rv-9a-online(at)telus.net Guest
Posted: Tue Jul 28, 2009 9:25 pm Post subject: Switch Failures |
Approximately 100 hours ago, I replaced all of my Carling toggle switches
with Honeywell/Microswitch switches in my RV-9A. I had experienced
multiple failures with the Carling switches in the first 150 hours due to
loose terminals and overheating leading to charred terminals and wiring.
There is a long thread on this topic, including some failure analysis by
Bob.
At this point, I have had no additional switch failures after switching to
the Honeywell switches. At the time, Bob postulated that the lack of
decoupling loops in the wiring may have contributed. I was not so sure, so
I made no other changes other than replacing the switches.
While not conclusive, I would say the root cause of failure was the loose
riveted terminals on the Carling Switches. The lack of decoupling loops in
the wiring may have contributed, but it appears that a higher quality switch
is an effective solution.
I had two failures on the Strobe circuit, one on the Landing light circuit
and one on the progressive-transfer Master Switch in the first 150 hours
with the Carling Switches.
So, if anyone thinks that this is just a characteristic of our OBAM aircraft
being built with "substandard" components, look at this:
FAA Issues Airworthiness Bulletin For Cessna GA Aircraft
Tue, 28 Jul '09
SAIB Affects 100, 200, 300 Series Cessna Aircraft
The FAA has issued a Special Airworthiness Information Bulletin (SAIB) to
advise pilots and owners of an airworthiness concern on mandatory
replacement intervals of Cessna Landing Light, Beacon Light, and Taxi Light
switches on Cessna 100, 200, and 300 series airplanes, specified in Cessna
service bulletins MEB09-3 and SEB09-6 dated May 11, 2009.
Cessna 100, 200, and 300 series airplanes utilize switches in the Landing
Light, Beacon Light, and Taxi Light circuits that have been reported failing
in the field causing overheating and smoke in the cockpit. There have been
reports of burned insulation on the wiring terminals to the switch. On at
least one occasion, there was a small fire in the cockpit. The failure in
these applications can be attributed to contact erosion leading to irregular
arcing and eventual failure of the switch. The contact erosion has been
shown to occur after approximately 4,000 cycles of operation.
Cessna service bulletins SEB09-6 and MEB09-3, initial release, dated May 11,
2009, specify the following:
.An inspection to determine time-in-service for the switches.
.Replacement of switches that have been in service for four or more years
with the month and year of the installation written on the new replacement
switch.
.The month and year of the initial installation written on switches that
have been in service for less than four years.
The FAA recommends that owners, operators, and maintenance technicians act
on the above-referenced service bulletins within the next 400 hours of
operation, 12 months, or the next annual inspection, whichever comes first.
Vern Little
Vx Aviation
peterlaurence6(at)gmail.c Guest
Posted: Wed Jul 29, 2009 5:43 am Post subject: Switch Failures |
Vern
Can you post the product number for the Honeywell switches?
Peter
On Wed, Jul 29, 2009 at 1:22 AM, Vern Little <rv-9a-online(at)telus.net (rv-9a-online(at)telus.net)> wrote:
[quote]--> AeroElectric-List message posted by: "Vern Little" <rv-9a-online(at)telus.net (rv-9a-online(at)telus.net)>
Approximately 100 hours ago, I replaced all of my Carling toggle switches with Honeywell/Microswitch switches in my RV-9A. I had experienced multiple failures with the Carling switches in the first 150 hours due to loose terminals and overheating leading to charred terminals and wiring. There is a long thread on this topic, including some failure analysis by Bob.
At this point, I have had no additional switch failures after switching to the Honeywell switches. At the time, Bob postulated that the lack of decoupling loops in the wiring may have contributed. I was not so sure, so I made no other changes other than replacing the switches.
While not conclusive, I would say the root cause of failure was the loose riveted terminals on the Carling Switches. The lack of decoupling loops in the wiring may have contributed, but it appears that a higher quality switch is an effective solution.
I had two failures on the Strobe circuit, one on the Landing light circuit and one on the progressive-transfer Master Switch in the first 150 hours with the Carling Switches.
So, if anyone thinks that this is just a characteristic of our OBAM aircraft being built with "substandard" components, look at this:
Tue, 28 Jul '09
The FAA has issued a Special Airworthiness Information Bulletin (SAIB) to advise pilots and owners of an airworthiness concern on mandatory replacement intervals of Cessna Landing Light, Beacon Light, and Taxi Light switches on Cessna 100, 200, and 300 series airplanes, specified in Cessna service bulletins MEB09-3 and SEB09-6 dated May 11, 2009.
Cessna 100, 200, and 300 series airplanes utilize switches in the Landing Light, Beacon Light, and Taxi Light circuits that have been reported failing in the field causing overheating and smoke in the cockpit. There have been reports of burned insulation on the wiring terminals to the switch. On at
least one occasion, there was a small fire in the cockpit. The failure in these applications can be attributed to contact erosion leading to irregular arcing and eventual failure of the switch. The contact erosion has been shown to occur after approximately 4,000 cycles of operation.
Cessna service bulletins SEB09-6 and MEB09-3, initial release, dated May 11, 2009, specify the following:
.Replacement of switches that have been in service for four or more years with the month and year of the installation written on the new replacement switch.
.The month and year of the initial installation written on switches that have been in service for less than four years.
The FAA recommends that owners, operators, and maintenance technicians act on the above-referenced service bulletins within the next 400 hours of operation, 12 months, or the next annual inspection, whichever comes first.
Vern Little
Vx Aviation
nuckollsr
Joined: 24 Mar 2009 Posts: 95 Location: Medicine Lodge, KS
Posted: Wed Jul 29, 2009 7:24 am Post subject: Re: Switch Failures |
"The failure in these applications can be attributed to contact erosion leading to irregular arcing and eventual failure of the switch. The contact erosion has been shown to occur after approximately 4,000 cycles of operation."
I'm away from my office for a couple of days. I'll have a more extensive response when I get back "to the hills".
It would be interesting/enlightening to see the failed switches. For all of the Carling failures I examined, there was no evidence of contact erosion. In fact, all failure examples displayed evidence of heating effects that began away from the contacts . . . most notably at the riveted joins for the fast-on tabs. It would also be interesting to know how the problem aircraft were flown. I've flown dozens of Cessna aircraft fitted with switches where the factory original switches were 40+ years old. I also recall testing the the lab at Cessna East (single engine) on the Carling rocker switches were tens of thousands of cycles were impressed on the switches before they were deemed suited to the task.
I suspect that root cause for this rash of failures is yet to be deduced and understood. Action taken by the regulators was predictable. Write an $AD$ that demands replacing a $2 switch with the one that's been re-labeled with Cessna's $Standard-Part$ number.
I don't know if any of the gray-beards are still working out there. I'll have to call around and see what I can discover.
jlisler(at)windstream.net Guest
Posted: Fri Jul 31, 2009 8:15 am Post subject: Switch Failures |
Bob,
While on the subject of switches, what's up with the AD on Beechcraft
switches? My local FBO has 3 or 4 Bonanzas and a couple of Barons in the
shop to replace all the switches on the panels. They told me the switches
were about $130 each (cost!!!!) plus several hours labor to install. I
cannot imagine charging that much for a switch.
Jerry Isler
RV4 N455J
Posted: Fri Jul 31, 2009 10:09 am Post subject: Switch Failures |
At 11:13 AM 7/31/2009, you wrote:
<jlisler(at)windstream.net>
Bob,
Beechcraft switches? My local FBO has 3 or 4 Bonanzas and a couple
of Barons in the shop to replace all the switches on the panels.
They told me the switches were about $130 each (cost!!!!) plus
several hours labor to install. I cannot imagine charging that much
for a switch.
Gee . . . ONLY $130? It has to be because the
volume in sales is up. While I was still at HBC,
I seem to recall a price of $175 each.
The device in question is a breaker-switch . . .
http://aeroelectric.com/Pictures/Breakers/W31_3.jpg
. . . where robustness of the braided copper jumper
wire is not meeting design goals. If the "added
insulator" is not present, jumper failure causes
load current to flow through the contact-spreading
spring. IF the switch is used in a high current
application (prop de-ice, pitot heat) then the spring
smokes and folks get upset.
Problem is similar to the AD being discussed on the
Cessna switches. The Bonanzas and Barons total about
80,000 switches in the field. The Cessna situation
is probably much larger.
This is a great example of what happens when one
discovers a failure to meet design goals in a
legacy product with huge numbers. The only folks
upset about it are the aircraft owners. The FBO
can sympathize but he cannot do anything practical.
Cessna and Beech can't do anything practical either.
First, it's unlikely that they have anyone on their
staff that truly understands root causes for
the problems. Second, practical fixes require
properly approved kits with staggering costs and
time-to-market issues driven by bureaucracy and
corporate policy/procedure albatrosses.
So, what's the easy fix? AD the critters, spread
the costs around the fleet owners. But make sure
the work is accomplished only by qualified technicians
at FBO standard rates.
The type certificated light airplane market
is sinking ever lower in the FAA/ISO tarpits.
While at Cessna in 1965 or so, we broke 10,000
airplanes per year production. It's never
been that high since and the trends are going
down.
( -Thomas Paine 1776- )
frank.hinde(at)hp.com Guest
Posted: Fri Jul 31, 2009 10:24 am Post subject: Switch Failures |
Buy one switch then search heavan and earth to find the supplier and buy direct from them..then hand them to the A&P..Got to be worth a shot..Gee!
Frank...Thankfully experimental!
Bob,
While on the subject of switches, what's up with the AD on Beechcraft switches? My local FBO has 3 or 4 Bonanzas and a couple of Barons in the shop to replace all the switches on the panels. They told me the switches were about $130 each (cost!!!!) plus several hours labor to install. I cannot imagine charging that much for a switch.
Jerry Isler
RV4 N455J
dave.gribble(at)mchsi.com Guest
Posted: Fri Jul 31, 2009 5:57 pm Post subject: Switch Failures |
At 08:08 PM 7/31/2009, you wrote:
<dave.gribble(at)mchsi.com>
The cost isn't that high - I paid only $98-$105 each for my six
switch / breakers. Its the miracle of certified aviation.
BTW - there was a vendor at Oshkosh who claims that the new switches
are also defective (with a somewhat different failure mode - the
breakage of the braided wire inside).
That was the ORIGINAL failure with a secondary event
(smoking spring) caused by current flowing through
the spring between the contact strut and the frame.
The "FIX" didn't stop the wire from breaking, it only
kept the secondary event from occurring. So instead
of getting a broken wire followed by smoke, you only
get a dead accessory. Now, I suppose the next shoe to
drop will insist that some light or warning be included.
Yeah, put a paragraph in the flight manual asking the
pilot to keep an eye on the ammeter lest a broken wire
sneak past without notice . . . but at least we don't
put smoke in the cockpit.
| Quote: | He claimed to have "just yesterday" received a PMA for his
replacement switch/breaker. It was only $130.... taking orders
but not yet available.
Do you have his contact data?
Posted: Fri Jul 31, 2009 8:20 pm Post subject: Switch Failures |
His handout reads:
"MAJOR PROBLEM! If you install the NEW Beech Circuit Breaker for the AD, be
prepared for smoke, sparks, or fire in the cockpit.
THE Braided Wire BREAKS..."
You can read the rest of it with photos here:
http://www.williamsairpower.com/pdf/switches.pdf
Contact info as requested:
Daniel J. Williams
Williams Air Power
730 Lincoln Lake Ave Lowell MI 49331
616-897-5785
BTW Bob - in all the recent thread about regular (non-breaker) toggle
switches failing there was talk of Carling and Honeywell.... do you know
whose parts B&C sells? I want to buy the switches for my RV.
dave
Posted: Sat Aug 01, 2009 5:41 am Post subject: Switch Failures |
At 11:17 PM 7/31/2009, you wrote:
| Quote: | --> AeroElectric-List message posted by: "Dave Gribble" <dave.gribble(at)mchsi.com>
His handout reads:
"MAJOR PROBLEM! If you install the NEW Beech Circuit Breaker for the AD, be prepared for smoke, sparks, or fire in the cockpit.
You can read the rest of it with photos here: http://www.williamsairpower.com/pdf/switches.pdf
Good grief! A one page .pdf file of over 12 megabytes!
Here's the meat of the text . . .
The Braided Wire BREAKS
This one was 90% failed when opened. ALL Beech
and Tyco circuit breaker switches have the braided
wire.
Yes, that basic design has existed in this
product since the early 60's. That series
of breaker-switches has been manufactured
in the hundreds of thousands with about
80K used in Beech products and perhaps
the same amount in some Cessna models.
Commercially, that design has a market footprint
probably in the millions. Now, there is
a fundamental flaw in the design for this
product. You'll all no doubt recall numerous
discussions about "gas-tight" for reliable
connectivity and "support at the stress risers"
for robustness. This is a common theme throughout
the universe of wire connection. It was discussed
at length in . . .
http://aeroelectric.com/articles/terminal.pdf
As you can see in this photo . . .
[url=http://aeroelectric.com/Pictures/Breakers/W31_w_\'Failed\'_jumper_wires.jpg] http://aeroelectric.com/Pictures/Breakers/W31_w_%27Failed%27_jumper_wires.jpg[/url]
. . . the braid is SPOT WELDED to the
forward corner of the frame. Yeah, let's hear
it for gas-tight. But were is the support at the
stress-risers for robustness? It isn't there.
Now, in the photo above, the "failed" wires are
some that I cut to see if I could detect a delta-R
in the breaker's closed position for the purposes
of detecting an impending failure. It wasn't possible
with ordinary tools. However, when wires break in the
fielded products, they fail right at the edge of
the spotweld. Predictable.
When the braided wire fails it either fails open or
closed. If it fails open, the current then goes through
the arm, through the spring and onto the load bar.
The FAA used the word "shorted" in some of their
descriptions of failure modes. I objected but
the document was already published and in the
field. It's a rare bureaucrat that will
step up to do the right thing when caught with
his pants down. I don't think there were EVER
instances of shorting, only of broken wires
that transferred the major current path to
an uninsulated spring.
By insulating the spring it solved this problem. However
many Tyco circuit breaker switches have failed
closed or shorted ( in all types of aircraft). When the
braid breaks off and closes the buss input to the load
bar, it renders the switch ineffective and uncontrolled
electricity goes through that circuit. After that it is
smoke, sparks, and ultimately fire unless God
intervenes.
A classic example of seizing on a few
facts, a few off the wall assumptions,
some mis-interpreted drivel from the
bureaucrats, an scare the pants off the
uninformed by alluding to enhanced risk
of joining their maker . . .
What is needed is a circuit breaker switch that
does not have a braided wire.
Simplify the current path.
Without a doubt, the new design is superior
with regard to the elimination of the poorly
implemented spot-welds for wire bonding. However,
this product doesn't have the field history
of the existing part. It's not known if 20
years and 100,000 parts from now, some new
AD won't be issued against this part as well.
What we DO know is that the failures are rare,
and relatively benign and is only a risk for
the breakers above 10A continuous loads.
If it were my airplane, I'd replace the pitot
heat and prop heat switch breakers with the
new design, leave the rest alone.
Just like the guy who got an STC for replacing
Piper's aluminum cables with copper cables
and made a bundle selling holy-watered hunks
of wire, this guy is going to make some bux
selling a $30 device at a huge mark-up . . .
made possible because he was willing to run
the traps with the folks who holy-watered
his product.
Hey, how about a "cash for breakers" program?
Talk to the right folks in Congress and I'll
bet we can soak our grandchildren for a
few $millions$ to help this guy get well quicker
and alleviate the need for prayers in the cockpit.
lrsecaldwell(at)earthlink Guest
Posted: Sat Aug 01, 2009 1:20 pm Post subject: Switch failures |
Does anyone have a cross reference from B & C part numbers to Honeywell's part numbers?
Roger
Posted: Sat Aug 01, 2009 5:02 pm Post subject: Switch failures |
At 04:13 PM 8/1/2009, you wrote:
| Quote: | Does anyone have a cross reference from B & C part numbers to Honeywell's part numbers?
The last two digits of B&C's numbers carry over
to the Honeywell part numbers shown in
http://www.aeroelectric.com/Mfgr_Data/Switches/Microswitch/Microswitch_TL-Series.pdf
For example, the S700-2-3 is a Honeywell 2TL1-3
| | | \--Function
| | \-- # of poles
| \---- Function
\----- # of poles
