toaster73(at)embarqmail.c Guest
Posted: Sat Aug 01, 2009 7:17 am Post subject: GRT AHRS Mounting and CG |
Anyone have a feeling about how far it is acceptable to mount the AHRS from the CG? When does the “lever affect” really kick-in?
I would like to put it on a shelf like others have done - one bay behind the battery bay, with the magnetometers there too. What do those in the know think?
Thank You
Chris Lucas
#40072
rngurley
Joined: 21 Jan 2008 Posts: 18 Location: Indianapolis, IN
Posted: Sat Aug 01, 2009 1:17 pm Post subject: GRT AHRS Mounting and CG |
I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers.
Dick Gurley
bcondrey
Posted: Sat Aug 01, 2009 2:13 pm Post subject: GRT AHRS Mounting and CG |
Won't be a problem.
Bob
From: owner-rv10-list-server(at)matronics.com <owner-rv10-list-server(at)matronics.com>
To: rv10-list(at)matronics.com <rv10-list(at)matronics.com>
Sent: Sat Aug 01 07:52:50 2009
Subject: RV10-List: GRT AHRS Mounting and CG
Thank You
Chris Lucas
#40072
johngoodman
Posted: Sat Aug 01, 2009 2:25 pm Post subject: Re: GRT AHRS Mounting and CG |
| rngurley wrote: | I talked with the GRT folks about this at Oshkosh this week. They recommend putting the AHRS back by the battery (Vans makes a shelf) and the magnetometers out on the wingtips. They indicated that having both on the same shelf might cause too much electrical noise for the magnetometers.
Dick Gurley
Darn! When I asked them the same question at Sun 'n fun they didn't blink an eye when I said I would mount both on a tray behind the battery bay. If you look at their installation documentation for both, they have to be within 0.5 degrees of each other in all orientations. Talk about CYA. I'm calling on Monday!
John
_________________ #40572 Phase One complete in 2011 |
bcondrey
Posted: Sat Aug 01, 2009 3:20 pm Post subject: GRT AHRS Mounting and CG |
I mounted the magnetometers up high in the bay with the batteries and have no issue - been flying over a year. YMMV.
Bob
Posted: Sat Aug 01, 2009 6:09 pm Post subject: GRT AHRS Mounting and CG |
Dick,
SO your saying they told you the AHRS itself could interfere with the magnetometer performance? That seems odd. I wouldn’t think much is going on electrically in the AHRS plus it had that thick Al housing. Let us know what they say John Goodman if you get a call in to GRT on Monday. I’ll call Tuesday to see if we get a third answer!!
I think I am going to press forward based on the input from folks already in operation (I kinda just finished the mounting this evening anyway).
When it comes time, I’ll give it all a thorough check out and move things later if I have to. It is very convenient to have it all on the shelf instead of having to run more wires out the wing etc.
Thanks for the inputs.
-Chris
#40072
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Richard Gurley
Sent: Saturday, August 01, 2009 4:55 PM
Subject: RE: GRT AHRS Mounting and CG
Dick Gurley
Ron.McGann(at)thalesgroup Guest
Posted: Sun Aug 02, 2009 2:40 pm Post subject: GRT AHRS Mounting and CG |
I would support this.
My AHRS and magnetometer are located in the 'standard' position on a
tray above and aft of the battery. I thought it was magnetically
benign, but about 10 mins into every flight my displays suffer the
'leans' by about 5degs. Still trying to get to the bottom of the issue.
GRT seem to be fairly sure that there is some magnetic interference
there. I will be moving the magnetometer to the wingtip shortly.
I reckon magnetometer installation is a chook raffle (crapshoot to you
guys up north). AHRS on the tray and magnetomoeters in the wingtip
should be standard IMHO.
Cheers,
Ron
VH-XRM
Flying in oz
bcondrey
Posted: Mon Aug 03, 2009 8:24 am Post subject: Re: GRT AHRS Mounting and CG |
The AHRS can be mounted on the standard tray next to the battery however the magnetometer must be at least 24" (IIRC) from the contactors and AP servo both of which are strong sources of magnetic energy. I found that a shelf about 3" below the top of the tailcone, attached to the J channel stringers works great. I did look into mounting a shelf across the longerons but my testing with a simple compass in that location showed large variations as things were switched on/off and the AP servo exercised. Just a few inches higher made a huge difference.
Wingtips would also be an excellent location.
Bob
johngoodman
Posted: Mon Aug 03, 2009 10:05 am Post subject: Re: GRT AHRS Mounting and CG |
| Quote: | | SO your saying they told you the AHRS itself could interfere with the magnetometer performance? That seems odd. I wouldn’t think much is going on electrically in the AHRS plus it had that thick Al housing. Let us know what they say John Goodman if you get a call in to GRT on Monday. I’ll call Tuesday to see if we get a third answer!! |
I called, but only a few are back from Oshkosh. Left a message for a call back.
John
johngoodman
Posted: Mon Aug 03, 2009 10:30 am Post subject: Re: GRT AHRS Mounting and CG |
OK,
I got a call back from Jeff at GRT. It is true that the AHRS interferes with the magnometer. The stock answer is that the magnometer can be no closer than 18" to a magnetic source. He's not sure what the exact distance for the AHRS is, but it contains stuff that will interfere. They recommend a wing tip as first choice, otherwise a separate mount in the tail far away from everything. Back to the drawing board....
John
Posted: Mon Aug 03, 2009 11:08 am Post subject: GRT AHRS Mounting and CG |
I'm exactly 18" from closest edge of AHRS to closest edge of
Magnetometer. I tried to maximize the distance from the pitch AP servo
and the Strobe flash unit.
I recall some previous posts on be careful with the AHRS around the
pitch trim unit in the rear of the tail cone. It's further forward than
you think and I recall it being difficult to setup the 18" clearance.
Let's hear some more flying experiences with the GRTs.
Bill "Firewall Forward" Watson
johngoodman wrote:
OK,
John
#40572 QB Fuselage, wings finished. Finish Kit progressing. Engine & Panel delivery soon.
N711JG reserved
http://forums.matronics.com/viewtopic.php?p 55821#255821
Posted: Mon Aug 03, 2009 6:38 pm Post subject: GRT AHRS Mounting and CG |
Ok, I'll rethink too then.
Chris
#40072
billderou(at)yahoo.com Guest
Posted: Tue Aug 04, 2009 9:42 am Post subject: GRT AHRS Mounting and CG |
Guys-
I have not been following this thread so my comments may have already been covered.
The best place to locate a magnometer (and/or the AHRS if they do not interfer with one another) is on a shelf that spans the fuselage laterally between the three longeron bolts that secure the aft seat belt attachment. This location has four good advantages:
I have measured the magnetic interference and this location is the farthest distance from the autopilot elevator servo and the elevator trim servo. Do not underestimate the interference from the little trim servo - it is more of a problem than the autopilot.
A shelf in this orientation is automatically aligned with the pitch and roll axis.
If the sensor contains accelerometers or rate gyros it will function more accurately along the centerline of the fuselage than a wing tip.
This location is far from the baggage compartment and the unpredictable magnetic forces contained in the unpredictable baggage.
Also - you will never get a sensor accurately aligned in a wing tip. I just had a good example of how the wing will move about between ground and air.
Bill DeRouchey
N939SB
--- On Mon, 8/3/09, Chris <toaster73(at)embarqmail.com> wrote:
Subject: RE: Re: GRT AHRS Mounting and CG
Date: Monday, August 3, 2009, 7:36 PM
--> RV10-List message posted by: "Chris" <toaster73(at)embarqmail.com (toaster73(at)embarqmail.com)>
Chris
#40072
Posted: Tue Aug 04, 2009 6:43 pm Post subject: GRT AHRS Mounting and CG |
Good points Bill. I decided to make the shelf for the magnetometers just ahead of the seat belt attach. I am putting another shelf forward of that slightly aft of the battery to hold the AHRS. Both units will be completely aligned though separated based on GRT’s inputs that the AHRS can cause some disturbance in the magnetometer.
-Chris Lucas
#40072
From: owner-rv10-list-server(at)matronics.com [mailto:owner-rv10-list-server(at)matronics.com] On Behalf Of Bill DeRouchey
Sent: Tuesday, August 04, 2009 1:40 PM
Guys-
Bill DeRouchey
N939SB
--> RV10-List message posted by: "Chris" <toaster73(at)embarqmail.com>
Chris
#40072
Posted: Wed Aug 05, 2009 4:52 am Post subject: GRT AHRS Mounting and CG |
I'm sticking with my already completed installation.
I built a shelf across the longerons just aft of the bay containing the
AP servo. The magnetometers are mounted on the left side to maximize the
distance from the servo and the strobe power unit mounted on the right wall.
I purchased Van's AHRS shelf which mounts on the floor next to the AP
servo. The GRT AHRS holes are pre-drilled and the shelf appears to be
properly aligned.
This puts the Magnetometers and AHRS exactly 18" apart. The
Magnetometers are 23" from the AP servo and 24+ from the stobe power unit.
I hope it all works well.
Chris wrote:
-Chris Lucas
#40072
[mailto:owner-rv10-list-server(at)matronics.com] *On Behalf Of *Bill
DeRouchey
*Sent:* Tuesday, August 04, 2009 1:40 PM
*To:* rv10-list(at)matronics.com
*Subject:* RE: Re: GRT AHRS Mounting and CG
Guys-
been covered.
and roll axis.
and air.
Bill DeRouchey
N939SB
johngoodman
Posted: Wed Aug 05, 2009 5:13 am Post subject: Re: GRT AHRS Mounting and CG |
| Quote: | I'm sticking with my already completed installation.
properly aligned.
I hope it all works well. |
The Van's AHRS shelf sounds like a possibility. Van's drawing shows it on the left side, can it be mounted on the right? I've already got the A/P servo on that side.
John
Posted: Wed Aug 05, 2009 11:11 am Post subject: GRT AHRS Mounting and CG |
johngoodman wrote:
> properly aligned.
John
I think it is left side only unless they made a right side. Did you
install something other than TruTrak? My TruTrak servo is on the right.
