				|  | Matronics Email Lists Web Forum Interface to the Matronics Email Lists
		| Author | Message |
		| uvtreith(at)t-online.de Guest
				|  Posted: Sat Jul 25, 2009 2:09 am    Post subject: AW: NPT threads |   |
				| Svein,
 You have to use a Teflon sealing.
 Normally for instrumentation (industry) we are using Teflon tape, but there is also a Teflon sealing fluid (pasta) on the market.
 Maybe that this is better for “tank” connectors to avoid getting parts of the Teflon tape into the fuel system
 Best Regards,
 Bruno
 Von: owner-europa-list-server(at)matronics.com [mailto:owner-europa-list-server(at)matronics.com] Im Auftrag von Sidsel & Svein Johnsen
 Gesendet: Samstag, 25. Juli 2009 11:16
 An: europa-list(at)matronics.com
 Betreff: NPT threads
 Should I use any kind of sealing on NPT threads in the fuel system (e.g. Locktite) or do these threads seal just by using the recommended torque?
 Svein
 LN-SKJ
 0123456789 	  | Quote: |  	  | [b]http://www.matronics.com/Navigator?Europa-List[b] |
 | |  |  | - The Matronics Europa-List Email Forum - |  |  |  | Use the List Feature Navigator to browse the many List utilities available such as the Email Subscriptions page, Archive Search & Download, 7-Day Browse, Chat, FAQ, Photoshare, and much more:http://www.matronics.com/Navigator?Europa-List
		| Back to top |  |
		| rampil
				|  Posted: Sun Jul 26, 2009 5:05 am    Post subject: Re: AW: NPT threads |   |
				| Hi Svein,
 Never use teflon tape in the Fuel system.
 The reason is that tape shreds and those shreds can get into the
 fuel stream and clog your carb, especially if the particular fitting
 is downstream from filters.
 Use instead PTFE Pipe compound as suggested. it is a paste
 available at places like Home Depot or plumbing shops.
 Good Luck,
 Ira
 Ira N224XS
		| Back to top |  |
 | You cannot post new topics in this forum You cannot reply to topics in this forum
