra hour would be good but I don't know about an extra 60 gallons
unless you few at gross weight or under but you know what people would
do!
With two 10's with gear leg collapses We do not want to fly over gross.
So Yes I would add an extra 1 hour of fuel if I were to build again for
out back flying.
Chris
hotwheels
Posted: Thu Jul 23, 2009 12:08 pm Post subject: Re: Aux fuel tanks |
Last year at OSH there was at least one -10 with outboard aux tanks. It made me ponder... The danger isn't not knowing for sure what you're doing. The real peril is not knowing what you don't know.
If one hasn't done a proper engineering load analysis then making substantial airframe changes puts the capital "E" in Experimental... Not an aeronautical or mechanical engineer? Then you could end up as the next NTSB poster child slash Internet whipping boy.
Please don't add to the body count or to higher insurance premiums for the rest of us.
My 2 cents worth...
Jay
ncol(at)xtra.co.nz Guest
Posted: Thu Jul 23, 2009 1:24 pm Post subject: Aux fuel tanks |
We talked at length with Vans on this issue. From memory, the wing has
been designed to have some flex in it, outboard of the main tanks.
While you can replace the leading edge further outboard with another
tank, it stops that part of the wing from flexing. This then gives
rise to a hinge point between the two tanks and creates point loads /
stresses that the spar was not designed for at a center point in the
wing. That's not to say it can't be done, but they do not advise it.
Short term and low turbulence it would probably be ok. Long term.......
It is not often that you need to carry 4 people & a whole pile of
extra fuel. Vans recommendation to me was tip tanks & a ferry tank.
The plane is designed for those loads. You can put a Turtlepac 66 Gal
ferry tank, sitting as close to the front seats as possible. It leaves
little room for baggage, but it gives you 60+66 gal = 126 gal (at) 8.5
gph LOP = nearly 15 hours. How big is your bladder??
The other thing to remember is that for most of your flying you will
probably be carrying around the extra weight for no gain. A removable
ferry tank is probably the best way to go.
Neil
rngurley
Joined: 21 Jan 2008 Posts: 18 Location: Indianapolis, IN
Posted: Thu Jul 23, 2009 1:33 pm Post subject: Aux fuel tanks |
To all -
Thank you for the input. I think that his summarizes the wing tank idea but
I will look at a removable tank in the baggage area.
Thank you again
Dick Gurley
Kelly McMullen
Posted: Thu Jul 23, 2009 2:12 pm Post subject: Aux fuel tanks |
If the reported tip tanks are 7.5 gal per side, that is 45 lbs per
side. If always consumed first, in low turbulence, low G flying,
perhaps not an issue. There are a number of planes that have STCs to
add tip tanks to certified planes. Who knows what the FAA demanded for
those, but I doubt they did spar beef up. Bonanza, C210, C185 all come
to mind.
On Thu, Jul 23, 2009 at 1:08 PM, jayb<jaybrinkmeyer(at)yahoo.com> wrote:
My 2 cents worth...
Jay
http://forums.matronics.com/viewtopic.php?p 54507#254507
A&P/IA, EAA Tech Counselor
KCHD |
partner14
Posted: Thu Jul 23, 2009 2:38 pm Post subject: Aux fuel tanks |
No sense in reinventing the wheel, so has anyone,,,, using the KISS principal,,, come up with the best connection method for a baggage area aux tank? Venting? Transfer/check valve?
I haven't even made any trips longer than 200 miles yet, but it seems it would be nice to know you had another 5-10 gallons somewhere.... oh, like a reserve!
We flew over toward the CA coast on July 4th. First stop for fuel, Colusa,tank empty, 2nd stop, Ukia, 2 fuel trucks, but no operators.... yes, I did get a little nervous.
Don McDonald
--- On Thu, 7/23/09, Richard Gurley <rngurley(at)att.net> wrote:
Subject: RE: Re: Aux fuel tanks
Date: Thursday, July 23, 2009, 2:27 PM
--> RV10-List message posted by: "Richard Gurley" <rngurley(at)att.net (rngurley(at)att.net)>
To all -
Thank you again
Dick Gurley
40636 |
Posted: Thu Jul 23, 2009 3:52 pm Post subject: Aux fuel tanks |
I don't believe that the bending moment on the spar is increased by tip
tanks. If anything it is lessened. In some Ceesnas, the tips are the mains
dmaib@me.com
Joined: 25 Apr 2006 Posts: 455 Location: New Smyrna Beach, Florida
Posted: Thu Jul 23, 2009 5:15 pm Post subject: Aux fuel tanks |
I think David is correct. In the Bonanza, the maximum gross weight is
actually increased by the addition of tip tanks. No spar mods, that I
know of with the Bonanza tip tanks.
David Maib
40559
mains
_________________ David Maib
RV-10 #40559
New Smyrna Beach, FL |
Posted: Thu Jul 23, 2009 7:51 pm Post subject: Aux fuel tanks |
We have used a bladder tank in the baggage compartment before. We used the 3rd port on the Van's fuel valve and ran a line to the baggage area. No venting is needed with the bladder. It would be fairly easy to plumb a rigid line inside the tunnel, then a bulkhead fitting just behind the rear seat, in the front corner of the baggage area or possibly in the tunnel cover in the baggage area, then it can be capped when not in use or plumbed into the bladder with a flex line when in use. I think our bladder was 20 gallons, which should be right at the weight allowed in the baggage area.
Jesse Saint
Saint Aviation, Inc.
Cell: 352-427-0285
Fax: 815-377-3694
On Jul 23, 2009, at 5:29 PM, Don McDonald wrote:
[quote]No sense in reinventing the wheel, so has anyone,,,, using the KISS principal,,, come up with the best connection method for a baggage area aux tank? Venting? Transfer/check valve?
Don McDonald
--- On Thu, 7/23/09, Richard Gurley <rngurley(at)att.net (rngurley(at)att.net)> wrote:
From: Richard Gurley <rngurley(at)att.net (rngurley(at)att.net)>
To all -
Thank you again
Dick Gurley
Posted: Thu Jul 23, 2009 8:09 pm Post subject: Aux fuel tanks |
cost and source of the bladder?
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Jesse Saint
Sent: Thursday, July 23, 2009 8:46 PM
Subject: Re: Re: Aux fuel tanks
Jesse Saint
Cell: 352-427-0285
Fax: 815-377-3694
[quote] No sense in reinventing the wheel, so has anyone,,,, using the KISS principal,,, come up with the best connection method for a baggage area aux tank? Venting? Transfer/check valve?
Don McDonald
To all -
Thank you again
Dick Gurley
fritzsch(at)eskimo.com Guest
Posted: Thu Jul 23, 2009 9:45 pm Post subject: Aux Fuel Tanks |
If my memory is correct, some of the early aircraft were found to be
flaming coffins in a crash due to fuel tanks located right behind the
pilot rupturing. I would be very concerned about putting a fuel tank in
the baggage compartment for that reason. In a crash you could suddenly
find yourself in a gasoline shower with the slightest spark turning the
cockpit into an inferno.
Dave
Dave Fritzsche
40813
Puyallup, WA
wcurtis(at)nerv10.com Guest
Posted: Fri Jul 24, 2009 4:33 am Post subject: Aux Fuel Tanks |
This opinion, and memory, relies heavily on truthiness. The fact is that any impact sufficient to rupture an in cabin tank is most likely not survivable by the occupants due to blunt force trauma. Secondly, impact sufficient to rupture a cabin tank will also have caused more damage to the wing tanks which is only a few inches from the cabin. Lastly there are many current certified aircraft (as well as the RV-12) that have fuselage fuel tanks or STCs for fuselage fuel tanks. There is an STC for a permanent baggage area fuel tank for the Cardinal RG that I currently fly. Most commercial airlines have wing center tanks under the cabin.
In a past RVAtor article, Van's (Ken Krueger) has stated if builders must add additional tanks, they would prefer fuselage based tanks, rather than additional wing tanks. Your concern regarding a "gasoline shower" is only valid if you are worried about having an "excellent kadabra."
William Curtis
40237
http://wcurtis.nerv10.com/
On Fri, Jul 24, 2009 at 1:27 AM, Dave Fritzsche (Building) <fritzsch(at)eskimo.com (fritzsch(at)eskimo.com)> wrote:
[quote]--> RV10-List message posted by: "Dave Fritzsche (Building)" <fritzsch(at)eskimo.com (fritzsch(at)eskimo.com)>
If my memory is correct, some of the early aircraft were found to be flaming coffins in a crash due to fuel tanks located right behind the pilot rupturing. I would be very concerned about putting a fuel tank in the baggage compartment for that reason. In a crash you could suddenly find yourself in a gasoline shower with the slightest spark turning the cockpit into an inferno.
Dave
Dave Fritzsche
40813
Puyallup, WA
AV8ORJWC
Posted: Fri Jul 24, 2009 8:15 am Post subject: Aux Fuel Tanks |
The RV-12 has just received FAA certification as a Light Sport and
complete kits are now being readied for shipment to those who have
passion for such things. Just a note before shifting entirely into
RV-10 issues for OSH.
John
AV8ORJWC
Posted: Fri Jul 24, 2009 8:26 am Post subject: Aux fuel tanks |
Stalled high, pancaked hard in California.
CBS did a small piece on Lancair International (KOIN-PDX and yes, I recorded it) as they roll out the Evolution which did a tail contact landing attempt with gear inadvertently UP two weeks ago. The byline was titled "Unsafe at any speed" and unfortunately took the kit builder's positive effort at a pre OSH promotional and turned it towards the more than 100 fatalities in make that have been documented. Proficiency Training is not an will never be Transition Training. That said, I read that Bill's LSI, RV-10 had a mid flight propulsion problem and executed a near perfect landing ON FIELD with no airspeed left. As some so humorously pointed out on the 2 -FAT which was actually a reference to the two POB "onboard", I think they should be commended for their airmanship.
Airspeed maintenance until contact with terra firma can result in CFIT or at the least memorialized FAA embarrassment. Let's all make compliant landings to and from OSH this next week.
John
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Wayne Edgerton
Sent: Thursday, July 23, 2009 5:50 AM
Time:
02:39:41 PM PST US
Subject:
Re: Aux fuel tanks
do!
[b] So Yes I would add an extra 1 hour of fuel if I were to build again for
out back flying.
[/b]
Chris
[quote] [/b][/b][/b][/b][b]http://www.matronics.com/Navigator?RV10-List[b][/b][b]http://forums.matronics.com[b][/b]http://www.matronics.com/contribution [b]
