		jrlark
				 Posted: Wed Aug 05, 2009 5:10 am    Post subject: proseal |
				Hi guys
  I came home with a quart of Proseal and hardener from Airventure and recall
  people putting the Proseal in a freezer to extend its shelf life.
  The expiry date is Nov 2009, and since I won't be starting the tail section
  until at least Sept, I am wondering if it's unopened, if it matters?  Also
  did anyone freeze the hardener as well?
  Thx in advance.......
  Rick
  #40956
  Southampton, Ont
		flysrv10(at)gmail.com Guest
				 Posted: Wed Aug 05, 2009 5:44 am    Post subject: proseal |
				I store it in the frig not the freezer.  It seems to work even after
 couple of years of storage.
 do not archive.
 On Aug 5, 2009, at 9:05 AM, Sandra & Rick Lark wrote:
  <jrlark(at)bmts.com>
  Hi guys
  recall
  section
  matters?  Also
  Rick
  #40956
  Southampton, Ont
		AirMike
				 Posted: Wed Aug 05, 2009 5:48 am    Post subject: proseal shelf life |
				I do not know about the freezer, it is not water based.  Refer might be preferred if there is no smell.
 I do know that I had Van's 2 oz kit (bought last Oct) in my very cold garage all winter, and have used it with good results all this summer. Garage is in the 40's most of the winter.
  _________________ See you OSH '18
Q/B - sold. |
		drfred(at)suddenlinkmail. Guest
				 Posted: Wed Aug 05, 2009 5:55 am    Post subject: proseal |
				Rick;
 I do keep the proseal in the freezer. I have used it about a year over
 exp date for non essential areas.  I wouldn't hesitate using it on the
 trailing edges/to bond the rudder/elevator if it was a little over the
 exp date.  I would not use it for the tanks.  All you have to do is look
 at the recent posts with all the trouble one has to go thru if you have
 a leaking tank.  Some have even repainted their airplanes.  Messes up
 the paint scheme which can take months to develop.
 Dr Fred.
  Hi guys
  recall
  section
  Also
  Rick
  #40956
  Southampton, Ont
		planesmith(at)hotmail.com Guest
				 Posted: Wed Aug 05, 2009 5:57 am    Post subject: proseal |
				Hi Rick C
  I put both parts in the refrigerator. It's a little stiff when you take it out but it has worked fine. Can't comment on the freezer idea.
  Vern Smith (N44QT finishing)
  	  | Quote: | 	 		   From: jrlark(at)bmts.com
  Subject: proseal
  Date: Wed C 5 Aug 2009 09:05:48 -0400
  --> RV10-List message posted by: "Sandra & Rick Lark" <jrlark(at)bmts.com>
  Hi guys
  The expiry date is Nov 2009 C and since I won't be starting the tail section
  until at least Sept C I am wondering if it's unopened C if it matters? Also
  Rick
 [quote] _=====
 Get back to school stuff for them and cashback for you. Try BingT now.
		Kelly McMullen
				 Posted: Wed Aug 05, 2009 6:08 am    Post subject: proseal |
				I know some manufacturers had/have FAA approval for storing in
 freezer, followed by microwaving so many seconds(of course only works
 for non-metal sem-tubes). Like others, I store mine in hangar
 refrig..adds to beer and soda flavor.
 On Wed, Aug 5, 2009 at 6:30 AM, Rob Kermanj<flysrv10(at)gmail.com> wrote:
  I store it in the frig not the freezer.  It seems to work even after couple
  do not archive.
 > Hi guys
 > recall
 > section
 > Rick
 > #40956
 > Southampton, Ont
A&P/IA, EAA Tech Counselor
KCHD |
		rene(at)felker.com Guest
				 Posted: Wed Aug 05, 2009 6:22 am    Post subject: proseal |
				I would recommend keeping it cool at least, you will need it later in the
 project and it will keep for a long time if it is kept out of the heat.  In
 the winter I kept my in the garage and in the spring, summer and fall, I
 kept it in the refrigerator.  I did not have any problem with it setting up.
 Rene' Felker
 RV-10 N423CF Flying
 801-721-6080
		Tim Olson
				 Posted: Wed Aug 05, 2009 6:24 am    Post subject: proseal |
				Put it in the freezer and it should be fine for the tail kit.
 You may want to buy a quart or more of new when you get to
 the fuel tanks.  This stuff you can use for misc. jobs
 for a couple years at least if you keep it in the freezer,
 but use new for your fuel tanks.
 Tim Olson - RV-10 N104CD
  Hi guys
  Rick
  #40956
  Southampton, Ont
				 Posted: Wed Aug 05, 2009 10:36 am    Post subject: proseal |
				Doesn't have to be in the freezer .... just keep it cold.  The hardener
 is the part that goes bad with age.  I've tested really old Proseal with
 fresh hardener and it cured.
 Linn
  Hi guys
  Rick
  #40956
  Southampton, Ont
		msausen
				 Posted: Wed Aug 05, 2009 11:05 am    Post subject: proseal |
				I put leftover proseal from my tanks in the freezer for 3-4 years now.  I needed to use some for the cabin top riveting recently and actually threw both parts in the microwave to warm up enough to mix (I wouldn't recommend this for any large qty) and had no problems with it.  Setup just like it was new. YMMV and I would recommend a test batch for any that is past the recommended date.
 Michael
		jrlark
				 Posted: Wed Aug 05, 2009 1:25 pm    Post subject: proseal |
				Thx for all the replies with regards to  proseal.  It's already sitting beside the BudLight in the shop  refrigerator.
  Rick
  #40956
  Southampton, Ont
		Kelly McMullen
				 Posted: Wed Aug 05, 2009 2:15 pm    Post subject: proseal |
				I hear it is Light sensitive. Probably safer next to Molson.
 On Wed, Aug 5, 2009 at 2:22 PM, Rick and Sandra Lark<jrlark(at)bmts.com> wrote:
  	  | Quote: | 	 		   Thx for all the replies with regards to proseal.  It's already sitting
  Rick
  #40956
  Southampton, Ont
KCHD |
		jeff(at)westcottpress.com Guest
				 Posted: Wed Aug 05, 2009 2:16 pm    Post subject: proseal |
				Bud Light?  I thought you all drank Labatts up there?
 On Aug 5, 2009, at 2:22 PM, Rick and Sandra Lark wrote:
  	  | Quote: | 	 		  Thx for all the replies with regards to proseal.  It's already sitting beside the BudLight in the shop refrigerator.
 Rick
 #40956
 Southampton, Ont
