sidsel.svein(at)oslo.onli Guest
Posted: Sat Jul 25, 2009 1:17 am Post subject: NPT threads |
Should I use any kind of sealing on NPT threads in the fuel system (e.g. Locktite) or do these threads seal just by using the recommended torque?
Svein
LN-SKJ
paul.the.aviator(at)gmail Guest
Posted: Sat Jul 25, 2009 5:43 am Post subject: NPT threads |
Hi Svein
I would recommend that you use liquid teflon pipe sealant against the tape. The tape has the risk of small pieces of it splitting off and getting into your fuel system.
Regards, Paul
Rowland_Carson
Joined: 04 Jul 2008 Posts: 155 Location: Cheltenham, England
Posted: Sat Jul 25, 2009 6:45 am Post subject: NPT threads |
At 2009-07-25 11:16 +0200 Sidsel & Svein Johnsen wrote:
| Quote: | Should I use any kind of sealing on NPT threads in the fuel system
recommended torque?
Svein - I've been using Loctite 577 (originally recommended to me by
Graham Singleton) but have yet to test its effectiveness as my fuel
system is still dry. I would NOT use any tape sealant as it's
impossible to ensure that small pieces are not set adrift inside the
fuel system - to lead to a bad day sometime later.
Incidentally what are the recommended torques for 1/8" & 1/4" NPT,
and where did you find a reference to them?
regards
Rowland
| Rowland Carson LAA #16532 http://home.clara.net/rowil/aviation/
| 1280 hours building Europa #435 G-ROWI e-mail <rowil(at)clara.net>
Posted: Sat Jul 25, 2009 11:56 pm Post subject: NPT threads |
Many thanks for all replies. Seems that at fluid sealant will be the way to
go.
I only have max. allowed torque for the flow sensor into which the 1/4" NPT
AN fitting will go (25 ft.lbs.), not the recommended torque for the AN
fitting itself. Apologize for expressing myself differently.
Svein
| Quote: | Incidentally what are the recommended torques for 1/8" & 1/4" NPT,
johnwigney(at)windstream. Guest
Posted: Sun Jul 26, 2009 11:55 am Post subject: NPT threads |
Hi Svein,
For any threaded fuel joints I recommend that you use Hylomar sealant which is a non-hardening product developed by Rolls Royce many years ago. It is used widely in many high performance applications. You can find information and suppliers with a Google search for "Hylomar" or "Permatex Hylomar". You need the 'Universal Blue' product. For clean up, you can use methylene chloride.
I do not recommend that you use Teflon tape. This product is forbidden in the petro-chemical industry after catastrophic plant failures have been traced back to small pieces of tape which have blocked critical control instrumentation orifices.
Cheers, John
N262WF, mono XS, 912S
Mooresville, North Carolina
ORIGINAL MESSAGE
[quote]From: "Sidsel & Svein Johnsen" <sidsel.svein(at)oslo.online.no>
Subject: NPT threads
Should I use any kind of sealing on NPT threads in the fuel system (e.g.Locktite) or do these threads seal just by using the recommended torque? Regards, Svein LN-SKJ[b]
