rvdave
Posted: Tue Aug 04, 2009 7:01 pm Post subject: mounting steps |
I'm in the process of mounting steps on a QB, the steps were pre-drilled and according to the drawings the weld should be flush with the skin, which it isn't, and the measurement from rear spar should be 45 1/2, which it's about 46 with fuselage leveled. I could either let it go as is, move step to correct position and re-drill 90 deg from previous hole, or order new steps and align with existing hole. What are your experiences as to how your steps came out in relation to plans?
Dave Ford
_________________ Dave Ford
Cadillac, MI |
jeff(at)westcottpress.com Guest
Posted: Tue Aug 04, 2009 8:13 pm Post subject: mounting steps |
Hi Dave,
From what I remember of a conversation with Vans, the step position
relative to the rear spar has more to do with clearing the flaps when
extended than anything else. If your step is canted a bit further aft
than specified, I don't think you have a problem. You don't say how
far from flush the weld is to the skin. Mine stopped at the edge of
the widest edge of the weld bead... which didn't seem all that "flush."
Jeff Carpenter
40304
Doors. Ugh!
On Aug 4, 2009, at 8:01 PM, rvdave wrote:
Dave Ford
Dave Ford
RV6 flying
RV10 building
Cadillac, MI
http://forums.matronics.com/viewtopic.php?p 56093#256093
johngoodman
Posted: Wed Aug 05, 2009 3:40 am Post subject: Re: mounting steps |
I wouldn't worry about it too much. Some of the weld will be visible but no big deal. As long as you clear the flaps, it should be fine.
